Installing GenyMotion on Jetson TX1
I would like to install the Genymotion (android emulator) on my Jetson TX1 to play android supported games. But I have encountered a problem with the VirtualBox (as it is required for Genymotion) installation. When installing, it shows architecture does not match. The VirtualBox is amd64 whereas the Jetson is arm64. So is there any way to install it, or which is the apt emulator that can be installed on Jetson TX1?"
I haven’t looked at emulators on the Jetson, but the emulator must support arm64…anything “PC” will not work. I don’t know what is available out in the wild, but if no native version exists with arm64, perhaps source is available and arm64 could be enabled.
