Hello! When installing imageAI, I get an error:
File “/usr/lib/python3/dist-packages/setuptools/sandbox.py”, line 154, in save_modules
yield saved
File “/usr/lib/python3/dist-packages/setuptools/sandbox.py”, line 195, in setup_context
yield
File “/usr/lib/python3/dist-packages/setuptools/sandbox.py”, line 250, in run_setup
_execfile(setup_script, ns)
File “/usr/lib/python3/dist-packages/setuptools/sandbox.py”, line 45, in _execfile
exec(code, globals, locals)
File “/tmp/easy_install-ukxargtw/numpy-1.22.3/setup.py”, line 34, in
# The setuptools version of sdist adds a setup.cfg file to the tree.
RuntimeError: Python version >= 3.8 required.
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "/tmp/pip-build-owm07z3e/matplotlib/setup.py", line 299, in <module>
cmdclass=cmdclass,
File "/usr/lib/python3/dist-packages/setuptools/_init_.py", line 128, in setup
_install_setup_requires(attrs)
File "/usr/lib/python3/dist-packages/setuptools/_init_.py", line 123, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 513, in fetch_build_eggs
replace_conflicting=True,
File "/usr/lib/python3/dist-packages/pkg_resources/_init_.py", line 774, in resolve
replace_conflicting=replace_conflicting
File "/usr/lib/python3/dist-packages/pkg_resources/_init_.py", line 1057, in best_match
return self.obtain(req, installer)
File "/usr/lib/python3/dist-packages/pkg_resources/_init_.py", line 1069, in obtain
return installer(requirement)
File "/usr/lib/python3/dist-packages/setuptools/dist.py", line 580, in fetch_build_egg
return cmd.easy_install(req)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 698, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 724, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 909, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1177, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1163, in run_setup
run_setup(setup_script, args)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/usr/lib/python3.6/contextlib.py", line 99, in _exit_
self.gen.throw(type, value, traceback)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/usr/lib/python3/dist-packages/setuptools/_vendor/six.py", line 685, in reraise
raise value.with_traceback(tb)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
yield
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 250, in run_setup
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 45, in _execfile
File "/tmp/easy_install-ukxargtw/numpy-1.22.3/setup.py", line 34, in <module>
Edit setup.cfg to change the build options; suppress output with --quiet.
BUILDING MATPLOTLIB
matplotlib:yes [3.3.2]
python: yes [3.6.9 (default, Mar 15 2022, 13:55:28) [GCC 8.4.0]]
platform: yes [linux]
sample_data: yes [installing]
tests: no [skipping due to configuration]
macosx: no [Mac OS-X only]
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-owm07z3e/matplotlib/
help solve the problem
