When I try to install Jetpack 3.0.0 on a host pc (Ubuntu 16.04) in order to use it for the Jetson TX1 I get the following error message, meaning it fails at getting file:/var/cuda… and it can’t find the file or directory:
“E: Fehlschlag beim Holen von file:/var/cuda-repo-8-0-local/./cuda-toolkit-8-0_8
0.44-1_amd64.deb Datei nicht gefunden - /var/cuda-repo-8-0-local/./cuda-toolkit-8-0_8.0.44-1_amd64.deb (2: Datei oder Verzeichnis nicht gefunden)”
In addition, when I try to access /var/cuda-repo-8-0-local/./cuda-toolkit-8-0_8.0.44-1_amd64.deb, there is only a file called cuda-toolkit-8-0_8.0.34-1_amd64.deb.
