I have downloaded Jetpack latest version from Nvidia website to install it on my TX2.
here is my setup:
My PC is connected to Internet via LAN connection.
TX2 is connected to the PC via LAN connection using Network card.
After installing Ubuntu, Jetpack fails due to a permission denied error.
161.4459 ] […] 199%
161.5186 1
161.5292 ] tegradevflash_v2 -write MBl_BCT_b mb1_cold_boot_bct_MBl_sigheader.
Ibct.encrypt
161.5218 ] Bootloader version 01.00.0099
161.5240 ] Writing partition MBl_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bc
t.encrypt
I[ 161.5257 ] […] 109%
161.5882
161.5882 ] Flashing completed
161.5883 ] Coldbooting the device
161.5999 ] tegradevflash_v2 -reboot coldboot
161.5914 ] Bootloader version 01.00.0000
1[ 161.5978 1
The target t186ref has been flashed successfully.
Reset the board to boot from internal eMMC.
root 5724 0.1 9.9 265364 3590 ? Ssl 17:41 0:02 /home/azim_se/M
yProjects/JETSON-TX2/JetPack/_installer/sudo_daemon -installer=1 -d=/home/azim_s
ie/MyProjects/JETSON-TX2/JetPack/_installer/tmp
l/home/azim_se/MyProjects/JETSON-TX2/JetPack//_installer/run_command -c=“mv /hom
e/azim_se/MyProjects/JETSON-TX2/JetPack/64_TX2/Linux_for_Tegra/rootfs/etc/rc.loc
al.original /home/azim_se/MyProjects/JETSON-TX2/JetPack/64_TX2/Linux_for_Tegra/r
ootfs/etc/rc.local” -d=/home/azim_se/MyProjects/JETSON-TX2/JetPack//_installer/t
mp
I 1
Finished Flashing OS
Determining the IP address of target…
10.0.0.2
I Waiting 39 seconds to make sure target is fully up
DEBUG: echo GetValueToInfoBroker: key = Install_Dir, value = /home/azim_se/MyPr
ojects/JETSON-TXZ/JetPack >> /tmp/jetpack_debug.log
DEBUG: mkdir -p /.ssh
mkdir: cannot create directory ‘/.ssh’: Permission denied
DEBUG: touch /.ssh/known_hosts
touch: cannot touch ‘/.ssh/known_hosts’: No such file or directory
gDEBUG: ssh-keygen -q -N “” -f / ssh/id_rsa
Saving key “/.ssh/id_rsa” failed: No such file or directory
DEBUG: ssh-keygen -R 19.9.9.2
1# Host 10.0.0.2 found: line 28
home/azim_se/.ssh/known_hosts updated.
IOriginal contents retained as /home/azim_se/.ssh/known_hosts.old
IDEBUG: ssh-keyscan 10.0.0.2>>/.ssh/known_hosts
‘lbin/bash: /.ssh/known_hosts: No such file or directory
“DEBUG: echo
iDEBUG: ssh-add /.ssh/id_rsa 9<&-
i/.ssh/id_rsa: No such file or directory
scp -F /dev/null -o PubkeyAuthentication=no -o ConnectTimeout=30 -o StrictHostKe
yChecking=no /.ssh/id_rsa.pub nvidia@10.0.0.2:/home/nvidia/tmp.pub
0.0.2’5
l/.ssh/id_rsa.pub: No such file or directory
‘mv: cannot stat ‘/home/nvidia/tmp.pub’: No such file or directory
Invidia@tegra-ubuntu:~$
anidia©tegra~ubuntu:~$ exit
qlogout
“Connection to 19.9.9.2 closed.
