Hi Folks,
I have a Tx1 board. I installed most recent version of jetpack on it two weeks back. I building an example code on Tx1 which makes use of libvisionworks-nvxio. I do not have libvisionworks-nvxio and looking for help in installing it on my Tx1. I do have libvisionworks on my board.
Thanks,
Following is what I have tried -
ubuntu@tegra-ubuntu:~/work/Demo$ sudo apt-get install libvisionworks-nvxio
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package libvisionworks-nvxio
u
Do you use visionworks 1.5? (since we changes API in visionworks-1.6)
Library can be found in
/usr/lib/libvisionworks.so
/usr/lib/libnvxio.so
Command should be
nvcc test.cpp -lnvxio -lvisionworks -o test
Hi AastaLLL
I do see /usr/lib/libvisionworks.so, but I do not see any /usr/lib/libnvxio.so. How can I install libnvxio ?
Thanks,
Which version do you use?
In VisionWorks-1.6:
NVXIO was split to NVX and OVX. And libnvx.a and libovx.a will be generated automatically before building visionworks samples.
Please read more information in VisionWorks release note:
https://developer.nvidia.com/embedded/dlc/visionworks-1-6-release-notes
How can I find the version of VisionWorks ? I am thinking I will reinstall the Jet pack again. That look way more simpler/safe/quick.
BTW, my emmc card with 16GB capacity is full. I have a 128 GB SD card - which has everything set up on it. I am booting ubuntu from SD card.
Thanks,
Please try this:
dpkg -l | grep visionworks
If you install VisionWorks with JetPack3.0, it should be version1.6.
VisionWorks-1.5, which has libnvxio and libvisionworks, can be installed with JetPack2.3.1.
I see following …
ii libvisionworks 1.6.0.235n arm64 NVIDIA's VisionWorks Library and supplemental data
ii libvisionworks-dev 1.6.0.235n all Development files for NVIDIA's VisionWorks Library
ii libvisionworks-docs 1.6.0.235n all Documentation for NVIDIA's VisionWorks Library
ii libvisionworks-repo 1.6.0.235n arm64 NVIDIA VisionWorks computer vision library.
ii libvisionworks-samples 1.6.0.235n arm64 Samples for NVIDIA's VisionWorks Library
ii libvisionworks-sfm 0.90.1 arm64 SFM module for NVIDIA's VisionWorks Library
ii libvisionworks-sfm-dev 0.90.1 arm64 Development files for SFM module for NVIDIA's VisionWorks Library
ii libvisionworks-sfm-docs 0.90.1 all Documentation for SFM module for NVIDIA's VisionWorks Library
ii libvisionworks-sfm-repo 0.90.1 arm64 Package repository for NVIDIA's VisionWorks SFM module.
ii libvisionworks-tracking 0.88.0 arm64 Tracking module for NVIDIA's VisionWorks Library
ii libvisionworks-tracking-dev 0.88.0 arm64 Development files for Tracking module for NVIDIA's VisionWorks Library
ii libvisionworks-tracking-docs 0.88.0 all Documentation for Tracking module for NVIDIA's VisionWorks Library
ii libvisionworks-tracking-repo 0.88.0 arm64 Package repository for NVIDIA's VisionWorks Tracking module.
Thanks for your feedback.
Based on your log, visionworks-1.6 is installed.
If you prefer nvxio API, please migrate to visionworks-1.5.
No need to flash every, just re-install visionworks should be enough:
- Remove visionworks-1.6 first:
$ sudo apt-get remove --purge libvisionworks-samples libvisionworks-dev libvisionworks-docs libvisionworks
$ sudo apt-get purge libvisionworks-repo
$ sudo apt-get update
- Install visionworks-1.5 via JetPack2.3.1 (only select visionworks packs)
Thanks AastaLLL.
I would not like to move backward. I have problem compiling following code
#include <NVX/nvx.h>
#include <NVX/nvx_timer.hpp>
#include <NVXIO/Application.hpp>
#include <NVXIO/ConfigParser.hpp>
#include <NVXIO/FrameSource.hpp>
#include <NVXIO/Render.hpp>
#include <NVXIO/SyncTimer.hpp>
#include <NVXIO/Utility.hpp>
I am getting following error
ubuntu@tegra-ubuntu:~/work/Demo$ make
Package nvxio was not found in the pkg-config search path.
Perhaps you should add the directory containing `nvxio.pc'
to the PKG_CONFIG_PATH environment variable
No package 'nvxio' found
nvcc -O3 -DNDEBUG -std=c++11 -o obj/release/leopard_demo.o -c leopard_demo.cpp
nvcc warning : The 'compute_20', 'sm_20', and 'sm_21' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
leopard_demo.cpp:38:33: fatal error: NVXIO/Application.hpp: No such file or directory
compilation terminated.
Makefile:101: recipe for target 'obj/release/leopard_demo.o' failed
make: *** [obj/release/leopard_demo.o] Error 1
Any idea which header I should use from visionworks 1.6 ?
Thanks,
As mentioned in #4, NVXIO was split into NVX and OVX.
Since API changes, please modify your source with NVX and OVX rather than NVXIO.
Please refer to Visionworks-1.6 samples to get more hint.
