Installing Linux Drivers on Ubuntu
Hello, I’m new here. I need help on installing drivers on pc that i’m building. I need help installing drivers on Ubuntu 26.04.1 LTS for (2x) RTX 3090 GPUs and CUDA ready for GPU, please assist, thanks!
This is easy on Ubuntu. Review this doc: NVIDIA drivers installation - Ubuntu Server documentation
The short version:
For general purpose desktops:
$ sudo ubuntu-drivers install
For servers:
$ sudo ubuntu-drivers install --gpgpu
The downside is that if you use the Ubuntu-provided drivers above, they are not the most recent ones released by NVIDIA. Depending on what you intend to do, this might be fine.
If you want the most recent version, you can follow this to get them from NVIDIA directly: Ubuntu — NVIDIA Driver Installation Guide
Just be warned that it’s a bit more complicated.
Hi Catt, thanks for your response. The link for the most recent version install is not that bad at all. The only question that i have is the driver version. My question is, what is the driver version for my gpu.
RTX 3090 GPU, that’s the gpu that i’m planning to purchase.
ubuntu-drivers will select it for you, they have an entire wiki on it you can search “ubuntu nvidia install” and its on the first 10-15 results
EDIT: its 2 of the first 3 results
The 3090 supports the current driver releases and the specific version is probably not something you need to worry about, unless you have some special requirement.
If you install it directly from the NVIDIA repo, as per the second link in my post, then by default, the system will automatically install the latest version, which is 620.70.06 as of this writing.
If you install it from Ubuntu, then you will get an older version.
Got it! I found a youtube tutorial (from a year ago - Ubuntu 24.04). The way I’m going to do the Nvidia installation is when i’m installing the Ubuntu OS, I’ll select the Install recommended proprietary software prompt. It’s going to install the 3rd party apps, drivers for my wi-fi, NVidia , and etc. Although, i’ll be installing an older version but i’ll get on the terminal, remove the older Nvidia software, and install the drivers from the repo so it will be current. I’ll make sure that I do the OS updates prior to the Nvida driver installation.
I’m also going to give Echoa props for pointing me in the right direction.
