Installing Nvidia Graphic Card in ArchLinux WSL2
I am unable to install graphic card in arch linux wsl2…Please help me out…now main problem is that it is not showing any screen when i do startx
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-linux-gnu/11.2.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /build/gcc/src/gcc/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=https://bugs.archlinux.org/ --enable-languages=c,c++,ada,fortran,go,lto,objc,obj-c++,d --with-isl --with-linker-hash-style=gnu --with-system-zlib --enable-__cxa_atexit --enable-cet=auto --enable-checking=release --enable-clocale=gnu --enable-default-pie --enable-default-ssp --enable-gnu-indirect-function --enable-gnu-unique-object --enable-linker-build-id --enable-lto --enable-multilib --enable-pgo-build=lto --enable-plugin --enable-shared --enable-threads=posix --disable-libssp --disable-libstdcxx-pch --disable-werror --with-build-config=bootstrap-lto --enable-link-serialization=1 gdc_include_dir=/usr/include/dlang/gdc
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 11.2.0 (GCC)
╭─dotsinspace@dotsinspace ~
╰─➤  cc -v
COLLECT_GCC=cc
Thread model: posix
╰─➤  sudo su startx
[sudo] password for dotsinspace:
su: user startx does not exist or the user entry does not contain all the required fields
╰─➤  sudo su        1 ↵
[root@dotsinspace dotsinspace]# startx
_XSERVTransSocketUNIXCreateListener: mkdir(/tmp/.X11-unix) failed, errno = 0
_XSERVTransMakeAllCOTSServerListeners: failed to create listener for unix
X.Org X Server 1.21.1.3
X Protocol Version 11, Revision 0
Current Operating System: Linux dotsinspace 5.10.93.2-microsoft-standard-WSL2 #1 SMP Wed Jan 26 22:38:54 UTC 2022 x86_64
Kernel command line: initrd=\initrd.img panic=-1 nr_cpus=12 swiotlb=force earlycon=uart8250,io,0x3f8,115200 console=hvc0 debug pty.legacy_count=0
Current version of pixman: 0.40.0
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Sat Feb 26 14:15:39 2022
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
xf86EnableIO: failed to enable I/O ports 0000-03ff (Function not implemented)
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file```
