but I’m not sure what this stub is - I’m expecting to see libnvidia-ml.so or .so.1 in /usr/lib or similar.
If I symlink to this so and run nvtop I see:
# nvtop
WARNING:
You should always run with libnvidia-ml.so that is installed with your
NVIDIA Display Driver. By default it's installed in /usr/lib and /usr/lib64.
libnvidia-ml.so in GDK package is a stub library that is attached only for
build purposes (e.g. machine that you build your application doesn't have
to have Display Driver installed).
Impossible to initialize nvidia nvml :
WARNING:
NVIDIA would have to answer that, I’m not sure what the purpose was. It is a good question, I just don’t know which packages provide what. There is probably a particular package still needed (even if all that package does is add a path to the linker).
Not sure how installed them, and not sure if they do suitable for Jetson Xavier.
