• Hardware Platform (Jetson / GPU) Jetson Orin AGX
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5.2-1+cuda11.4
• Issue Type( questions, new requirements, bugs) Failed to install pre-compiled wheel
**• How to reproduce the issue ? **
I have followed all steps described in this link.
But instead of compiling the bindings I downloaded the available precompiled wheels (https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/releases).
I tried:
pip3 install pyds-1.1.6-py3-none-linux_aarch64.whl
and got the following error:
Processing ./pyds-1.1.6-py3-none-linux_aarch64.whl
Collecting pgi (from pyds==1.1.6)
Using cached pgi-0.0.11.2.tar.gz (239 kB)
Preparing metadata (setup.py) … error
error: subprocess-exited-with-error× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [22 lines of output]
File “”, line 2, in
File “”, line 34, in
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/setup.py”, line 18, in
import pgi
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/pgi/init.py”, line 10, in
from .importer import require_version, get_required_version
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/pgi/importer.py”, line 15, in
from .clib.gir import GIRepository
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/pgi/clib/gir/init.py”, line 9, in
from .gibaseinfo import GIInfoType, GIBaseInfo, GIAttributeIter
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/pgi/clib/gir/gibaseinfo.py”, line 12, in
from .gitypelib import GITypelib
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/pgi/clib/gir/gitypelib.py”, line 16, in
_gir = find_library(“girepository-1.0”)
File “/tmp/pip-install-5i4qqhg8/pgi_15dfafbdd8a64fa0a1bf4bfcb77b04cb/pgi/clib/_utils.py”, line 99, in find_library
_internal[name] = cdll.LoadLibrary(_so_mapping[name])
File “/home/nvidia/miniconda3/envs/torch/lib/python3.8/ctypes/init.py”, line 451, in LoadLibrary
return self._dlltype(name)
File “/home/nvidia/miniconda3/envs/torch/lib/python3.8/ctypes/init.py”, line 373, in init
self._handle = _dlopen(self._name, mode)
OSError: /lib/aarch64-linux-gnu/libgobject-2.0.so.0: undefined symbol: ffi_type_uint32, version LIBFFI_BASE_7.0
[end of output]note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed× Encountered error while generating package metadata.
╰─> See above for output.
