Installing prerequisites: Error in SDK Manager (0.9.12.4180) during Cross Compile Package on Host
I am getting this error
cuda-cross-aarch64-10.0 : Depends cuda-toolkit-10-0 (>= 10.0.326) but 10.0.130-1 is to be installed.
Is there something I should do before running SDK Manager?
Hi frederickkl77n1,
Where did you hit this error? Does it happen when you try to use sdkmanager to install cuda toolkit on tegra?
If you didn’t install the toolkit and flash the board only, would you hit this issue?
Hi frederickkl77n1,
Is this still an issue in your side?
Any result can be shared?
It does not happen when the host is clean (re-installed Ubuntu on the host)
