Installing RTX 3060 on Kubuntu 23.10
Running Kubuntu 23.10 on a Ryzen-9 processor
Followed the instructions on the NVIDIA drivers page to get “NVIDIA-Linux-x86_64-535.146.02.run” and install it.
Followed the instructions on the CUDA pages to get a local “cuda-repo-ubuntu2204-12-3-local_12.3.1-545.23.08-1_amd64.deb” and add this to the package system APT. And then managed to install the “cuda-12.3” package
Then in python3 / Jupyter-Lab I run the following code
import GPUtil
GPUtil.getAvailable()
which throws some errors, the last of which says:
“NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.”
running the command “nvidia-smi” returns the same error
What do I need to do to fix this??
Good day. Try to use this ppa Proprietary GPU Drivers : “Graphics Drivers” team
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update && sudo apt upgrade
Went a different route :-)
used the “standard” NVIDIA-535 driver so that “nvidia-smi” works
This presents the correct information and tells me it wants the CUDA 12.2
So google a lot and work out how to do that
CUDA 12.2 managed to install
Then reinstalled TensorFlow, Keras and other Python bits
Ta-Da! Success
Might be useful when installing CUDA xx.x to include some simple binary to show that this works. Dig into the underlying GPU and give me some facts.
----- Just Saying -----
Depending on how you install cuda, it contains sample binaries like deviceQuery which does exactly that.
