Hardware Platform (Jetson / GPU):
GPU (NVIDIA GeForce RTX 4090)
• DeepStream Version:
7.1
• JetPack Version (valid for Jetson only):
N/A
• TensorRT Version:
10.7.0.23
• NVIDIA GPU Driver Version (valid for GPU only):
565.57.01
• Issue Type:
I am using DeepStream 7.1 and facing an issue with setting up the streammux
configuration. Here’s my setup:
In the [streammux]
section of my config file, I have added the following line:
Steps I Have Taken:
- Added
config-file-path
to the[streammux]
section in the config file. - Set the environment variable
USE_NEW_NVSTREAMMUX
toyes
. - Verified the file path exists and is accessible.
Despite these steps, DeepStream does not process the config-file-path
, and the pipeline fails to use my custom configuration file for streammux
My Questions:
- Is the
config-file-path
key supported in DeepStream 7.1 for the[streammux]
section? - If supported, what could be causing this warning and how can I fix it?
- If not supported, what is the recommended approach to load custom configurations for
streammux
Any guidance or suggestions would be greatly appreciated. Thank you!
[streammux]
config-file-path=/home/jayadevice0001/Jayachandaran_AI/src/deepstream-app/config/streammux_config.txt
gpu-id=0
live-source=1
batch-size=1
batched-push-timeout=100000
sync-inputs=0
width=1920
height=1080
Additionally, I have set the environment variable using the following command before running DeepStream:
export USE_NEW_NVSTREAMMUX=yes
However, when I run the DeepStream application, I receive the following warning:
** WARN: <parse_streammux:821>: Unknown key 'config-file-path' for group [streammux]
