HI @lainA
the following is python code.
#!/usr/bin/env python3
import datetime
import sys
sys.path.append("../")
import os
from deepstream.utils.common import is_aarch64
from deepstream.lib import pyds
from utils.Message import Message
from utils.constants import Constants
import math
import time
import yaml
import gi
gi.require_version("Gst", "1.0")
gi.require_version("GstRtspServer", "1.0")
from gi.repository import Gst, GstRtspServer, GLib
import configparser
from threading import Thread
color_list = {"topsite\r": (0, 0, 1),
"downside\r": (1, 0, 0),
"helmet\r": (0.6, 0.2, 1),
"downiside\r": (1, 0, 0),
"person\r": (0.2, 0.8, 0.2),
"animal\r": (0.2, 0.7, 0.2)}
count_frames = 0
last_time = time.perf_counter()
stopping_flag = False
def bus_call(bus, message, manager):
global stopping_flag
t = message.type
if t == Gst.MessageType.EOS:
print("End-of-stream\n")
stopping_flag = True
manager.loop.quit()
elif t == Gst.MessageType.WARNING:
err, debug = message.parse_warning()
print("Warning: %s: %s\n" % (err, debug))
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print("Error: %s: %s\n" % (err, debug))
manager.loop.quit()
return True
def filesink_out_bin(pipeline, manager, index):
print("creating filesink out bin")
queue = Gst.ElementFactory.make("queue", f"queue_file_{index}")
print("Creating nvvidconv1")
nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", f"convertor1_file_{index}")
if not nvvidconv1:
sys.stderr.write("Error: Unable to create nvvidconv1")
nvv4l2h265enc = Gst.ElementFactory.make("nvv4l2h265enc", f"h265-enc_file_{index}")
# nvv4l2h265enc.set_property("bufapi-version", "true")
h265parse = Gst.ElementFactory.make("h265parse", f"h265-parse_file_{index}")
print(f"saving file at {os.path.join(manager.video_output_dir, f'camera-{index}_video_xx.mp4')}")
file_sink = Gst.ElementFactory.make("splitmuxsink", f"filesink_file_{index}")
file_sink.set_property("location", os.path.join(manager.video_output_dir, f"camera-{index}_video_%d.mp4"))
file_sink.set_property("max-size-time", 1 * 60_000_000_000) # in minutes
pipeline.add(queue)
pipeline.add(nvvidconv1)
pipeline.add(nvv4l2h265enc)
pipeline.add(h265parse)
pipeline.add(file_sink)
queue.link(nvvidconv1)
nvvidconv1.link(nvv4l2h265enc)
nvv4l2h265enc.link(h265parse)
h265parse.link(file_sink)
sinkpad = queue.get_static_pad('sink')
srcpad = queue.get_static_pad('src')
if not sinkpad:
sys.stderr.write(f"Error: Unable to create file sink pad for stream-{index}")
if index > 0:
srcpad.add_probe(Gst.PadProbeType.BUFFER, control_flow_raw_probe, manager)
else:
srcpad.add_probe(Gst.PadProbeType.BUFFER, control_flow_inferred_probe, manager)
return sinkpad
def analytics_probe(pad, info, manager):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame:
balconys = set()
try:
except StopIteration:
break
l_obj = frame_meta.obj_meta_list
while l_obj:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
l_user_meta = obj_meta.obj_user_meta_list
while l_user_meta:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
if user_meta.base_meta.meta_type == pyds.nvds_get_user_meta_type("NVIDIA.DSANALYTICSOBJ.USER_META"):
user_meta_data = pyds.NvDsAnalyticsObjInfo.cast(user_meta.user_meta_data)
if user_meta_data.roiStatus:
for i in user_meta_data.roiStatus:
balconys.add(i)
break
try:
l_user_meta = l_user_meta.next
break
try:
l_obj = l_obj.next
break
display_text = ""
first = True
for balcony in balconys:
if not first:
display_text += "\n"
display_text += f"DANGER! humans in {balcony}"
first = False
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
py_nvosd_text_params.display_text = display_text
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 15
py_nvosd_text_params.font_params.font_color.set(1.0, 0.0, 0.0, 1.0)
py_nvosd_text_params.set_bg_clr = 1
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def model_postprocessing_probe(pad, info, manager):
IOU_factor = 0.6
invalid_confidence_threshold = 0.2
if not gst_buffer:
return
while l_frame:
try:
break
all_balconys = []
while l_obj:
try:
break
if "balcony" in obj_meta.obj_label:
all_balconys.append(obj_meta)
try:
l_obj = l_obj.next
break
all_balconys.sort(key=lambda x: x.confidence, reverse=True)
filtered_balconys = []
for balcony in all_balconys:
dont_add = False
center_of_balcony = (balcony.rect_params.left + balcony.rect_params.width / 2,
balcony.rect_params.top + balcony.rect_params.height / 2)
for filtered_balcony in filtered_balconys:
center_of_filtered = (filtered_balcony.rect_params.left + filtered_balcony.rect_params.width / 2,
filtered_balcony.rect_params.top + filtered_balcony.rect_params.height / 2)
dx = center_of_balcony[0] - center_of_filtered[0]
dy = center_of_balcony[1] - center_of_filtered[1]
if abs(dx) < balcony.rect_params.width * IOU_factor and abs(dy) < balcony.rect_params.height * IOU_factor:
if filtered_balcony.obj_label == "topsite" and balcony.obj_label == "downside":
if filtered_balcony.confidence - balcony.confidence < invalid_confidence_threshold:
filtered_balconys.remove(filtered_balcony)
pyds.nvds_remove_obj_meta_from_frame(frame_meta, filtered_balcony)
filtered_balconys.append(balcony)
break
dont_add = True
break
if dont_add:
# print(f"removing object in frame {frame_meta.frame_num}")
pyds.nvds_remove_obj_meta_from_frame(frame_meta, balcony)
else:
# print(balcony.confidence)
# print(balcony.rect_params.left, balcony.rect_params.top, balcony.rect_params.width, balcony.rect_params.height)
# print("*"*50)
try:
break
def osd_sink_pad_buffer_probe(pad, info, manager):
global count_frames, last_time
if not gst_buffer:
return
while l_frame:
try:
break
# if frame_meta.pad_index == 0:
count_frames += 1
if time.perf_counter() - last_time >= 1:
print(f"FPS: {count_frames / (time.perf_counter() - last_time)}")
count_frames = 0
while l_obj:
try:
break
color = color_list[obj_meta.obj_label.split("\\")[0]]
rect_params = obj_meta.rect_params
rect_params.border_color.set(*color, 1)
try:
l_obj = l_obj.next
break
try:
break
def control_flow_raw_probe(pad, info, manager):
if manager.record_raw_file:
return Gst.PadProbeReturn.DROP
def control_flow_inferred_probe(pad, info, manager):
if manager.record_inferred_file:
def deepstream_listener(manager):
try:
manager.clear_sink_flags_queue()
while True:
if stopping_flag:
break
if not manager.sink_flags_queue_is_empty():
message = manager.get_sink_flags_queue()
print(f"deepstream listener got {message}")
if message.header == Constants.Messages.STOP_DEEPSTREAM or message.header == Constants.Messages.CAMERAS_CONFIG:
manager.pipeline.send_event(Gst.Event.new_eos())
break
else:
print(message.data)
print(type(message.data))
sink_number = int(message.data)
if sink_number == 0:
manager.record_inferred_file = not manager.record_inferred_file
else:
manager.record_raw_file = not manager.record_raw_file
else:
time.sleep(1)
except KeyboardInterrupt:
print("deepstream listener thread ended!!!")
def cb_newpad(decodebin, decoder_src_pad, data):
print("In cb_newpad\n")
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=", gstname)
if gstname.find("video") != -1:
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=", features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write(
"Failed to link decoder src pad to source bin ghost pad\n"
else:
sys.stderr.write(
" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
print("Decodebin child added:", name, "\n")
if name.find("decodebin") != -1:
Object.connect("child-added", decodebin_child_added, user_data)
def create_source_bin(index, uri):
print("Creating source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % index
print(bin_name)
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri", uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(
Gst.GhostPad.new_no_target(
"src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def ds_main(manager):
# Check input arguments
input_sources_file = manager.config_data["input_sources"]
with open(input_sources_file, 'r') as f:
input_sources = yaml.safe_load(f)["input_streams"]
batch_size = len(input_sources)
primary_detector_config = os.path.join(manager.working_directory, manager.config_data['primary_detector'])
tracker_config = os.path.join(manager.working_directory, manager.config_data['tracker_config'])
analytics_config = os.path.join(manager.working_directory, manager.config_data['analytics_config_file'])
# Standard GStreamer initialization
Gst.init(None)
output_dir = os.path.join(manager.program_output_dir, f"{int(datetime.datetime.utcnow().timestamp())}")
os.makedirs(output_dir, exist_ok=True)
manager.video_output_dir = output_dir
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(batch_size):
print("Creating source_bin ", i, " \n ")
uri_name = input_sources[i]
if uri_name.find("rtsp://") == 0:
is_live = True
print("its a live stream!!")
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
tee_pre_mux = Gst.ElementFactory.make("tee", f"tee_pre_mux_{i}")
if not tee_pre_mux:
sys.stderr.write("unable to create tee pre mux")
pipeline.add(tee_pre_mux)
tee_sink_pad = tee_pre_mux.get_static_pad("sink")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(tee_sink_pad)
tee_raw_file_src_pad = tee_pre_mux.get_request_pad("src_0")
filesink_sink_pad = filesink_out_bin(pipeline, manager, i+1)
tee_raw_file_src_pad.link(filesink_sink_pad)
padname = "sink_%u" % i
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
tee_streammux_src_pad = tee_pre_mux.get_request_pad("src_1")
tee_streammux_src_pad.link(sinkpad)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating nvtracker \n ")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
if not tracker:
sys.stderr.write(" Unable to create tracker \n")
print("Creating nvdsanalytics \n ")
nvanalytics = Gst.ElementFactory.make("nvdsanalytics", "analytics")
if not nvanalytics:
manager.logger.info(" Unable to create nvanalytics \n")
print("Creating tiler \n ")
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
if not tiler:
sys.stderr.write(" Unable to create tiler \n")
print("Creating nvvidconv \n ")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
print("Creating nvosd \n ")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
tee_post_osd = Gst.ElementFactory.make("tee", "tee_post_osd")
if not tee_post_osd:
sys.stderr.write("Unable to create tee_post_osd")
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property(
"caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420")
encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
print("Creating H265 Encoder")
if not encoder:
sys.stderr.write(" Unable to create encoder")
encoder.set_property("bitrate", manager.config_data["encoder_bitrate"])
if is_aarch64():
encoder.set_property("preset-level", 1)
encoder.set_property("insert-sps-pps", 1)
#encoder.set_property("bufapi-version", 1)
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# Make the UDP sink
udpsink_port_num = 5400
sink = Gst.ElementFactory.make("udpsink", "udpsink")
if not sink:
sys.stderr.write(" Unable to create udpsink")
streammux.set_property("width", manager.config_data["streammux_width"])
streammux.set_property("height", manager.config_data["streammux_height"])
streammux.set_property("batch-size", batch_size)
streammux.set_property("batched-push-timeout", manager.config_data["streammux_batch_push"])
if is_live:
streammux.set_property('live-source', 1)
pgie.set_property("config-file-path", primary_detector_config)
pgie_batch_size = pgie.get_property("batch-size")
if pgie_batch_size != batch_size:
print(
"WARNING: Overriding infer-config batch-size",
pgie_batch_size,
" with number of sources ",
batch_size,
" \n",
pgie.set_property("batch-size", batch_size)
# Set properties of tracker
config = configparser.ConfigParser()
config.read(tracker_config)
config.sections()
for key in config['tracker']:
if key == 'tracker-width':
tracker_width = config.getint('tracker', key)
tracker.set_property('tracker-width', tracker_width)
if key == 'tracker-height':
tracker_height = config.getint('tracker', key)
tracker.set_property('tracker-height', tracker_height)
if key == 'gpu-id':
tracker_gpu_id = config.getint('tracker', key)
tracker.set_property('gpu_id', tracker_gpu_id)
if key == 'll-lib-file':
tracker_ll_lib_file = config.get('tracker', key)
tracker.set_property('ll-lib-file', tracker_ll_lib_file)
if key == 'll-config-file':
tracker_ll_config_file = config.get('tracker', key)
tracker.set_property('ll-config-file', tracker_ll_config_file)
if key == 'enable-batch-process':
tracker_enable_batch_process = config.getint('tracker', key)
tracker.set_property('enable_batch_process', tracker_enable_batch_process)
if key == 'enable-past-frame':
tracker_enable_past_frame = config.getint('tracker', key)
tracker.set_property('enable_past_frame', tracker_enable_past_frame)
nvanalytics.set_property("config-file", analytics_config)
print("Adding elements to Pipeline \n")
tiler_rows = int(math.sqrt(batch_size))
tiler_columns = int(math.ceil((1.0 * batch_size) / tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", manager.config_data["tiler_width"])
tiler.set_property("height", manager.config_data["tiler_height"])
sink.set_property("host", "224.224.255.255")
sink.set_property("port", udpsink_port_num)
sink.set_property("async", False)
sink.set_property("sync", 1)
sink.set_property("qos", 0)
print(f"******************** UDP out at 224.224.255.255:{udpsink_port_num} ********************")
queue_1 = Gst.ElementFactory.make("queue", "optimization-queue-1")
queue_2 = Gst.ElementFactory.make("queue", "optimization-queue-2")
queue_3 = Gst.ElementFactory.make("queue", "optimization-queue-3")
queue_4 = Gst.ElementFactory.make("queue", "optimization-queue-4")
queue_5 = Gst.ElementFactory.make("queue", "optimization-queue-5")
queue_6 = Gst.ElementFactory.make("queue", "optimization-queue-6")
queue_7 = Gst.ElementFactory.make("queue", "optimization-queue-7")
queue_8 = Gst.ElementFactory.make("queue", "optimization-queue-8")
queue_9 = Gst.ElementFactory.make("queue", "optimization-queue-9")
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(nvanalytics)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(nvvidconv_postosd)
pipeline.add(tee_post_osd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(sink)
pipeline.add(queue_1)
pipeline.add(queue_2)
pipeline.add(queue_3)
pipeline.add(queue_4)
pipeline.add(queue_5)
pipeline.add(queue_6)
pipeline.add(queue_7)
pipeline.add(queue_8)
pipeline.add(queue_9)
streammux.link(queue_1)
queue_1.link(pgie)
pgie.link(queue_2)
queue_2.link(nvvidconv)
# queue_2.link(nvanalytics)
# nvanalytics.link(queue_3)
nvvidconv.link(queue_3)
queue_3.link(tracker)
tracker.link(queue_4)
queue_4.link(tiler)
tiler.link(queue_5)
queue_5.link(nvosd)
nvosd.link(queue_6)
queue_6.link(tee_post_osd)
tee_osd_file_src_pad = tee_post_osd.get_request_pad("src_0")
filesink_osd_sink_pad = filesink_out_bin(pipeline, manager, 0)
tee_osd_file_src_pad.link(filesink_osd_sink_pad)
tee_rtsp_src_pad = tee_post_osd.get_request_pad("src_1")
nvvidcov_postosd_sink_pad = nvvidconv_postosd.get_static_pad("sink")
tee_rtsp_src_pad.link(nvvidcov_postosd_sink_pad)
nvvidconv_postosd.link(caps)
caps.link(queue_7)
queue_7.link(encoder)
encoder.link(queue_8)
queue_8.link(rtppay)
rtppay.link(queue_9)
queue_9.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, manager)
manager.loop = loop
manager.pipeline = pipeline
# Start streaming
rtsp_port_num = 8554
server = GstRtspServer.RTSPServer.new()
server.props.service = "%d" % rtsp_port_num
server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
f'( udpsrc name=pay0 port={udpsink_port_num} buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)H265, payload=96 " )')
factory.set_shared(True)
server.get_mount_points().add_factory(f"/camera-{0}", factory)
print(f"\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:{rtsp_port_num}/camera-{0} ***\n\n")
queue_4_src_pad = queue_4.get_static_pad("src")
if not queue_4_src_pad:
sys.stderr.write(" Unable to get src pad \n")
else:
queue_4_src_pad.add_probe(Gst.PadProbeType.BUFFER, model_postprocessing_probe, manager)
nvanalytics_src_pad = nvanalytics.get_static_pad("src")
if not nvanalytics_src_pad:
else:
nvanalytics_src_pad.add_probe(Gst.PadProbeType.BUFFER, analytics_probe, manager)
osd_sink_pad = nvosd.get_static_pad("sink")
if not osd_sink_pad:
else:
osd_sink_pad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, manager)
t = Thread(target=deepstream_listener, args=(manager,))
t.start()
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except BaseException:
time.sleep(5)
while loop.is_running():
print("waiting for loop to exit")
time.sleep(1)
# cleanup
t.join()
pipeline.set_state(Gst.State.NULL)
message = Message(header=Constants.Messages.DEEPSTREAM_ENDED)
manager.put_message_for_main(message)
