Integrating real-time physics for load simulation of timber/steel trusses in Omniverse
Hey everyone, I’m currently looking at how to leverage NVIDIA’s Omniverse for the roof truss detailing industry. Current CAD/BIM tools do an excellent job of static detailing, however we need to investigate real-time physics to show how the loads will distribute through the roof system, up to structural collapse in complex roofs.
I have some doubts as technical questions for the community.
PhysX and Blast: Has anyone tried leveraging Omniverse PhysX (rigid/deformable body) or NVIDIA Blast (fracture/destruction) to perform structural analysis on wood or light-gauge steel. More specifically I am looking to achieve the breaking point of a truss when it goes from elastic to catastrophic failure.
Metadata accuracy: How are you maintaining high-fidelity metadata like plate thickness, timber grade, nail plate orientation etc., when importing industry-standard IFC/USD files. We are trying to retain this “hidden” data in Omniverse and use it to feed simulation parameters.
Integration of solvers: Can you recommend any specific extension to hook up to an external structural solver (like Ansys or RFEM) back to the Omniverse Viewport in real time.
Thanks for any and all recommendations for work in the AEC world.
You can use Omniverse as a very powerful visualization and interaction layer for truss behavior, but you should not treat PhysX/Blast as a replacement for a structural solver if you care about engineering-grade results.[docs.omniverse.nvidia]
Below I’ll tackle your three questions in turn and then suggest a practical architecture for an AEC/roof‑truss workflow.
1. PhysX / Blast for structural failure
What PhysX is good at
  • Omniverse exposes NVIDIA PhysX 5 for rigid, articulation, soft‑body and deformable simulations inside USD scenes, via Kit simulation extensions.[nvidia-omniverse.github]
  • It’s excellent for interactive load application, contacts, joints, and visualizing “what happens if…” scenarios (e.g., a snow load drifting, a person jumping on a roof section, progressive collapse animations).[youtube][docs.omniverse.nvidia]
Limitations for engineering‑grade truss analysis
  • PhysX is not a general FEM structural solver; its constitutive models and integration schemes are designed for games/real‑time simulation, not code‑checkable stress/strain results or serviceability limits.[nvidia-omniverse.github]
  • You can approximate elastic → plastic → failure behavior with:
    • Per‑member stiffness (springs or articulations)
    • Non‑linear limits (break thresholds on joints/constraints)
    • Simplified damage models or breakable joints
      but you are calibrating against “ground truth” that needs to come from a structural solver or lab tests, not from PhysX itself.[nvidia-omniverse.github]
Where Blast fits
  • NVIDIA Blast is a fracture/demolition framework integrated with Omniverse for breaking meshes, driven by physics events (impacts, stress proxies, etc.).[youtube]
  • It’s ideal for visually convincing fracture/collapse of meshes, but it does not itself compute timber fiber-level behavior, nail‑plate pull‑out, or cold‑formed steel buckling in a way that you can sign off as structural analysis.[youtube]
Practical pattern for trusses
  • Use a proper solver (Ansys, RFEM, etc.) to compute:
    • Member forces and utilization
    • Failure sequence (which member/connection fails and at what load)
    • Residual capacity and progressive collapse.
  • Map those results to Omniverse:
    • Encode utilization as per‑member attributes (e.g. 0–1) and drive color, deformation, and break triggers via PhysX and Blast.
    • Trigger Blast fracture on a member when its utilization attribute from the external solver crosses 1.0 (or another limit state).
  • Result: You get a believable elastic–plastic–collapse visualization that is driven by a validated solver but rendered with PhysX/Blast in real time.[ansys][youtube]
2. Keeping high‑fidelity metadata (timber grade, plate thickness, orientation)
USD/IFC as the data backbone
  • Omniverse is built around OpenUSD; arbitrary “primvars” and custom attributes can be attached to any prim (mesh, Xform, etc.).[youtube][docs.omniverse.nvidia]
  • IFC‑to‑USD connectors can preserve IFC properties as USD attributes if you map them properly (e.g. IFC property sets ⇒ USD custom attributes on the corresponding truss/plate prims).[goto]
How to store your structural metadata
Typical pattern inside USD:
  • On the truss member prim (e.g. RoofTruss/Chord_Top_01):
    • struct:timberGrade = "MGP10"
    • struct:sectionDepth = 90.0 (mm)
    • struct:sectionWidth = 35.0
    • struct:E_longitudinal = 8.5e9
  • On the nail plate prim:
    • struct:plateThickness = 1.0 (mm)
    • struct:plateSteelGrade = "G300"
    • struct:toothPatternId = "NP-XYZ-12x8"
    • struct:orientationLocal = [0, 0, 1] (normal vector)
USD and Omniverse support creation of such attributes directly; they simply show up under the raw USD properties panel and can be accessed by extensions and materials.[docs.omniverse.nvidia][youtube]
Using metadata for simulation parameters
  • Omniverse extensions (Python/Kit) can read those attributes at runtime and:
    • Build PhysX bodies with matching densities, stiffness, or joint properties.
    • Pass them to an external solver via gRPC/REST (e.g. section properties and material model selection).
  • The “Attributes Brush” and MDL examples show the idiom: define a prim attribute (e.g. struct:utilization), then use a lookup node in a material/extension to drive behavior (color, opacity, or physics). The same pattern applies to your timber grade, plate thickness, etc.[docs.omniverse.nvidia][youtube]
Key takeaway: treat IFC/USD purely as the authoritative geometry + metadata container, and define a clear schema (struct:*) that your truss detailing system, Omniverse extensions, and external solver all understand.[aecmag]
3. Hooking external solvers (Ansys, RFEM) into the Omniverse viewport
Ansys examples
  • Ansys has already started adopting Omniverse APIs for visualizing solver results (HFSS, Icepak, RedHawk‑SC, Fluent, AVxcelerate Sensors) in real time, using Omniverse as the 3D visualization layer.[youtube][engineering]
  • For EnSight specifically, there’s a documented integration:
    • Enable “Ansys Omniverse Geometry Service GUI” in an Omniverse app.
    • Connect to EnSight via gRPC from the Omniverse UI (matching port numbers).
    • Pull updated simulation results into Omniverse, and request updates to re‑sync as the solver runs or results change.[youtube]
This pattern is exactly what you want: the solver runs on its own, Omniverse subscribes to results and updates the viewport.
General integration pattern (works for RFEM and others)
Even if RFEM (or your chosen structural package) doesn’t ship a ready‑made Omniverse connector, you can follow the same architecture used by Ansys:
  1. Define a USD schema for results
  • E.g. per member:
    • struct:axialForce
    • struct:bendingMy, struct:bendingMz
    • struct:utilizationULS
    • struct:utilizationSLS
  • Optionally, define a prim for global load steps or time increments.
  1. Build a small server around the solver
  • RFEM/Ansys/other solver exports per‑member results (via API, COM, or file).
  • A lightweight service converts them into a USD layer or a stream of attribute updates (e.g. via gRPC, WebSocket, or file‑based USD overlays).
  1. Omniverse extension as the bridge
  • Omniverse Kit extension connects to that service (similar to the Ansys EnSight geometry service).[ansys][youtube]
  • On new data:
    • It applies attribute updates on the corresponding USD prims.
    • Optionally, it deforms geometry for displacements (overlay mesh or scale/offset).
    • It updates PhysX parameters or triggers Blast fracture when utilization exceeds thresholds.
  1. Real‑time or near‑real‑time loop
  • For static solvers: loop through load factors and push updates as a sequence for “animated” collapse.
  • For non‑linear progressive collapse: solver steps load, recomputes stiffness, pushes back updated member states; Omniverse animates and optionally uses Blast for visual destruction at key events.
Why follow the Ansys pattern
  • It’s officially supported: Ansys is using Omniverse APIs and Kit App Streaming for advanced simulation visualization, and the same mechanisms are open to you.[engineering]
  • It keeps numerical heavy lifting in tools that are validated for structural work, while Omniverse excels at multi‑user, physically plausible, ray‑traced visualization.[goto]
4. Suggested architecture for roof‑truss workflows
Putting it together for your timber/light‑gauge roof trusses:
  • Authoring / detailing
    • Continue to author trusses in your CAD/BIM tool and export IFC with rich property sets.[aecmag]
    • Use an IFC→USD pipeline that preserves those properties as USD attributes (or add an intermediate step that maps IFC Psets to struct:* attributes on USD prims).
  • Metadata discipline
    • Define a clear, documented tag schema for:
      • Member ID, type (top chord, web, bottom chord)
      • Section geometry
      • Timber grade/steel grade
      • Connection type (nail plate, screw pattern)
    • Ensure every plate and member prim in USD has a stable ID that the solver also uses.
  • External solver loop
    • Map each USD member ID to an element/member in your solver model (Ansys, RFEM, etc.).
    • Solver computes forces/stresses/utilization and optionally the failure sequence.
    • A bridge service exports results as:
      • A USD overlay file per load factor, or
      • A gRPC/WebSocket stream of {memberId, propertyName, value} updates.
  • Omniverse viewport behavior
    • A custom Omniverse extension:
      • Subscribes to solver updates.
      • Writes per‑member attributes like struct:utilizationULS, struct:displacement, struct:failed.
      • Drives:
        • Material colors (e.g., green→yellow→red based on utilization) using MDL + attribute lookup.[youtube][docs.omniverse.nvidia]
        • Deformation (scaled displacements) using either geometry offsets or a deformed mesh overlay.
        • PhysX/Blast transitions: when struct:failed == true, detach that member, apply gravity, and optionally fracture the mesh to show catastrophic failure.[docs.omniverse.nvidia][youtube]
  • What Omniverse adds beyond your existing tools
    • Multi‑user review of collapse scenarios in real time.[goto]
    • VR/AR exploration of “what fails when” for complex roofs.
    • A unified platform where CAD/BIM, simulation metadata, and visualization stay in sync.
5. Concrete answers to your original bullets
  • PhysX / Blast for truss failure
    • Use them for interactive, visually compelling failure and collapse animations, but calibrate them to external solver results; they are not a substitute for structural analysis.[nvidia-omniverse.github][youtube]
  • Metadata accuracy (plate thickness, timber grade, etc.)
    • Preserve IFC properties as USD attributes on each prim, using a consistent schema (struct:*), and access them from Omniverse extensions and MDL graphs.[youtube][aecmag]
  • Integration of solvers
    • Follow the Ansys EnSight → Omniverse model: run the solver separately, exchange data via gRPC or USD overlays, and let an Omniverse extension pull updates to drive the viewport in real time. This pattern is already being used commercially for multi‑physics visualization.[engineering][youtube][ansys]
Would your ideal workflow lean more toward “explaining collapse to non‑engineers visually” or toward “helping engineers perform and iterate actual design checks”? Your emphasis there will change how much effort you should put into solver accuracy vs. real‑time responsiveness.
