In jetpack 5, we were able to get the Intel E810 networking card running successfully by doing the following in the corresponding PCIE device tree node:
And by changing define GIC_SPI_MSI_SIZE (defined in tegra-t23x-agic.h) to 252
What to do to get it running on jetpack 6? define GIC_SPI_MSI_SIZE and the corresponding file “tegra-t23x-agic.h” do not exist anymore. Also the device tree node for interrupt-controller@f400000 does look very different…
Could you elaborate more about what did you remove on jeptack5? I don’t really think what you told is correct.
/delete-property/ status;
/delete-property/ iommus;
/delete-property/ dma-coherent;
Delete status means PCIe controller is totally not enabled. Thus, I don’t think what you told is correct… or you are actually not doing this on “PCIe device tree”.
