Integration of Kafka with a DeepStream Python Pipeline for Multiple Input and Output Sources and Cropping Image
• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.2.3.
• NVIDIA GPU Driver Version (valid for GPU only): 525.147.05.
• Issue Type( questions, new requirements, bugs): questions.
I am currently using DeepStream Python to develop a pipeline for multiple input sources and multiple RTSP output sources, and I have completed this setup. Now, I want to integrate Kafka using msgconv and msgbroker . How should I design the pipeline considering that after the demux , each input source will have a separate branch? Where should I place msgconv and msgbroker - in each branch or elsewhere? Also, if I want to extract images from the buffer for object cropping, at which element should I place the probe? I tried it at sgie , but it reported an error, only supporting the RGBA format? Thank you in advance.
please refer to this topic.
