New important update:
I was able to fix it with sudo prime-select nvidia
Smoothness is back and 75Hz monitors work as if they had that much
The card was detected and the display system changed to X11
Output
dgrabowski@dgrabowski:~$ grep -r nvidia /lib/modprobe.d/ /etc/modprobe.d/
/lib/modprobe.d/nvidia-kms.conf:# This file was generated by nvidia-prime
/lib/modprobe.d/nvidia-kms.conf:options nvidia-drm modeset=1
/etc/modprobe.d/blacklist-framebuffer.conf:blacklist nvidiafb
dgrabowski@dgrabowski:~$ grep -r nvidia /lib/udev/rules.d /etc/udev/rules.d/
/lib/udev/rules.d/71-u-d-c-gpu-detection.rules:ACTION=="add", SUBSYSTEMS=="pci", DRIVERS=="nvidia", RUN+="/bin/touch /run/u-d-c-nvidia-was-loaded"
/lib/udev/rules.d/71-u-d-c-gpu-detection.rules:ACTION=="add", SUBSYSTEM=="module", KERNEL=="nvidia_drm", RUN+="/bin/touch /run/u-d-c-nvidia-drm-was-loaded"
/lib/udev/rules.d/71-nvidia.rules:SUBSYSTEM=="pci", ATTRS{vendor}=="0x10de", DRIVERS=="nvidia", TAG+="seat", TAG+="master-of-seat"
/lib/udev/rules.d/71-nvidia.rules:# Start and stop nvidia-persistenced on power on and power off
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", DEVPATH=="/bus/pci/drivers/nvidia", TAG+="systemd", ENV{SYSTEMD_WANTS}="nvidia-persistenced.service"
/lib/udev/rules.d/71-nvidia.rules:# Load and unload nvidia-modeset module
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/modprobe nvidia-modeset"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="remove", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/modprobe -r nvidia-modeset"
/lib/udev/rules.d/71-nvidia.rules:# Load and unload nvidia-drm module
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/modprobe nvidia-drm"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="remove", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/modprobe -r nvidia-drm"
/lib/udev/rules.d/71-nvidia.rules:# Load and unload nvidia-uvm module
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/modprobe nvidia-uvm"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="remove", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/modprobe -r nvidia-uvm"
/lib/udev/rules.d/71-nvidia.rules:# This will create the device nvidia device nodes
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", DEVPATH=="/bus/pci/drivers/nvidia", RUN+="/sbin/ub-device-create"
/lib/udev/rules.d/71-nvidia.rules:# Create the device node for the nvidia-uvm module
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", DEVPATH=="/module/nvidia_uvm", SUBSYSTEM=="module", RUN+="/sbin/ub-device-create"
/lib/udev/rules.d/61-gdm.rules:# disable Wayland when using the proprietary nvidia driver
/lib/udev/rules.d/61-gdm.rules:DRIVER=="nvidia", RUN+="/usr/lib/gdm3/gdm-disable-wayland"
dgrabowski@dgrabowski:~$ grep -r 10de /lib/udev/rules.d /etc/udev/rules.d/
/lib/udev/rules.d/71-nvidia.rules:ACTION=="bind", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x03[0-9]*", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x040300", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c0330", TEST=="power/control", ATTR{power/control}="auto"
/lib/udev/rules.d/71-nvidia.rules:ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x10de", ATTR{class}=="0x0c8000", TEST=="power/control", ATTR{power/control}="auto"
dgrabowski@dgrabowski:~$ modprobe -vvv nvidia
modprobe: INFO: ../libkmod/libkmod.c:365 kmod_set_log_fn() custom logging function 0x5589d5246c70 registered
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/6.2.16-060216-generic/modules.dep.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/6.2.16-060216-generic/modules.alias.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/6.2.16-060216-generic/modules.symbols.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/6.2.16-060216-generic/modules.builtin.alias.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/6.2.16-060216-generic/modules.builtin.bin
modprobe: DEBUG: ../libkmod/libkmod-module.c:556 kmod_module_new_from_lookup() input alias=nvidia, normalized=nvidia
modprobe: DEBUG: ../libkmod/libkmod-module.c:562 kmod_module_new_from_lookup() lookup modules.dep nvidia
modprobe: DEBUG: ../libkmod/libkmod.c:598 kmod_search_moddep() use mmaped index 'modules.dep' modname=nvidia
modprobe: DEBUG: ../libkmod/libkmod.c:403 kmod_pool_get_module() get module name='nvidia' found=(nil)
modprobe: DEBUG: ../libkmod/libkmod.c:411 kmod_pool_add_module() add 0x5589d58db5f0 key='nvidia'
modprobe: DEBUG: ../libkmod/libkmod.c:403 kmod_pool_get_module() get module name='drm' found=(nil)
modprobe: DEBUG: ../libkmod/libkmod.c:411 kmod_pool_add_module() add 0x5589d58db670 key='drm'
modprobe: DEBUG: ../libkmod/libkmod-module.c:196 kmod_module_parse_depline() add dep: /lib/modules/6.2.16-060216-generic/kernel/drivers/gpu/drm/drm.ko
modprobe: DEBUG: ../libkmod/libkmod-module.c:202 kmod_module_parse_depline() 1 dependencies for nvidia
modprobe: DEBUG: ../libkmod/libkmod-module.c:589 kmod_module_new_from_lookup() lookup nvidia=0, list=0x5589d58db160
modprobe: DEBUG: ../libkmod/libkmod.c:500 lookup_builtin_file() use mmaped index 'modules.builtin' modname=nvidia
modprobe: DEBUG: ../libkmod/libkmod-module.c:468 kmod_module_unref() kmod_module 0x5589d58db5f0 released
modprobe: DEBUG: ../libkmod/libkmod.c:419 kmod_pool_del_module() del 0x5589d58db5f0 key='nvidia'
modprobe: DEBUG: ../libkmod/libkmod-module.c:468 kmod_module_unref() kmod_module 0x5589d58db670 released
modprobe: DEBUG: ../libkmod/libkmod.c:419 kmod_pool_del_module() del 0x5589d58db670 key='drm'
modprobe: INFO: ../libkmod/libkmod.c:332 kmod_unref() context 0x5589d58da600 released
New log:
nvidia-bug-report.log (2.4 MB)
