I connected Intel 8265NGW card without any antenna to Jetson Nano. Device is showing Bluetooth Not Found. Wifi its showing list of available networks, but bluetooth seems not to work.
Output from bluetoothctl is no default device found
Console Log :
tuna@tuna-desktop:~$ uname -a
Linux tuna-desktop 4.9.140-tegra #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
tuna@tuna-desktop:~$ sudo dmesg | egrep -i ‘blue|firm’
[sudo] password for tuna:
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.611691] Bluetooth: Core ver 2.22
[ 0.611775] Bluetooth: HCI device and connection manager initialized
[ 0.611803] Bluetooth: HCI socket layer initialized
[ 0.611824] Bluetooth: L2CAP socket layer initialized
[ 0.611860] Bluetooth: SCO socket layer initialized
[ 3.249708] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.508395] Bluetooth: RFCOMM socket layer initialized
[ 3.508404] Bluetooth: RFCOMM ver 1.11
[ 3.508408] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.508412] Bluetooth: HIDP socket layer initialized
[ 7.171255] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 second
[ 7.411950] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 8.185240] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 8.467280] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 8.808315] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 9.012352] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 9.303599] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 9.429702] Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
[ 9.430736] Bluetooth: hci0: Device revision is 16
[ 9.430740] Bluetooth: hci0: Secure boot is enabled
[ 9.430742] Bluetooth: hci0: OTP lock is enabled
[ 9.430744] Bluetooth: hci0: API lock is enabled
[ 9.430746] Bluetooth: hci0: Debug lock is disabled
[ 9.430748] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 9.570864] Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
[ 9.604978] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.604988] Bluetooth: BNEP socket layer initialized
[ 11.102432] Bluetooth: hci0: Waiting for firmware download to complete
[ 11.102703] Bluetooth: hci0: Firmware loaded in 1638122 usecs
[ 11.102818] Bluetooth: hci0: Waiting for device to boot
[ 11.114677] Bluetooth: hci0: Device booted in 11618 usecs
[ 11.144010] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
[ 11.146691] Bluetooth: hci0: Applying Intel DDC parameters completed
tuna@tuna-desktop:~$ sudo rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
tuna@tuna-desktop:~$ sudo lsmod
Module Size Used by
fuse 103841 5
bnep 16562 2
iwlmvm 368205 0
mac80211 719792 1 iwlmvm
btusb 40149 0
btrtl 7318 1 btusb
btbcm 8808 1 btusb
btintel 10771 1 btusb
overlay 48691 0
iwlwifi 167043 1 iwlmvm
nvs 54527 0
cfg80211 589351 3 iwlmvm,iwlwifi,mac80211
nvgpu 1555053 21
bluedroid_pm 13912 0
ip_tables 19441 0
x_tables 28951 1 ip_tables
tuna@tuna-desktop:~$ sudo lspci -vv
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 84
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 13000000-130fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2+ ASPM_L1.1+
T_CommonMode=30us LTR1.2_Threshold=98304ns
L1SubCtl2: T_PwrOn=70us
Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 13100000-131fffff
ExtTag+ RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=150us LTR1.2_Threshold=294912ns
L1SubCtl2: T_PwrOn=150us
01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
Subsystem: Intel Corporation Dual Band Wireless-AC 8265
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 406
Region 0: Memory at 13000000 (64-bit, non-prefetchable)
Capabilities: [c8] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fa83e000 Data: 0001
Capabilities: [40] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L1, Exit Latency L0s <4us, L1 <8us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via WAKE#
DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis-, LTR+, OBFF Disabled
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number 0c-54-15-ff-ff-8d-88-b7
Capabilities: [14c v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [154 v1] L1 PM Substates
PortCommonModeRestoreTime=30us PortTPowerOnTime=18us
T_CommonMode=0us LTR1.2_Threshold=98304ns
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 404
Region 0: I/O ports at 1000
Region 2: Memory at 13104000 (64-bit, non-prefetchable)
Region 4: Memory at 13100000 (64-bit, non-prefetchable)
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fa83e000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 01
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 4096 bytes
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via message/WAKE#
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Vector table: BAR=4 offset=00000000
PBA: BAR=4 offset=00000800
Capabilities: [100 v2] Advanced Error Reporting
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [160 v1] Device Serial Number 01-00-00-00-68-4c-e0-00
Capabilities: [170 v1] Latency Tolerance Reporting
Capabilities: [178 v1] L1 PM Substates
PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
T_CommonMode=0us LTR1.2_Threshold=294912ns
Kernel driver in use: r8168
tuna@tuna-desktop:~$ lspci
tuna@tuna-desktop:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.137.111 netmask 255.255.255.0 broadcast 192.168.137.255
inet6 fe80::9c01:9d25:6839:3518 prefixlen 64 scopeid 0x20
ether 00:e0:4c:68:00:01 txqueuelen 1000 (Ethernet)
RX packets 46792 bytes 2981702 (2.9 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 85798 bytes 288291269 (288.2 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 148 base 0xe000
l4tbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.55.1 netmask 255.255.255.0 broadcast 192.168.55.255
inet6 fe80::4cb0:71ff:fee3:5fdb prefixlen 64 scopeid 0x20
inet6 fe80::1 prefixlen 128 scopeid 0x20
ether d6:5e:d2:0b:e2:79 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 9 bytes 1419 (1.4 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 2172 bytes 144013 (144.0 KB)
TX packets 2172 bytes 144013 (144.0 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
TX packets 0 bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether d6:5e:d2:0b:e2:7b txqueuelen 1000 (Ethernet)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 0c:54:15:8d:88:b7 txqueuelen 1000 (Ethernet)
Pls try with antenna attached.
Okay i have ordered an antenna, should get it within two days.
But isn’t antenna used only for getting bluetooth devices or increasing range? Why does not having antenna cause Bluetooth not found error. Any ideas?
After trying with sudo bluetoothctl, device got successfully registered and i am able to connect to bluetooth devices through terminal.
But even after that, Settings tab shows Bluetooth not found connect usb dongle. Any idea on why this happens!
