On Nano with a intel 8265ngw wireless card on the M2 connector, Nano has serious problems. The connection is unstable, hangs and makes the platform impossible to use. There are a lot of errors in the dmesg log. Has anyone encountered this problem and knows a way to solve it?
Kernel: 4.9.140-tegra
Nvidia release: R32.2.1
[code]
Welcome to Ubuntu 18.04.3 LTS (GNU/Linux 4.9.140-tegra aarch64)
root@nano:~# dmesg
[ 0.512300] vdd-ac-bat: 5000 mV
[ 0.512650] vdd-5v0-sys: 5000 mV
[ 0.513654] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.513695] vdd-5v0-hdmi: 5000 mV
[ 0.514111] vdd-1v8-sys: 1800 mV
[ 0.514557] vdd-fan: supplied by vdd-5v0-sys
[ 0.514594] vdd-fan: 5000 mV
[ 0.514971] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.515004] vdd-usb-vbus: 5000 mV
[ 0.515507] vdd-usb-vbus2: 5000 mV
[ 0.546141] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.548715] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.551318] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.551338] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.551745] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.559744] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.560099] SCSI subsystem initialized
[ 0.560397] libata version 3.00 loaded.
[ 0.560706] usbcore: registered new interface driver usbfs
[ 0.560757] usbcore: registered new interface driver hub
[ 0.560831] usbcore: registered new device driver usb
[ 0.564619] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.569234] vdd-core: 600 <–> 1162 mV at 1125 mV
[ 0.570016] random: fast init done
[ 0.570113] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.573003] vdd-ddr-1v1: 1150 mV
[ 0.576240] vdd-pre-reg-1v35: 1350 mV
[ 0.580308] vdd-1v8: 1800 mV
[ 0.584236] avdd-sys-1v2: 1200 mV
[ 0.588233] vdd-pex-1v0: 1050 mV
[ 0.588803] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.589343] max77620-ldo3: at 3100 mV
[ 0.592238] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.592726] max77620-ldo5: at 3100 mV
[ 0.593222] max77620-ldo6: at 2800 mV
[ 0.596231] avdd-1v05-pll: 1050 mV
[ 0.600237] avdd-io-hdmi-dp: 1050 mV
[ 0.601368] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.601679] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.603036] max77620 4-003c: max77620 probe successful
[ 0.605883] media: Linux media interface: v0.10
[ 0.605943] Linux video capture interface: v2.00
[ 0.606855] pps_core: LinuxPPS API ver. 1 registered
[ 0.606859] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.606878] PTP clock support registered
[ 0.610604] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.617038] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.617890] Advanced Linux Sound Architecture Driver Initialized.
[ 0.618535] Bluetooth: Core ver 2.22
[ 0.618586] NET: Registered protocol family 31
[ 0.618591] Bluetooth: HCI device and connection manager initialized
[ 0.618604] Bluetooth: HCI socket layer initialized
[ 0.618613] Bluetooth: L2CAP socket layer initialized
[ 0.618666] Bluetooth: SCO socket layer initialized
[ 0.620284] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.620299] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.620341] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.620354] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.623656] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.624841] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.624910] vdd-3v3-sys: 3300 mV
[ 0.625238] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.629081] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.629584] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.629629] vdd-3v3-sd: 3300 mV
[ 0.630461] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.630509] avdd-io-edp-1v05: 1050 mV
[ 0.631036] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.631082] vdd-usb-hub-en: 5000 mV
[ 0.632587] camchar: rtcpu character device driver loaded
[ 0.633381] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.634770] clocksource: Switched to clocksource arch_sys_counter
[ 0.675167] VFS: Disk quotas dquot_6.6.0
[ 0.675293] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.675797] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676224] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.676242] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.676439] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.676445] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.676455] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.676479] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.676484] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.676497] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.676506] nvmap_page_pool_init: Total RAM pages: 1009326
[ 0.676511] nvmap_page_pool_init: nvmap page pool size: 126165 pages (492 MB)
[ 0.676599] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.677107] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.678165] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.686412] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.686883] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.687129] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.687332] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.687520] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.687800] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.687804] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.688249] NET: Registered protocol family 2
[ 0.689222] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.689433] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.689950] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.690100] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.690190] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.690596] NET: Registered protocol family 1
[ 0.691377] RPC: Registered named UNIX socket transport module.
[ 0.691383] RPC: Registered udp transport module.
[ 0.691387] RPC: Registered tcp transport module.
[ 0.691391] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.691403] PCI: CLS 0 bytes, default 64
[ 0.691639] Trying to unpack rootfs image as initramfs…
[ 0.928194] Freeing initrd memory: 5432K
[ 0.938217] host1x 50000000.host1x: initialized
[ 0.940148] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.943521] audit: initializing netlink subsys (disabled)
[ 0.943617] audit: type=2000 audit(0.791:1): initialized
[ 0.944368] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.954480] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.956025] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.956831] 9p: Installing v9fs 9p2000 file system support
[ 0.960195] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.960361] io scheduler noop registered
[ 0.960659] io scheduler cfq registered (default)
[ 0.963490] gic 702f9000.agic: GIC IRQ controller registered
[ 0.966435] iommu: Adding device 702ef000.adsp to group 33
[ 0.973617] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.973831] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.974428] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x7a0940f
[ 0.974435] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.976152] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.976245] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.976345] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.976546] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.976640] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.976732] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.976813] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.976900] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.976981] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.977067] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.982387] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.984182] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.986067] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.987343] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.987710] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.988968] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.989200] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.989442] Adding domain tsec-pd to PM domain host1x-pd
[ 0.991697] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.992668] tsec 54500000.tsec: initialized
[ 0.994263] tsec 54100000.tsecb: initialized
[ 0.995030] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.998630] nvdec 54480000.nvdec: initialized
[ 0.999716] Adding domain vic03-pd to PM domain host1x-pd
[ 0.999891] Adding domain msenc-pd to PM domain host1x-pd
[ 1.000051] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.004060] falcon 54340000.vic: initialized
[ 1.005245] falcon 544c0000.nvenc: initialized
[ 1.006604] falcon 54380000.nvjpg: initialized
[ 1.011272] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.011402] display board info: id 0x0, fab 0x0
[ 1.011466] generic_infoframe_type: 0x87
[ 1.011600] tegradc tegradc.0: DT parsed successfully
[ 1.011657] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.012184] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.015582] tegradc tegradc.0: probed
[ 1.019547] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.024245] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.025166] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.025505] kfuse 7000fc00.kfuse: initialized
[ 1.027222] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.028201] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.029749] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.029764] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 1.030358] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.031604] vdd-gpu: applied init 1000000uV constraint
[ 1.031612] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 1.032008] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.034221] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.034240] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.034247] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.034254] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.034262] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.034324] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.034491] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.034860] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.034958] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.035188] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.035201] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.035413] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[ 1.035469] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 1.035725] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 1.040762] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.040908] No Device Node present for smmu client: serial8250 !!
[ 1.040922] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.040982] iommu: Adding device serial8250 to group 35
[ 1.043810] console [ttyS0] disabled
[ 1.043895] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.043996] console [ttyS0] enabled
[ 1.044943] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.045220] serial-tegra 70006200.serial: RX in PIO mode
[ 1.045309] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.046269] [drm] Initialized
[ 1.046986] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.047283] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.047322] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.047360] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.047384] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.047573] pci 0000:02:00.0: supports D1 D2
[ 1.047577] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.048067] Console: switching to colour frame buffer device 240x67
[ 1.048201] tegradc tegradc.0: fb registered
[ 1.057296] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.057346] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.057684] brd: module loaded
[ 1.057847] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.057858] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.058943] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.059048] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.059058] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 1.059065] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.059079] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
[ 1.059108] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.059118] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.059131] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 1.059152] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 1.059171] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.059180] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.059185] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.059193] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 1.059809] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.059815] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.059824] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.059956] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 1.060182] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.060187] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.060193] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.060300] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 1.065137] loop: module loaded
[ 1.065245] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.065370] tegra_profiler: auth: init
[ 1.066727] THERMAL EST: found 2 subdevs
[ 1.066736] THERMAL EST num_resources: 0
[ 1.066741] [THERMAL EST subdev 0]
[ 1.066790] [THERMAL EST subdev 1]
[ 1.067291] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.067295] THERMAL EST: thz register success.
[ 1.067456] THERMAL EST: end of probe, return err: 0
[ 1.068734] hisi_sas: driver version v1.6
[ 1.073364] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.074681] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.074693] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.078046] libphy: Fixed MDIO Bus: probed
[ 1.078669] tun: Universal TUN/TAP device driver, 1.6
[ 1.078673] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.079805] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 1.079812] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 1.079875] igb: Intel® Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.079879] igb: Copyright © 2007-2014 Intel Corporation.
[ 1.079935] igbvf: Intel® Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.079938] igbvf: Copyright © 2009 - 2012 Intel Corporation.
[ 1.079991] Intel® 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.079995] Copyright© 1999 - 2017 Intel Corporation.
[ 1.080967] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.080997] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.083854] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.083861] Extcon AUX1(HDMI) enable
[ 1.084845] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.084921] tegradc tegradc.1: No lt-data, using default setting
[ 1.084953] tegradc tegradc.1: No hpd-gpio in DT
[ 1.084985] tegradc tegradc.1: DT parsed successfully
[ 1.085047] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.086470] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.096340] tegradc tegradc.1: probed
[ 1.099445] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.099820] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e4:14:9b from device tree
[ 1.100922] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.101047] r8168 Copyright © 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 1.102480] PPP generic driver version 2.4.2
[ 1.118457] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.119152] PPP BSD Compression module registered
[ 1.119159] PPP Deflate Compression module registered
[ 1.119209] PPP MPPE Compression module registered
[ 1.119218] NET: Registered protocol family 24
[ 1.119336] usbcore: registered new interface driver r8152
[ 1.119481] usbcore: registered new interface driver asix
[ 1.119633] usbcore: registered new interface driver ax88179_178a
[ 1.119724] usbcore: registered new interface driver cdc_ether
[ 1.119816] usbcore: registered new interface driver net1080
[ 1.119905] usbcore: registered new interface driver cdc_subset
[ 1.119960] usbcore: registered new interface driver zaurus
[ 1.120022] usbcore: registered new interface driver cdc_ncm
[ 1.120317] VFIO - User Level meta-driver version: 0.3
[ 1.121918] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.121948] ehci-pci: EHCI PCI platform driver
[ 1.121998] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.122010] ohci-pci: OHCI PCI platform driver
[ 1.122049] ohci-platform: OHCI generic platform driver
[ 1.125197] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.125486] tegradc tegradc.1: fb registered
[ 1.125835] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.127028] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9100c00 id
[ 1.129359] usbcore: registered new interface driver uas
[ 1.129429] usbcore: registered new interface driver usb-storage
[ 1.129566] usbcore: registered new interface driver usbserial
[ 1.129889] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.129964] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.129992] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.130431] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.130438] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.130448] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.130464] tegradc tegradc.1: blank - powerdown
[ 1.130488] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.130492] Extcon DP: HPD disabled
[ 1.130497] hpd: hpd_switch 0
[ 1.130501] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.130509] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.130516] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.130964] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.131028] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.131240] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.131247] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.131253] usb usb1: Product: xHCI Host Controller
[ 1.131257] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.131261] usb usb1: SerialNumber: 70090000.xusb
[ 1.131905] hub 1-0:1.0: USB hub found
[ 1.131950] hub 1-0:1.0: 5 ports detected
[ 1.132649] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.132664] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.132745] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.132838] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.132844] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.132849] usb usb2: Product: xHCI Host Controller
[ 1.132855] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.132859] usb usb2: SerialNumber: 70090000.xusb
[ 1.133338] hub 2-0:1.0: USB hub found
[ 1.133375] hub 2-0:1.0: 4 ports detected
[ 1.134359] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.135777] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.135793] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.135829] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.136090] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.136793] mousedev: PS/2 mouse device common for all mice
[ 1.136910] usbcore: registered new interface driver xpad
[ 1.218344] tegradc tegradc.0: blank - powerdown
[ 1.241222] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.241283] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 1.257520] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.257524] Extcon AUX1(HDMI) disable
[ 1.267178] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.269687] rtc rtc1: alarm rtc device
[ 1.269708] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.269740] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.270395] i2c /dev entries driver
[ 1.272518] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.289168] tegradc tegradc.0: unblank
[ 1.295831] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.295903] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.295934] imx219 6-0010: board setup failed
[ 1.296051] imx219: probe of 6-0010 failed with error -121
[ 1.297391] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.300348] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.300353] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.300811] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.300828] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.300837] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.300974] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.300984] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.300991] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.301146] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.301156] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.301160] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.301337] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.302191] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.302247] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.302274] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.302292] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.302300] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.303436] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.303456] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 1.303660] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.303691] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 1.304182] parse_throttle_dt_data: Num cap clks = 6
[ 1.304188] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.304203] parse_throttle_dt_data: clk=gpu type=4
[ 1.304233] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.304259] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.304288] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.304291] parse_throttle_dt_data: clk=emc type=3
[ 1.304668] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.304778] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.304924] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.305808] FAN dev name: pwm-fan
[ 1.305862] FAN:gpio request success.
[ 1.305935] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.306270] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.306491] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.306500] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.306586] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.306591] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.306595] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.306599] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.306603] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.306607] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.306611] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.306615] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.306620] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.306623] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.307329] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.307673] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.308562] device-mapper: uevent: version 1.0.3
[ 1.309100] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.314386] tegra210-cpufreq cpufreq: probe()…completed
[ 1.315201] sdhci: Secure Digital Host Controller Interface driver
[ 1.315202] sdhci: Copyright© Pierre Ossman
[ 1.315204] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.315690] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.316047] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.316170] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.320704] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.321241] hidraw: raw HID events driver © Jiri Kosina
[ 1.322346] usbcore: registered new interface driver usbhid
[ 1.322348] usbhid: USB HID core driver
[ 1.324643] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 1.324815] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.326500] nvpmodel: initialized successfully
[ 1.327834] usbcore: registered new interface driver snd-usb-audio
[ 1.327893] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.327897] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.327914] iommu: Adding device snd-soc-dummy to group 36
[ 1.333370] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.333505] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.333556] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.334649] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.334656] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.349266] OPE platform probe
[ 1.349353] OPE platform probe successful
[ 1.349716] OPE platform probe
[ 1.349795] OPE platform probe successful
[ 1.367040] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.369339] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.369341] Extcon AUX1(HDMI) enable
[ 1.369807] tegradc tegradc.0: sync windows ret = 250
[ 1.375549] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.375688] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.375811] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.375941] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.376062] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.376184] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.376301] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.376426] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.376548] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.376666] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.388846] u32 classifier
[ 1.388848] Actions configured
[ 1.388920] Initializing XFRM netlink socket
[ 1.389658] NET: Registered protocol family 10
[ 1.390029] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1.390032] Extcon HDMI: HPD enabled
[ 1.390054] tegradc tegradc.0: hdmi: plugged
[ 1.394413] NET: Registered protocol family 17
[ 1.394426] NET: Registered protocol family 15
[ 1.394501] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.394549] Bluetooth: RFCOMM socket layer initialized
[ 1.394561] Bluetooth: RFCOMM ver 1.11
[ 1.394566] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.394571] Bluetooth: HIDP socket layer initialized
[ 1.394590] 9pnet: Installing 9P2000 support
[ 1.394628] Key type dns_resolver registered
[ 1.395167] Registered cp15_barrier emulation handler
[ 1.395181] Registered setend emulation handler
[ 1.396375] registered taskstats version 1
[ 1.397028] Adding domain ve2-pd to PM domain host1x-pd
[ 1.397277] Adding domain ve-pd to PM domain host1x-pd
[ 1.399408] isp 54600000.isp: initialized
[ 1.400368] isp 54680000.isp: initialized
[ 1.410888] last reset is due to software reset
[ 1.410893] KERNEL: PMC reset status reg: 0x3
[ 1.410970] BL: PMC reset status reg: 0x3
[ 1.410972] BL: PMIC poweroff Event Recorder: 0x0
[ 1.412507] clk_cbus_recalc_rate: no gbus parent
[ 1.412513] clk_cbus_round_rate: no gbus parent
[ 1.412516] clk_cbus_round_rate: no gbus parent
[ 1.412524] clk_cbus_recalc_rate: no gbus parent
[ 1.412627] clk_cbus_recalc_rate: no gbus parent
[ 1.412631] clk_cbus_round_rate: no gbus parent
[ 1.412633] clk_cbus_round_rate: no gbus parent
[ 1.412637] clk_cbus_recalc_rate: no gbus parent
[ 1.413318] tegra_dvfs: GPU-cap: registered
[ 1.413372] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.413375] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.413378] tegra dvfs: vdd-gpu: nominal 1078mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.414718] tegra_dvfs: vdd-gpu-vts: registered
[ 1.415418] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 1.416081] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 1.416635] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.450967] tegra_rtc 7000e000.rtc: setting system clock to 2019-11-18 18:27:40 UTC (1574101660)
[ 1.451993] vi 54080000.vi: vi_probe: ++
[ 1.455032] vi 54080000.vi: initialized
[ 1.457031] vi 54080000.vi: subdev nvcsi–1 bound
[ 1.458552] Disable partitions left on by BL
[ 1.458555] disb
[ 1.458602] bwmgr: missing cdev-type property
[ 1.458711] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.458717] DRAM derating cdev registered.
[ 1.459739] vdd-fan: disabling
[ 1.459743] vdd-usb-vbus: disabling
[ 1.459745] vdd-usb-vbus2: disabling
[ 1.459756] avdd-io-edp-1v05: disabling
[ 1.459850] ALSA device list:
[ 1.459854] #0: tegra-hda at 0x70038000 irq 83
[ 1.459856] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.462790] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.463009] Freeing unused kernel memory: 8576K
[ 1.481415] L4T-INITRD Build DATE: Mon Nov 18 18:27:40 UTC 2019
[ 1.485832] Root device found: mmcblk0p1
[ 1.497709] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.497714] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.497718] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.497721] usb 1-2: Manufacturer: Generic
[ 1.499134] hub 1-2:1.0: USB hub found
[ 1.501219] hub 1-2:1.0: 4 ports detected
[ 1.565654] mmc0: hw tuning done …
[ 1.565688] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.566131] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 1.570648] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 1.622829] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 1.645693] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 1.645697] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.690634] Found dev node: /dev/mmcblk0p1
[ 1.723327] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.724099] Rootfs mounted over mmcblk0p1
[ 1.747983] Switching from initrd to actual rootfs
[ 1.790774] usb 1-2.1: new high-speed USB device number 4 using tegra-xusb
[ 1.825655] usb 1-2.1: New USB device found, idVendor=0bda, idProduct=5411
[ 1.825661] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.825666] usb 1-2.1: Product: 4-Port USB 2.0 Hub
[ 1.825721] usb 1-2.1: Manufacturer: Generic
[ 1.826876] hub 1-2.1:1.0: USB hub found
[ 1.827756] hub 1-2.1:1.0: 4 ports detected
[ 1.963075] ip_tables: © 2000-2006 Netfilter Core Team
[ 1.975245] cgroup: cgroup2: unknown option “nsdelegate”
[ 1.996522] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.997270] systemd[1]: Detected architecture arm64.
[ 2.022546] systemd[1]: Set hostname to .
[ 2.118785] usb 1-2.1.2: new low-speed USB device number 5 using tegra-xusb
[ 2.122338] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.122347] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.150563] usb 1-2.1.2: New USB device found, idVendor=045e, idProduct=0750
[ 2.150570] usb 1-2.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.150575] usb 1-2.1.2: Product: Wired Keyboard 600
[ 2.150579] usb 1-2.1.2: Manufacturer: Microsoft
[ 2.242777] usb 1-2.1.3: new full-speed USB device number 6 using tegra-xusb
[ 2.265722] usb 1-2.1.3: New USB device found, idVendor=222a, idProduct=0001
[ 2.265729] usb 1-2.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.265733] usb 1-2.1.3: Product: ILITEK-TP
[ 2.265736] usb 1-2.1.3: Manufacturer: ILITEK
[ 2.265739] usb 1-2.1.3: SerialNumber: V06.00.00.00
[ 2.269030] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.270407] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.270539] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.271237] input: ILITEK ILITEK-TP as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3:1.0/0003:222A:0001.0003/input/input2
[ 2.271553] hid-multitouch 0003:222A:0001.0003: input,hidraw0: USB HID v1.10 Device [ILITEK ILITEK-TP] on usb-70090000.xusb-2.1.3/input0
[ 2.272188] systemd[1]: Created slice System Slice.
[ 2.272263] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.272474] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.272634] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 2.272774] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.273568] input: ILITEK ILITEK-TP as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.3/1-2.1.3:1.1/0003:222A:0001.0004/input/input3
[ 2.273888] hid-generic 0003:222A:0001.0004: input,hidraw1: USB HID v1.10 Mouse [ILITEK ILITEK-TP] on usb-70090000.xusb-2.1.3/input1
[ 2.364206] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.495463] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.578467] systemd-journald[2004]: Received request to flush runtime journal from PID 1
[ 3.089451] using random self ethernet address
[ 3.094898] using random host ethernet address
[ 3.179776] Mass Storage Function, version: 2009/09/11
[ 3.179782] LUN: removable file: (no medium)
[ 3.249208] using random self ethernet address
[ 3.266857] using random host ethernet address
[ 3.584117] random: crng init done
[ 3.587554] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.040513] rndis0: HOST MAC 26:ac:9c:c3:15:a4
[ 4.040739] rndis0: MAC 26:ac:9c:c3:15:a5
[ 4.042593] usb0: HOST MAC 26:ac:9c:c3:15:a6
[ 4.042623] usb0: MAC 26:ac:9c:c3:15:a7
[ 4.042642] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.043429] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.043446] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.043475] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.043692] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.043707] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.045371] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.045396] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.045639] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.050174] l4tbr0: port 1(rndis0) entered blocking state
[ 4.050180] l4tbr0: port 1(rndis0) entered disabled state
[ 4.050351] device rndis0 entered promiscuous mode
[ 4.065323] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.073371] l4tbr0: port 2(usb0) entered blocking state
[ 4.073377] l4tbr0: port 2(usb0) entered disabled state
[ 4.073844] device usb0 entered promiscuous mode
[ 4.084782] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.473458] Intel® Wireless WiFi driver for Linux
[ 4.473463] Copyright© 2003- 2015 Intel Corporation
[ 4.473879] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.751557] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 4.769829] iwlwifi 0000:01:00.0: Falling back to user helper
[ 4.835362] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 4.852165] iwlwifi 0000:01:00.0: Falling back to user helper
[ 4.875581] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 4.885319] iwlwifi 0000:01:00.0: Falling back to user helper
[ 4.896254] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 4.905755] iwlwifi 0000:01:00.0: Falling back to user helper
[ 4.954412] iwlwifi 0000:01:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[ 5.050224] iwlwifi 0000:01:00.0: Detected Intel® Dual Band Wireless AC 8265, REV=0x230
[ 5.052701] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.053681] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.173554] ieee80211 phy0: Selected rate control algorithm ‘iwl-mvm-rs’
[ 5.174506] thermal thermal_zone6: failed to read out thermal zone (-5)
[ 5.181427] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi
[ 5.298864] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.298871] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.476656] usbcore: registered new interface driver btusb
[ 5.481408] Bluetooth: hci0: Firmware revision 0.1 build 185 week 49 2017
[ 5.620314] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.643041] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.644093] eth0: 0xffffff800a37e000, 00:04:4b:e4:14:9b, IRQ 404
[ 5.654094] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.654104] Bluetooth: BNEP socket layer initialized
[ 5.655151] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.655158] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.655162] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.655165] usb 2-1: Manufacturer: Generic
[ 5.663561] hub 2-1:1.0: USB hub found
[ 5.665029] hub 2-1:1.0: 4 ports detected
[ 5.705907] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.740166] input: Microsoft Wired Keyboard 600 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.2/1-2.1.2:1.0/0003:045E:0750.0001/input/input4
[ 5.791324] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.793772] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.794219] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.855708] microsoft 0003:045E:0750.0001: input,hidraw2: USB HID v1.11 Keyboard [Microsoft Wired Keyboard 600] on usb-70090000.xusb-2.1.2/input0
[ 5.857398] input: Microsoft Wired Keyboard 600 as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1.2/1-2.1.2:1.1/0003:045E:0750.0002/input/input5
[ 5.911021] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.911452] iwlwifi 0000:01:00.0: L1 Enabled - LTR Enabled
[ 5.955381] usb 2-1.1: new SuperSpeed USB device number 3 using tegra-xusb
[ 5.974947] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.975159] microsoft 0003:045E:0750.0002: input,hidraw3: USB HID v1.11 Device [Microsoft Wired Keyboard 600] on usb-70090000.xusb-2.1.2/input1
[ 5.985655] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.985662] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.985666] usb 2-1.1: Product: 4-Port USB 3.0 Hub
[ 5.985670] usb 2-1.1: Manufacturer: Generic
[ 5.990049] hub 2-1.1:1.0: USB hub found
[ 5.990838] hub 2-1.1:1.0: 4 ports detected
[ 6.097396] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 6.279483] usb 2-1.1.1: new SuperSpeed USB device number 4 using tegra-xusb
[ 6.302534] usb 2-1.1.1: New USB device found, idVendor=0781, idProduct=cfcb
[ 6.302542] usb 2-1.1.1: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[ 6.302546] usb 2-1.1.1: Product: SDDR-B531
[ 6.302549] usb 2-1.1.1: Manufacturer: SanDisk
[ 6.302552] usb 2-1.1.1: SerialNumber: 0424192594310008
[ 6.304301] usb-storage 2-1.1.1:1.0: USB Mass Storage device detected
[ 6.311651] scsi host0: usb-storage 2-1.1.1:1.0
[ 6.365881] zram: Added device: zram0
[ 6.366436] zram: Added device: zram1
[ 6.366982] zram: Added device: zram2
[ 6.368010] zram: Added device: zram3
[ 6.395457] usb 2-1.1.4: new SuperSpeed USB device number 5 using tegra-xusb
[ 6.415413] usb 2-1.1.4: LPM exit latency is zeroed, disabling LPM.
[ 6.416272] usb 2-1.1.4: New USB device found, idVendor=04b4, idProduct=00f9
[ 6.416278] usb 2-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.416282] usb 2-1.1.4: Product: oCam-5CRO-U
[ 6.416286] usb 2-1.1.4: Manufacturer: WITHROBOT Inc.
[ 6.416289] usb 2-1.1.4: SerialNumber: SN_29CD7172
[ 6.588495] zram0: detected capacity change from 0 to 518569984
[ 6.727192] uvcvideo: Found UVC 1.00 device oCam-5CRO-U (04b4:00f9)
[ 6.729890] uvcvideo 2-1.1.4:1.0: Entity type for entity Extension 3 was not initialized!
[ 6.739464] uvcvideo 2-1.1.4:1.0: Entity type for entity Processing 2 was not initialized!
[ 6.748492] uvcvideo 2-1.1.4:1.0: Entity type for entity Camera 1 was not initialized!
[ 6.756864] input: oCam-5CRO-U as /devices/70090000.xusb/usb2/2-1/2-1.1/2-1.1.4/2-1.1.4:1.0/input/input6
[ 6.757041] usbcore: registered new interface driver uvcvideo
[ 6.757043] USB Video Class driver (1.1.1)
[ 7.167931] Adding 506412k swap on /dev/zram0. Priority:5 extents:1 across:506412k SS
[ 7.171832] zram1: detected capacity change from 0 to 518569984
[ 7.183659] Adding 506412k swap on /dev/zram1. Priority:5 extents:1 across:506412k SS
[ 7.189764] zram2: detected capacity change from 0 to 518569984
[ 7.206241] Adding 506412k swap on /dev/zram2. Priority:5 extents:1 across:506412k SS
[ 7.211366] zram3: detected capacity change from 0 to 518569984
[ 7.223943] Adding 506412k swap on /dev/zram3. Priority:5 extents:1 across:506412k SS
[ 7.320889] scsi 0:0:0:0: Direct-Access SanDisk SDDR-B531 2916 PQ: 0 ANSI: 6
[ 8.271174] sd 0:0:0:0: [sda] 61736960 512-byte logical blocks: (31.6 GB/29.4 GiB)
[ 8.272158] sd 0:0:0:0: [sda] Write Protect is off
[ 8.272163] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 8.273081] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 8.283747] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 8.283751] GPT:30375935 != 61736959
[ 8.283753] GPT:Alternate GPT header not at the end of the disk.
[ 8.283754] GPT:30375935 != 61736959
[ 8.283755] GPT: Use GNU Parted to correct GPT errors.
[ 8.283780] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9 sda10 sda11 sda12
[ 8.297922] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 9.355884] tegradc tegradc.0: blank - powerdown
[ 9.418390] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 9.418394] Extcon AUX1(HDMI) disable
[ 9.442641] tegradc tegradc.0: unblank
[ 9.455395] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 9.455564] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 9.459400] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 9.459408] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 9.496386] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 9.496389] Extcon AUX1(HDMI) enable
[ 9.502335] tegradc tegradc.0: unblank
[ 9.502346] tegradc tegradc.1: blank - powerdown
[ 9.687669] wlan0: authenticate with cc:2d:e0:b0:f6:58
[ 9.703456] wlan0: send auth to cc:2d:e0:b0:f6:58 (try 1/3)
[ 9.709429] wlan0: authenticated
[ 9.710824] wlan0: associate with cc:2d:e0:b0:f6:58 (try 1/3)
[ 9.716980] wlan0: RX AssocResp from cc:2d:e0:b0:f6:58 (capab=0x431 status=0 aid=1)
[ 9.734535] wlan0: associated
[ 9.747045] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 24.272539] wlan0: deauthenticated from cc:2d:e0:b0:f6:58 (Reason: 16=GROUP_KEY_HANDSHAKE_TIMEOUT)
[ 25.435226] wlan0: authenticate with cc:2d:e0:b0:f6:58
[ 25.446562] wlan0: send auth to cc:2d:e0:b0:f6:58 (try 1/3)
[ 25.449107] wlan0: authenticated
[ 25.450885] wlan0: associate with cc:2d:e0:b0:f6:58 (try 1/3)
[ 25.455801] wlan0: RX AssocResp from cc:2d:e0:b0:f6:58 (capab=0x431 status=0 aid=1)
[ 25.459840] wlan0: associated
[ 269.426624] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 316.407023] pcieport 0000:00:01.0: AER: Corrected error received: id=0010
[ 316.407034] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 316.419014] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 316.428172] pcieport 0000:00:01.0: [ 0] Receiver Error (First)
[ 316.834701] iwlwifi 0000:01:00.0: Queue 2 stuck for 10000 ms.
[ 316.840454] iwlwifi 0000:01:00.0: Current SW read_ptr 95 write_ptr 96
[ 316.846966] iwl data: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
[ 316.855891] iwlwifi 0000:01:00.0: FH TRBs(0) = 0xcccf44a9
[ 316.861356] iwlwifi 0000:01:00.0: FH TRBs(1) = 0x8010205f
[ 316.866817] iwlwifi 0000:01:00.0: FH TRBs(2) = 0x4e5d55d6
[ 316.872271] iwlwifi 0000:01:00.0: FH TRBs(3) = 0x80300010
[ 316.877733] iwlwifi 0000:01:00.0: FH TRBs(4) = 0xf46ccd32
[ 316.883185] iwlwifi 0000:01:00.0: FH TRBs(5) = 0x28c5e002
[ 316.888639] iwlwifi 0000:01:00.0: FH TRBs(6) = 0x2dfe952f
[ 316.894109] iwlwifi 0000:01:00.0: FH TRBs(7) = 0x00709056
[ 316.899602] iwlwifi 0000:01:00.0: Q 0 is active and mapped to fifo 3 ra_tid 0x0000 [17,17]
[ 316.907966] iwlwifi 0000:01:00.0: Q 1 is active and mapped to fifo 2 ra_tid 0x0000 [0,0]
[ 316.916167] iwlwifi 0000:01:00.0: Q 2 is active and mapped to fifo 1 ra_tid 0x0000 [95,96]
[ 316.924533] iwlwifi 0000:01:00.0: Q 3 is active and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.932734] iwlwifi 0000:01:00.0: Q 4 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.941099] iwlwifi 0000:01:00.0: Q 5 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.949484] iwlwifi 0000:01:00.0: Q 6 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.957851] iwlwifi 0000:01:00.0: Q 7 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.966227] iwlwifi 0000:01:00.0: Q 8 is active and mapped to fifo 3 ra_tid 0x0000 [0,0]
[ 316.974420] iwlwifi 0000:01:00.0: Q 9 is active and mapped to fifo 7 ra_tid 0x0000 [87,87]
[ 316.982793] iwlwifi 0000:01:00.0: Q 10 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.991250] iwlwifi 0000:01:00.0: Q 11 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 316.999702] iwlwifi 0000:01:00.0: Q 12 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.008141] iwlwifi 0000:01:00.0: Q 13 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.016579] iwlwifi 0000:01:00.0: Q 14 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.025025] iwlwifi 0000:01:00.0: Q 15 is active and mapped to fifo 5 ra_tid 0x0000 [0,0]
[ 317.033298] iwlwifi 0000:01:00.0: Q 16 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.041735] iwlwifi 0000:01:00.0: Q 17 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.050191] iwlwifi 0000:01:00.0: Q 18 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.058636] iwlwifi 0000:01:00.0: Q 19 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.067076] iwlwifi 0000:01:00.0: Q 20 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.075515] iwlwifi 0000:01:00.0: Q 21 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.083961] iwlwifi 0000:01:00.0: Q 22 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.092410] iwlwifi 0000:01:00.0: Q 23 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.100861] iwlwifi 0000:01:00.0: Q 24 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.109301] iwlwifi 0000:01:00.0: Q 25 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.117740] iwlwifi 0000:01:00.0: Q 26 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.126169] iwlwifi 0000:01:00.0: Q 27 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.134602] iwlwifi 0000:01:00.0: Q 28 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.143042] iwlwifi 0000:01:00.0: Q 29 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.151481] iwlwifi 0000:01:00.0: Q 30 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 317.159973] iwlwifi 0000:01:00.0: Microcode SW error detected. Restarting 0x2000000.
[ 317.167821] iwlwifi 0000:01:00.0: CSR values:
[ 317.172212] iwlwifi 0000:01:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
[ 317.180528] iwlwifi 0000:01:00.0: CSR_HW_IF_CONFIG_REG: 0X00489000
[ 317.187367] iwlwifi 0000:01:00.0: CSR_INT_COALESCING: 0X00000040
[ 317.194206] iwlwifi 0000:01:00.0: CSR_INT: 0X00000000
[ 317.201039] iwlwifi 0000:01:00.0: CSR_INT_MASK: 0X00000000
[ 317.207880] iwlwifi 0000:01:00.0: CSR_FH_INT_STATUS: 0X00000000
[ 317.214724] iwlwifi 0000:01:00.0: CSR_GPIO_IN: 0X00000010
[ 317.221576] iwlwifi 0000:01:00.0: CSR_RESET: 0X00000000
[ 317.228468] iwlwifi 0000:01:00.0: CSR_GP_CNTRL: 0X08040005
[ 317.235344] iwlwifi 0000:01:00.0: CSR_HW_REV: 0X00000230
[ 317.242181] iwlwifi 0000:01:00.0: CSR_EEPROM_REG: 0Xd55555d5
[ 317.249021] iwlwifi 0000:01:00.0: CSR_EEPROM_GP: 0Xd55555d5
[ 317.255864] iwlwifi 0000:01:00.0: CSR_OTP_GP_REG: 0Xd55555d5
[ 317.262716] iwlwifi 0000:01:00.0: CSR_GIO_REG: 0X001f0042
[ 317.269553] iwlwifi 0000:01:00.0: CSR_GP_UCODE_REG: 0X00000000
[ 317.276395] iwlwifi 0000:01:00.0: CSR_GP_DRIVER_REG: 0X00000000
[ 317.283231] iwlwifi 0000:01:00.0: CSR_UCODE_DRV_GP1: 0X00000000
[ 317.290064] iwlwifi 0000:01:00.0: CSR_UCODE_DRV_GP2: 0X00000000
[ 317.296896] iwlwifi 0000:01:00.0: CSR_LED_REG: 0X00000060
[ 317.303731] iwlwifi 0000:01:00.0: CSR_DRAM_INT_TBL_REG: 0X8816dae2
[ 317.310563] iwlwifi 0000:01:00.0: CSR_GIO_CHICKEN_BITS: 0X07800200
[ 317.317408] iwlwifi 0000:01:00.0: CSR_ANA_PLL_CFG: 0Xd55555d5
[ 317.324250] iwlwifi 0000:01:00.0: CSR_MONITOR_STATUS_REG: 0Xc03803c0
[ 317.331096] iwlwifi 0000:01:00.0: CSR_HW_REV_WA_REG: 0X0001001a
[ 317.337936] iwlwifi 0000:01:00.0: CSR_DBG_HPET_MEM_REG: 0Xffff0010
[ 317.344755] iwlwifi 0000:01:00.0: FH register values:
[ 317.349872] iwlwifi 0000:01:00.0: FH_RSCSR_CHNL0_STTS_WPTR_REG: 0X1665b800
[ 317.357508] iwlwifi 0000:01:00.0: FH_RSCSR_CHNL0_RBDCB_BASE_REG: 0X01619cf0
[ 317.365135] iwlwifi 0000:01:00.0: FH_RSCSR_CHNL0_WPTR: 0X00000008
[ 317.372779] iwlwifi 0000:01:00.0: FH_MEM_RCSR_CHNL0_CONFIG_REG: 0X00801054
[ 317.380409] iwlwifi 0000:01:00.0: FH_MEM_RSSR_SHARED_CTRL_REG: 0X000000fc
[ 317.388064] iwlwifi 0000:01:00.0: FH_MEM_RSSR_RX_STATUS_REG: 0X03030000
[ 317.395699] iwlwifi 0000:01:00.0: FH_MEM_RSSR_RX_ENABLE_ERR_IRQ2DRV: 0X00000000
[ 317.403335] iwlwifi 0000:01:00.0: FH_TSSR_TX_STATUS_REG: 0X07ff0001
[ 317.410953] iwlwifi 0000:01:00.0: FH_TSSR_TX_ERROR_REG: 0X00000000
[ 317.418692] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[ 317.424267] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 6
[ 317.430109] iwlwifi 0000:01:00.0: Loaded firmware version: 22.391740.0
[ 317.436644] iwlwifi 0000:01:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 317.443614] iwlwifi 0000:01:00.0: 0x00800674 | trm_hw_status0
[ 317.449377] iwlwifi 0000:01:00.0: 0x00000000 | trm_hw_status1
[ 317.455123] iwlwifi 0000:01:00.0: 0x0000E258 | branchlink2
[ 317.460619] iwlwifi 0000:01:00.0: 0x00027324 | interruptlink1
[ 317.466376] iwlwifi 0000:01:00.0: 0x000264B4 | interruptlink2
[ 317.472128] iwlwifi 0000:01:00.0: 0x00000000 | data1
[ 317.477108] iwlwifi 0000:01:00.0: 0x00000080 | data2
[ 317.482084] iwlwifi 0000:01:00.0: 0x07830000 | data3
[ 317.487064] iwlwifi 0000:01:00.0: 0xC84007E7 | beacon time
[ 317.492562] iwlwifi 0000:01:00.0: 0xBED3E819 | tsf low
[ 317.497715] iwlwifi 0000:01:00.0: 0x00000684 | tsf hi
[ 317.502776] iwlwifi 0000:01:00.0: 0x00000000 | time gp1
[ 317.508014] iwlwifi 0000:01:00.0: 0x128C1A39 | time gp2
[ 317.513241] iwlwifi 0000:01:00.0: 0x00000000 | uCode revision type
[ 317.519429] iwlwifi 0000:01:00.0: 0x00000016 | uCode version major
[ 317.525616] iwlwifi 0000:01:00.0: 0x0005FA3C | uCode version minor
[ 317.531805] iwlwifi 0000:01:00.0: 0x00000230 | hw version
[ 317.537211] iwlwifi 0000:01:00.0: 0x00489000 | board version
[ 317.542867] iwlwifi 0000:01:00.0: 0x025F001C | hcmd
[ 317.547753] iwlwifi 0000:01:00.0: 0xA4022002 | isr0
[ 317.552640] iwlwifi 0000:01:00.0: 0x00800000 | isr1
[ 317.557525] iwlwifi 0000:01:00.0: 0x0800180A | isr2
[ 317.562424] iwlwifi 0000:01:00.0: 0x0041F8C5 | isr3
[ 317.567311] iwlwifi 0000:01:00.0: 0x00000000 | isr4
[ 317.572202] iwlwifi 0000:01:00.0: 0x00004110 | last cmd Id
[ 317.577700] iwlwifi 0000:01:00.0: 0x00000000 | wait_event
[ 317.583118] iwlwifi 0000:01:00.0: 0x00004288 | l2p_control
[ 317.588626] iwlwifi 0000:01:00.0: 0x00002030 | l2p_duration
[ 317.594217] iwlwifi 0000:01:00.0: 0x000003BF | l2p_mhvalid
[ 317.599718] iwlwifi 0000:01:00.0: 0x00000020 | l2p_addr_match
[ 317.605480] iwlwifi 0000:01:00.0: 0x0000000D | lmpm_pmg_sel
[ 317.611067] iwlwifi 0000:01:00.0: 0x25091923 | timestamp
[ 317.616394] iwlwifi 0000:01:00.0: 0x00340818 | flow_handler
[ 317.622064] iwlwifi 0000:01:00.0: Start IWL Error Log Dump:
[ 317.627661] iwlwifi 0000:01:00.0: Status: 0x00000000, count: 7
[ 317.633518] iwlwifi 0000:01:00.0: 0x00000070 | ADVANCED_SYSASSERT
[ 317.639624] iwlwifi 0000:01:00.0: 0x00000000 | umac branchlink1
[ 317.645564] iwlwifi 0000:01:00.0: 0xC0082F64 | umac branchlink2
[ 317.651484] iwlwifi 0000:01:00.0: 0xC0081000 | umac interruptlink1
[ 317.657679] iwlwifi 0000:01:00.0: 0xC0081000 | umac interruptlink2
[ 317.663879] iwlwifi 0000:01:00.0: 0x00000800 | umac data1
[ 317.669298] iwlwifi 0000:01:00.0: 0xC0081000 | umac data2
[ 317.674717] iwlwifi 0000:01:00.0: 0xDEADBEEF | umac data3
[ 317.680129] iwlwifi 0000:01:00.0: 0x00000016 | umac major
[ 317.685541] iwlwifi 0000:01:00.0: 0x0005FA3C | umac minor
[ 317.690955] iwlwifi 0000:01:00.0: 0xC0886280 | frame pointer
[ 317.696630] iwlwifi 0000:01:00.0: 0xC0886280 | stack pointer
[ 317.702301] iwlwifi 0000:01:00.0: 0x0956019C | last host cmd
[ 317.707974] iwlwifi 0000:01:00.0: 0x00000000 | isr status reg
[ 711.324489] iwlwifi 0000:01:00.0: Queue 2 stuck for 10000 ms.
[ 711.330251] iwlwifi 0000:01:00.0: Current SW read_ptr 173 write_ptr 217
[ 711.336918] iwl data: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
[ 711.345832] iwlwifi 0000:01:00.0: FH TRBs(0) = 0xcccf44a9
[ 711.351264] iwlwifi 0000:01:00.0: FH TRBs(1) = 0x801020bc
[ 711.356694] iwlwifi 0000:01:00.0: FH TRBs(2) = 0x4e5d55d6
[ 711.362121] iwlwifi 0000:01:00.0: FH TRBs(3) = 0x80300001
[ 711.367549] iwlwifi 0000:01:00.0: FH TRBs(4) = 0xf46ccd32
[ 711.372977] iwlwifi 0000:01:00.0: FH TRBs(5) = 0x28c5e002
[ 711.378404] iwlwifi 0000:01:00.0: FH TRBs(6) = 0x2dfe952f
[ 711.383828] iwlwifi 0000:01:00.0: FH TRBs(7) = 0x00709067
[ 711.389299] iwlwifi 0000:01:00.0: Q 0 is active and mapped to fifo 3 ra_tid 0x0000 [2,2]
[ 711.397457] iwlwifi 0000:01:00.0: Q 1 is active and mapped to fifo 2 ra_tid 0x0000 [0,0]
[ 711.405612] iwlwifi 0000:01:00.0: Q 2 is active and mapped to fifo 1 ra_tid 0x0000 [173,217]
[ 711.414133] iwlwifi 0000:01:00.0: Q 3 is active and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.422285] iwlwifi 0000:01:00.0: Q 4 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.430610] iwlwifi 0000:01:00.0: Q 5 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.438939] iwlwifi 0000:01:00.0: Q 6 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.447269] iwlwifi 0000:01:00.0: Q 7 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.455598] iwlwifi 0000:01:00.0: Q 8 is active and mapped to fifo 3 ra_tid 0x0000 [0,0]
[ 711.463755] iwlwifi 0000:01:00.0: Q 9 is active and mapped to fifo 7 ra_tid 0x0000 [105,105]
[ 711.472258] iwlwifi 0000:01:00.0: Q 10 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.480675] iwlwifi 0000:01:00.0: Q 11 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.489091] iwlwifi 0000:01:00.0: Q 12 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.497506] iwlwifi 0000:01:00.0: Q 13 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.505922] iwlwifi 0000:01:00.0: Q 14 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.514338] iwlwifi 0000:01:00.0: Q 15 is active and mapped to fifo 5 ra_tid 0x0000 [0,0]
[ 711.522581] iwlwifi 0000:01:00.0: Q 16 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.530996] iwlwifi 0000:01:00.0: Q 17 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.539411] iwlwifi 0000:01:00.0: Q 18 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.547828] iwlwifi 0000:01:00.0: Q 19 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.556244] iwlwifi 0000:01:00.0: Q 20 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.564659] iwlwifi 0000:01:00.0: Q 21 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.573074] iwlwifi 0000:01:00.0: Q 22 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.581490] iwlwifi 0000:01:00.0: Q 23 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.589904] iwlwifi 0000:01:00.0: Q 24 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.598319] iwlwifi 0000:01:00.0: Q 25 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.606733] iwlwifi 0000:01:00.0: Q 26 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.615148] iwlwifi 0000:01:00.0: Q 27 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.623563] iwlwifi 0000:01:00.0: Q 28 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.631977] iwlwifi 0000:01:00.0: Q 29 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.640391] iwlwifi 0000:01:00.0: Q 30 is inactive and mapped to fifo 0 ra_tid 0x0000 [0,0]
[ 711.648887] iwlwifi 0000:01:00.0: Microcode SW error detected. Restarting 0x2000000.
[ 711.656754] iwlwifi 0000:01:00.0: CSR values:
[ 711.661132] iwlwifi 0000:01:00.0: (2nd byte of CSR_INT_COALESCING is CSR_INT_PERIODIC_REG)
[ 711.669437] iwlwifi 0000:01:00.0: CSR_HW_IF_CONFIG_REG: 0X00489000
[ 711.676267] iwlwifi 0000:01:00.0: CSR_INT_COALESCING: 0X0000ff40
[ 711.683107] iwlwifi 0000:01:00.0: CSR_INT: 0X10000000
[ 711.689944] iwlwifi 0000:01:00.0: CSR_INT_MASK: 0X00000000
[ 711.696769] iwlwifi 0000:01:00.0: CSR_FH_INT_STATUS: 0X00000000
[ 711.703599] iwlwifi 0000:01:00.0: CSR_GPIO_IN: 0X00000010
[ 711.710425] iwlwifi 0000:01:00.0: CSR_RESET: 0X00000000
[ 711.717259] iwlwifi 0000:01:00.0: CSR_GP_CNTRL: 0X08040005
[ 711.724091] iwlwifi 0000:01:00.0: CSR_HW_REV: 0X00000230
[ 711.730923] iwlwifi 0000:01:00.0: CSR_EEPROM_REG: 0Xd55555d5
[ 711.737749] iwlwifi 0000:01:00.0: CSR_EEPROM_GP: 0Xd55555d5
[ 711.744578] iwlwifi 0000:01:00.0: CSR_OTP_GP_REG: 0Xd55555d5
[ 711.751410] iwlwifi 0000:01:00.0: CSR_GIO_REG: 0X001f0042
[ 711.758238] iwlwifi 0000:01:00.0: CSR_GP_UCODE_REG: 0X00000000
[ 711.765065] iwlwifi 0000:01:00.0: CSR_GP_DRIVER_REG: 0X0
