Below patch is the fix, this will be part of next release.
From d989f4ba5e5819366e25ac19a3dab60713e6780d Mon Sep 17 00:00:00 2001
Date: Wed, 15 May 2019 12:15:24 +0530
Subject: [PATCH 1/1] PCI: tegra: Fix speed change code
X-NVConfidentiality: public
Speed change to Gen-2 should take place when there is no traffic on the
bus and the way software can make sure that is to attempt speed change to
Gen-2 before registering the devices with PCIe sub-system. This patch
does exactly that. It also fixes link retrain timeout value to 100000us.
Bug 200519254
Change-Id: I820a78d907a25e25e1e95e22456793d5e33ad833
Signed-off-by: Vidya Sagar <vidyas@nvidia.com>
drivers/pci/host/pci-tegra.c | 178 ++++++++++++-----------------------
1 file changed, 61 insertions(+), 117 deletions(-)
diff --git a/drivers/pci/host/pci-tegra.c b/drivers/pci/host/pci-tegra.c
index e4249feac226..7d9f376f85ee 100644
--- a/drivers/pci/host/pci-tegra.c
+++ b/drivers/pci/host/pci-tegra.c
@@ -204,6 +204,7 @@
#define RP_VEND_XP_PRBS_EN (1 << 1)
#define RP_LINK_CONTROL_STATUS 0x00000090
+#define RP_LINK_CONTROL_STATUS_BW_MGMT_STATUS 0x40000000
#define RP_LINK_CONTROL_STATUS_DL_LINK_ACTIVE 0x20000000
#define RP_LINK_CONTROL_STATUS_LINKSTAT_MASK 0x3fff0000
#define RP_LINK_CONTROL_STATUS_NEG_LINK_WIDTH (0x3F << 20)
@@ -374,7 +375,7 @@
#define INT_PCI_MSI_NR (32 * 8)
-#define LINK_RETRAIN_TIMEOUT HZ
+#define LINK_RETRAIN_TIMEOUT 100000
#define PCIE_LANES_X4_X1 0x14
@@ -489,6 +490,7 @@ struct tegra_pcie {
static int tegra_pcie_enable_msi(struct tegra_pcie *pcie, bool no_init);
static void tegra_pcie_check_ports(struct tegra_pcie *pcie);
+static void tegra_pcie_link_speed(struct tegra_pcie *pcie);
static int tegra_pcie_power_off(struct tegra_pcie *pcie);
#define MAX_PWR_GPIOS 5
@@ -524,7 +526,6 @@ struct tegra_pcie_bus {
/* used to avoid successive hotplug disconnect or connect */
static bool hotplug_event;
/* pcie mselect, xclk and emc rate */
-static bool is_gen2_speed;
static u16 bdf;
static u16 config_offset;
static u32 config_val;
@@ -2532,6 +2533,8 @@ static void tegra_pcie_check_ports(struct tegra_pcie *pcie)
dev_info(pcie->dev, "link %u down, ignoring\n", port->index);
tegra_pcie_port_disable(port);
+ /* configure all links to gen2 speed by default */
+ tegra_pcie_link_speed(pcie);
if (pcie->soc_data->mbist_war)
mbist_war(pcie, false);
@@ -2706,123 +2709,72 @@ static int tegra_pcie_scale_voltage(struct tegra_pcie *pcie)
return err;
-static void tegra_pcie_change_link_speed(struct tegra_pcie *pcie,
- struct pci_dev *pdev, bool isGen2)
+static void tegra_pcie_change_link_speed(struct tegra_pcie *pcie)
- u16 val, link_sts_up_spd, link_sts_dn_spd;
- u16 link_cap_up_spd, link_cap_dn_spd;
- u32 rp = 0;
- unsigned long start_jiffies;
- struct tegra_pcie_port *port = NULL;
- struct pci_dev *up_dev, *dn_dev;
+ struct device *dev = pcie->dev;
+ struct tegra_pcie_port *port, *tmp;
+ ktime_t deadline;
+ u32 value;
- PR_FUNC_LINE;
- /* skip if current device is not PCI express capable */
- /* or is either a root port or downstream port */
- if (!pci_is_pcie(pdev))
- goto skip;
- if ((pci_pcie_type(pdev) == PCI_EXP_TYPE_DOWNSTREAM) ||
- (pci_pcie_type(pdev) == PCI_EXP_TYPE_ROOT_PORT))
- goto skip;
- /* initialize upstream/endpoint and downstream/root port device ptr */
- up_dev = pdev;
- dn_dev = pdev->bus->self;
- rp = PCI_SLOT(dn_dev->devfn);
- list_for_each_entry(port, &pcie->ports, list)
- if (rp == port->index + 1)
- break;
- if (!port->ep_status)
- goto skip;
- /* read link status register to find current speed */
- pcie_capability_read_word(up_dev, PCI_EXP_LNKSTA, &link_sts_up_spd);
- link_sts_up_spd &= PCI_EXP_LNKSTA_CLS;
- pcie_capability_read_word(dn_dev, PCI_EXP_LNKSTA, &link_sts_dn_spd);
- link_sts_dn_spd &= PCI_EXP_LNKSTA_CLS;
- /* read link capability register to find max speed supported */
- pcie_capability_read_word(up_dev, PCI_EXP_LNKCAP, &link_cap_up_spd);
- link_cap_up_spd &= PCI_EXP_LNKCAP_SLS;
- pcie_capability_read_word(dn_dev, PCI_EXP_LNKCAP, &link_cap_dn_spd);
- link_cap_dn_spd &= PCI_EXP_LNKCAP_SLS;
- /* skip if both devices across the link are already trained to gen2 */
- if (isGen2) {
- if (((link_cap_up_spd >= PCI_EXP_LNKSTA_CLS_5_0GB) &&
- (link_cap_dn_spd >= PCI_EXP_LNKSTA_CLS_5_0GB)) &&
- ((link_sts_up_spd != PCI_EXP_LNKSTA_CLS_5_0GB) ||
- (link_sts_dn_spd != PCI_EXP_LNKSTA_CLS_5_0GB)))
- goto change;
- else
- goto skip;
- } else {
- /* gen1 should be supported by default by all pcie cards */
- if ((link_sts_up_spd != PCI_EXP_LNKSTA_CLS_2_5GB) ||
- (link_sts_dn_spd != PCI_EXP_LNKSTA_CLS_2_5GB))
- goto change;
- else
- goto skip;
+ list_for_each_entry_safe(port, tmp, &pcie->ports, list) {
+ * "Supported Link Speeds Vector" in "Link Capabilities 2"
+ * is not supported by Tegra. tegra_pcie_change_link_speed()
+ * is called only for Tegra chips which support Gen2.
+ * So there no harm if supported link speed is not verified.
+ value = readl(port->base + RP_LINK_CONTROL_STATUS_2);
+ value &= ~PCI_EXP_LNKSTA_CLS;
+ value |= PCI_EXP_LNKSTA_CLS_5_0GB;
+ writel(value, port->base + RP_LINK_CONTROL_STATUS_2);
+ * Poll until link comes back from recovery to avoid race
+ * condition.
+ deadline = ktime_add_us(ktime_get(), LINK_RETRAIN_TIMEOUT);
-change:
- /* Set Link Speed */
- pcie_capability_read_word(dn_dev, PCI_EXP_LNKCTL2, &val);
- val &= ~PCI_EXP_LNKSTA_CLS;
- if (isGen2) {
- dev_info(pcie->dev, "speed change : Gen-1 -> Gen-2\n");
- val |= PCI_EXP_LNKSTA_CLS_5_0GB;
- } else {
- dev_info(pcie->dev, "speed change : Gen-2 -> Gen-1\n");
- val |= PCI_EXP_LNKSTA_CLS_2_5GB;
- pcie_capability_write_word(dn_dev, PCI_EXP_LNKCTL2, val);
+ while (ktime_before(ktime_get(), deadline)) {
+ value = readl(port->base + RP_LINK_CONTROL_STATUS);
+ if ((value & PCI_EXP_LNKSTA_LT) == 0)
+ break;
- /* LTSSM might be in recovery or configuration, so wait for current
- * link training to end. Break out after waiting for timeout */
- start_jiffies = jiffies;
- for (;;) {
- pcie_capability_read_word(dn_dev, PCI_EXP_LNKSTA, &val);
- if (!(val & PCI_EXP_LNKSTA_LT))
- break;
- if (time_after(jiffies, start_jiffies + LINK_RETRAIN_TIMEOUT))
- break;
- usleep_range(1000, 1100);
- if (val & PCI_EXP_LNKSTA_LT)
- dev_err(pcie->dev, "Link training failed before speed change\n");
+ usleep_range(2000, 3000);
+ if (value & PCI_EXP_LNKSTA_LT)
+ dev_warn(dev, "PCIe port %u link is in recovery\n",
+ port->index);
- /* Retrain the link */
- pcie_capability_read_word(dn_dev, PCI_EXP_LNKCTL, &val);
- val |= PCI_EXP_LNKCTL_RL;
- pcie_capability_write_word(dn_dev, PCI_EXP_LNKCTL, val);
+ /* Clear BW Management Status */
+ value |= RP_LINK_CONTROL_STATUS_BW_MGMT_STATUS;
+ writel(value, port->base + RP_LINK_CONTROL_STATUS);
- /* Wait for link training end. Break out after waiting for timeout */
- for (;;) {
- break;
- break;
- dev_err(pcie->dev, "Link Re-training failed after speed change\n");
+ /* Retrain the link */
+ value |= PCI_EXP_LNKCTL_RL;
-skip:
- return;
+ if (value & RP_LINK_CONTROL_STATUS_BW_MGMT_STATUS)
+ break;
+ dev_err(dev, "failed to retrain link of port %u\n",
+ port->index);
-static void tegra_pcie_link_speed(struct tegra_pcie *pcie, bool isGen2)
- struct pci_dev *pdev = NULL;
PR_FUNC_LINE;
- /* Voltage scaling should happen before any device transition */
- /* to Gen2 or after all devices has transitioned to Gen1 */
- for_each_pci_dev(pdev)
- tegra_pcie_change_link_speed(pcie, pdev, isGen2);
+ tegra_pcie_change_link_speed(pcie);
tegra_pcie_scale_voltage(pcie);
return;
@@ -2833,8 +2785,6 @@ static void tegra_pcie_enable_features(struct tegra_pcie *pcie)
struct tegra_pcie_port *port;
PR_FUNC_LINE;
- /* configure all links to gen2 speed by default */
- tegra_pcie_link_speed(pcie, true);
list_for_each_entry(port, &pcie->ports, list) {
if (port->status)
tegra_pcie_apply_sw_war(port, true);
@@ -3662,9 +3612,8 @@ static int apply_link_speed(struct seq_file *s, void *data)
struct tegra_pcie *pcie = (struct tegra_pcie *)(s->private);
- seq_printf(s, "Changing link speed to %s... ",
- (is_gen2_speed) ? "Gen2" : "Gen1");
- tegra_pcie_link_speed(pcie, is_gen2_speed);
+ seq_puts(s, "Changing link speed to Gen2\n");
seq_printf(s, "Done\n");
return 0;
@@ -4591,11 +4540,6 @@ static int tegra_pcie_debugfs_init(struct tegra_pcie *pcie)
if (!d)
goto remove;
- d = debugfs_create_bool("is_gen2_speed(WO)", S_IWUSR, pcie->debugfs,
- &is_gen2_speed);
- if (!d)
- goto remove;
d = create_tegra_pcie_debufs_file("apply_link_speed",
&apply_link_speed_fops, pcie->debugfs,
(void *)pcie);
2.17.1
