Intel 9260 WiFi on jetson nano / jetbot
Thanks @yoshio.shinose, it certainly helped me.
To further elaborate on these instructions:
1.Make sure you do a clean install with your Jetson Nano
2.Download the latest L4T driver package for Jetson Nano. Can be found here: https://developer.nvidia.com/embedded/linux-tegra
3. Follow all steps in this website until you reach “Copy this patch” . Since that patch on that step has already been applied in the latest driver (right now 32.3.1), skip it. However, we still need to apply the bluetooth fixes. To do this:
a) Go to drivers/bluetooth/ and open ‘btusb.c’ to manually add:
{ USB_DEVICE(0x8087, 0x07dc), .driver_info = BTUSB_INTEL },
For example, looks like this:
 	{ USB_DEVICE(0x8087, 0x0a2a), .driver_info = BTUSB_INTEL },
 	{ USB_DEVICE(0x8087, 0x0a2b), .driver_info = BTUSB_INTEL_NEW },
        { USB_DEVICE(0x8087, 0x0025), .driver_info = BTUSB_INTEL_NEW },
 	{ USB_DEVICE(0x8087, 0x0aa7), .driver_info = BTUSB_INTEL },
b) Replace this line
*if* (ver.hw_variant != 0x0b && ver.hw_variant != 0x0c) {
With this line
*if* (ver.hw_variant != 0x0b && ver.hw_variant != 0x0c && ver.hw_variant != 0x12 ) {
  1. After applying the fixes for bluetooth, proceed with all step starting from “Execute the following commands to create the .config file:” on the website.
Just a note that this is for driver package 32.3.1. I hope the bluetooth fix will apply in future packages
@Caldarie - when I follow the blog and use:
make ARCH=arm64 O=kernel_build tegra_defconfig
I get an error about drivers/net/ethernet/nvidia/Kconfig:30: can't open file "drivers/net/ethernet/nvidia/eqos/Kconfig". It seems it is an old problem (R32.1 TX2 how can I build extra module in the tegra device) - are you sure you did everything in order and it worked?
I can fix it by using /usr/src instead of /home for the kernel source like in that post, but then I cannot compile make defconfig-iwlwifi-public and it says I don’t have the kernel headers installed.
Also the a) Go to drivers/bluetooth/ and open ‘btusb.c’ to manually add: part is wrong no? You must add it, but not where your example shows. The example seems to be from the blacklist where it already exists - shouldn’t it be removed from it as well?
Also, if I don’t need bluetooth but only wifi I still need to do this right? On Jetpack4.3 the wifi module didn’t seem to be working out of the box so I assumed that I had to recompile the modules.
Hi @Dalus
I believe jet pack 4.3 has already been patched, so there’s no need to recompile it for wifi. I haven’t done this myself, but I think that all you need to do after a fresh install is to just install iwlwifi. Correct me if I’m wrong
Hi @Dalus
Have you solved your issue yet?
For those who only need to install wifi (with no bluetooth), all you need to do after fresh install is:
  1. Clone, build and install the iwlwifi backport:
$ cd ~
$ git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git
$ cd backport-iwlwifi
$ make defconfig-iwlwifi-public
$ sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config
$ make -j4
$ sudo make install
  1. Clone the linux-firmware git repo and copy relevant files to the system:
$ cd ~
$ git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
$ cd linux-firmware
$ sudo cp iwlwifi-9260* /lib/firmware
  1. Reboot your system:
$ sudo reboot
  1. After rebooting, please wait for a moment for wifi to kick in.
That’s it. No need to recompile at all. Just install iwlwifi backport and you’re all set. (Just tested this with a clean install on my jetson nano, and can confirm it works fine)
Thank your for the detailed answer. Sadly it still doesn’t work for me. The issue could be a custom BSP because I use production module with CTI Photon board. I don’t have the devboard right now for a sanity check to see if that is the issue.
I can detect the hardware, but ifconfig doesn’t show the interface and ubuntu wifi manager doesn’t show anything either.
$ sudo lshw -C network
  *-network
       description: Network controller
       product: Wireless-AC 9260
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 29
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix cap_list
       configuration: driver=iwlwifi latency=0
       resources: irq:83 memory:13000000-13003fff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: eth0
       version: 19
       serial: 00:04:4b:ea:2a:64
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.045.08-NAPI duplex=full ip=192.168.89.252 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:406 ioport:1000(size=256) memory:20004000-20004fff memory:20000000-20003fff
  *-network:0 DISABLED
       physical id: 3
       logical name: dummy0
       serial: 3a:82:1d:36:8e:1a
       capabilities: ethernet physical
       configuration: broadcast=yes driver=dummy driverversion=1.0
  *-network:1
       physical id: 4
       logical name: rndis0
       serial: ca:a5:a8:68:35:ad
       configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc link=no multicast=yes
  *-network:2
       physical id: 5
       logical name: usb0
       serial: ca:a5:a8:68:35:af
  *-network:3 DISABLED
       physical id: 6
       logical name: l4tbr0
       configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=192.168.55.1 link=no multicast=yes
Jetpack is 4.3 and kernel:
$ uname -r
4.9.140-tegra
I installed everything:
$ ls /lib/firmware/ | grep 9260
iwlwifi-9260-th-b0-jf-b0-33.ucode
iwlwifi-9260-th-b0-jf-b0-34.ucode
iwlwifi-9260-th-b0-jf-b0-38.ucode
iwlwifi-9260-th-b0-jf-b0-41.ucode
iwlwifi-9260-th-b0-jf-b0-43.ucode
iwlwifi-9260-th-b0-jf-b0-46.ucode
I also tried: sudo update-initramfs -u
I hope there is an easy thing I missed, but I don’t think so. There are any tags for the git repo’s or just use master? Because I just copied what you wrote.
I personally need this for a wifi hotspot - if that is working with this module is also unknown. :( I guess I will need to find the “official” one again, but that is harder to get.
Hi @Dalus,
The good news is that your system at least detects the wifi adapter. So don’t give up just yet.
Have you tried updating the drivers with:
sudo apt update
sudo apt upgrade
Forgot to mention that before I installed wlfwifi, that I updated my drivers first. I believe this should Update the neccessary drivers/dependencies.
If all fails, all I can think of left is to go for wifi adapters that have no issue, i.e. the 8265. Or wait out for an update.
I ran:
sudo apt update
sudo apt upgrade
Sadly upgrade didn’t fix this.
This is what dmesg shows me:
[   65.944538] Timeout waiting for hardware access (CSR_GP_CNTRL 0xffffffff)
[   65.945020] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.945068] ------------[ cut here ]------------
[   65.945461] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.945512] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.945560] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.945609] pcieport 0000:00:01.0: broadcast error_detected message
[   65.945647] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.945688] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.946047] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.946092] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.946134] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.946178] pcieport 0000:00:01.0: broadcast error_detected message
[   65.946208] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.946248] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[   65.946312] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.946352] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.946388] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.946429] pcieport 0000:00:01.0: broadcast error_detected message
[   65.946457] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.946493] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.946564] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.946602] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.946637] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.946679] pcieport 0000:00:01.0: broadcast error_detected message
[   65.947189] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.947232] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.947328] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.947370] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.947411] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.947473] pcieport 0000:00:01.0: broadcast error_detected message
[   65.947503] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.947541] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[   65.947607] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.947681] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.947719] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.947778] pcieport 0000:00:01.0: broadcast error_detected message
[   65.947809] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.947846] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.947917] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.947960] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.947997] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.948057] pcieport 0000:00:01.0: broadcast error_detected message
[   65.948088] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.948128] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.948199] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.948239] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.948277] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.948338] pcieport 0000:00:01.0: broadcast error_detected message
[   65.948368] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.948405] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.948476] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.948516] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.948555] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.948596] pcieport 0000:00:01.0: broadcast error_detected message
[   65.948627] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.948665] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.948739] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.948781] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.948819] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.948860] pcieport 0000:00:01.0: broadcast error_detected message
[   65.948889] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.948926] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.948998] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.949038] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.949076] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.949154] pcieport 0000:00:01.0: broadcast error_detected message
[   65.949185] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.949224] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.949295] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.949336] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.949374] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.949415] pcieport 0000:00:01.0: broadcast error_detected message
[   65.949446] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.949485] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.949556] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.949596] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.949633] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.949675] pcieport 0000:00:01.0: broadcast error_detected message
[   65.949704] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.949743] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.949841] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.949881] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.949919] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.949960] pcieport 0000:00:01.0: broadcast error_detected message
[   65.949991] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.950028] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.950100] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.950136] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.950168] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.950208] pcieport 0000:00:01.0: broadcast error_detected message
[   65.950237] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.950271] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.950341] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.950398] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.950432] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.950472] pcieport 0000:00:01.0: broadcast error_detected message
[   65.950499] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.950534] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.950605] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.950641] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.950657] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.950675] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951201] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951212] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951235] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951243] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951253] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951263] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951270] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951278] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951297] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951305] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951313] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951324] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951330] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951339] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951360] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951369] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951378] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951389] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951396] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951406] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951428] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951438] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951447] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951459] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951466] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951476] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951499] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951509] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951519] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951531] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951539] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951550] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951574] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951585] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951594] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951607] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951615] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951625] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951650] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951661] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951671] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951684] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951693] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951703] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951728] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951739] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951750] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951763] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951772] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951783] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951808] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951820] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951831] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951845] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951854] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951865] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.951891] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.951940] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.951952] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.951966] pcieport 0000:00:01.0: broadcast error_detected message
[   65.951975] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.951987] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952013] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952025] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952036] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952050] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952059] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952071] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952097] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952112] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952125] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952145] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952155] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952168] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952199] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952213] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952225] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952245] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952255] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952268] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952299] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952313] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952325] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952345] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952355] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952368] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952399] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952413] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952425] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952445] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952455] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952468] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952499] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952513] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952525] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952545] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952555] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952568] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952600] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952613] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952625] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952645] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952656] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952668] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952699] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952713] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952726] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952745] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952755] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952768] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952799] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952813] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952825] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952845] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952855] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952868] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952899] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.952913] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.952926] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.952945] pcieport 0000:00:01.0: broadcast error_detected message
[   65.952955] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.952968] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.952999] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953013] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953025] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953045] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953056] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953068] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953094] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953106] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953117] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953131] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953140] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953152] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953177] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953189] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953200] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953214] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953223] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953235] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953261] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953273] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953284] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953298] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953307] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953319] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953344] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953356] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953368] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953381] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953390] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953402] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953427] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953440] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953450] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953464] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953473] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953485] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953511] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953523] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953533] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953547] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953556] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953568] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953594] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953606] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953617] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953631] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953640] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953651] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953677] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953689] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953700] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953714] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953723] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953734] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953760] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953772] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953794] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953808] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953817] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953829] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953855] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953867] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953878] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953892] pcieport 0000:00:01.0: broadcast error_detected message
[   65.953901] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.953918] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.953949] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.953963] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.953976] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.953995] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954006] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954018] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954049] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954063] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954075] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954095] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954105] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954118] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954149] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954162] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954175] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954195] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954205] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954218] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954250] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954263] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954276] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954295] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954305] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954318] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954349] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954363] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954375] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954395] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954405] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954418] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954449] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954463] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954475] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954494] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954504] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954517] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954548] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954561] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954574] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954594] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954604] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954616] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954648] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954661] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954674] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954820] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954832] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954847] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954878] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954890] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954898] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954908] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954913] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954920] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954934] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954939] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954944] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954951] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954955] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954960] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.954974] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.954979] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.954983] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.954990] pcieport 0000:00:01.0: broadcast error_detected message
[   65.954994] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.954999] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955013] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955018] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955022] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955029] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955032] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955037] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955050] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955055] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955059] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955082] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955086] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955091] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955104] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955108] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955112] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955118] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955122] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955127] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955139] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955144] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955148] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955154] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955158] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955176] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955189] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955194] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955199] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955205] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955209] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955213] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955226] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955231] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955236] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955242] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955246] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955251] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955265] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955270] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955275] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955282] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955286] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955291] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955305] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955310] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955316] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955323] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955329] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955336] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955351] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955358] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955364] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955374] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955379] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955386] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955401] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955408] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955414] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955424] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955430] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955436] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955453] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955461] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955469] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955480] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955486] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955493] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955510] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955518] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955525] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955536] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955542] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955549] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955567] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955575] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955581] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955593] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955599] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955606] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955623] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955631] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955638] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955649] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955655] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955662] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955680] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955688] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955695] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955706] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955712] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955720] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955738] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955746] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955753] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955765] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955771] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955779] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955798] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955806] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955813] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955825] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955832] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955839] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955858] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955866] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955872] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955881] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955886] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955893] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955910] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955917] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955924] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955932] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955938] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955945] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.955961] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.955969] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.955975] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.955984] pcieport 0000:00:01.0: broadcast error_detected message
[   65.955989] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.955996] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956013] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956020] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956027] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956035] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956041] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956048] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956065] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956072] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956078] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956087] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956093] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956100] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956157] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956164] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956170] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956179] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956184] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956191] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956208] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956215] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956221] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956230] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956235] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956242] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956259] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956266] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956272] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956281] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956286] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956293] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956310] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956318] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956326] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956337] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956343] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956351] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956369] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956377] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956385] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956396] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956403] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956410] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956429] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956437] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956444] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956456] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956462] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956469] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956488] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956496] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956503] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956515] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956521] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956529] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956547] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956555] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956562] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956574] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956580] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956587] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956606] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956614] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956621] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956633] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956639] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956646] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956664] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956672] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956680] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956691] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956697] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956705] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956723] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956731] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956739] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956750] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956756] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956764] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956782] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956790] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956797] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956809] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956815] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956822] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956841] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956849] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956856] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956868] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956874] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956881] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956898] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956905] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956911] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956920] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956925] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956932] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.956949] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.956956] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.956962] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.956971] pcieport 0000:00:01.0: broadcast error_detected message
[   65.956976] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.956983] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.957000] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.957007] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.957013] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.957022] pcieport 0000:00:01.0: broadcast error_detected message
[   65.957027] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.957034] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.957053] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.957060] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.957066] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.957075] pcieport 0000:00:01.0: broadcast error_detected message
[   65.957080] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.957087] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0010
[   65.957104] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.957111] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.957117] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.957126] pcieport 0000:00:01.0: broadcast error_detected message
[   65.957131] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.957138] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[   65.957151] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.957158] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.957165] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.957173] pcieport 0000:00:01.0: broadcast error_detected message
[   65.957179] pcieport 0000:00:01.0: AER: Device recovery failed
[   65.957186] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0010
[   65.957199] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[   65.957206] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[   65.957212] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[   65.957221] pcieport 0000:00:01.0: broadcast error_detected message
[   65.957226] pcieport 0000:00:01.0: AER: Device recovery failed
[   68.670912] WARNING: CPU: 1 PID: 6141 at /home/zpiic/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2126 iwl_trans_pcie_grab_nic_access+0x17c/0x248 [iwlwifi]
[   68.686617] Modules linked in: iwlmvm(O+) mac80211(O) btusb btrtl btbcm btintel iwlwifi(O) zram cfg80211(O) spidev overlay compat(O) nvgpu bluedroid_pm ip_tables x_tables
[   68.687089] CPU: 1 PID: 6141 Comm: modprobe Tainted: G           O    4.9.140-tegra #1
[   68.687119] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[   68.687158] task: ffffffc0f7c2e200 task.stack: ffffffc0f4cac000
[   68.688022] PC is at iwl_trans_pcie_grab_nic_access+0x17c/0x248 [iwlwifi]
[   68.688873] LR is at iwl_trans_pcie_grab_nic_access+0x17c/0x248 [iwlwifi]
[   68.688911] pc : [<ffffff80011f5a54>] lr : [<ffffff80011f5a54>] pstate: 404000c5
[   68.688937] sp : ffffffc0f4caf980
[   68.688967] x29: ffffffc0f4caf980 x28: ffffffc0c17aa760
[   68.689045] x27: ffffffc0c17aa798 x26: ffffff80012235d8
[   68.689116] x25: ffffffc0c17aa908 x24: 0000000000000001
[   68.689184] x23: 0000000000000001 x22: 00000000ffffffff
[   68.689251] x21: ffffffc0f4caf9e8 x20: ffffffc0e1782aac
[   68.689317] x19: ffffffc0e1780018 x18: 0000000000000030
[   68.689382] x17: 0000000000000001 x16: 0000000000000007
[   68.689446] x15: 0000000000000008 x14: ffffff800a117260
[   68.689512] x13: 0000000000000000 x12: 0000000000000006
[   68.689578] x11: 00000000000016a0 x10: 0000000000000002
[   68.689644] x9 : 00000000000016a0 x8 : 0000000000000001
[   68.689709] x7 : 0000000000000000 x6 : 000000000951fa6b
[   68.689775] x5 : 0000000000000000 x4 : ffffffc0fefe6be8
[   68.689840] x3 : ffffffc0fefe6be8 x2 : 0000000000000007
[   68.689904] x1 : ffffffc0f7c2e200 x0 : 000000000000003d
[   68.689995] ---[ end trace a4b7b79e80e44998 ]---
[   68.694698] Call trace:
[   68.695573] [<ffffff80011f5a54>] iwl_trans_pcie_grab_nic_access+0x17c/0x248 [iwlwifi]
[   68.696635] [<ffffff80011d88d0>] iwl_read_prph+0x30/0x88 [iwlwifi]
[   68.697730] [<ffffff80013643f8>] iwl_mvm_load_ucode_wait_alive+0x378/0x418 [iwlmvm]
[   68.698790] [<ffffff8001365100>] iwl_run_init_mvm_ucode+0x70/0x328 [iwlmvm]
[   68.699850] [<ffffff8001370dbc>] iwl_op_mode_mvm_start+0x6b4/0xa58 [iwlmvm]
[   68.700711] [<ffffff80011d9da0>] _iwl_op_mode_start.isra.1+0x50/0x80 [iwlwifi]
[   68.701552] [<ffffff80011da08c>] iwl_opmode_register+0x84/0xe0 [iwlwifi]
[   68.702612] [<ffffff800124603c>] __init_backport+0x3c/0x80 [iwlmvm]
[   68.702681] [<ffffff8008083afc>] do_one_initcall+0x44/0x130
[   68.702742] [<ffffff80081c0204>] do_init_module+0x64/0x1b0
[   68.702796] [<ffffff8008156ddc>] load_module+0xfcc/0x12f0
[   68.702842] [<ffffff80081573f8>] SyS_finit_module+0x108/0x118
[   68.702885] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
[   68.702970] iwlwifi 0000:01:00.0: iwlwifi transaction failed, dumping registers
[   68.710376] iwlwifi 0000:01:00.0: iwlwifi device config registers:
[   68.717288] iwlwifi 0000:01:00.0: 00000000: 25268086 00100000 02800029 00000000 00000004 00000000 00000000 00000000
[   68.727820] iwlwifi 0000:01:00.0: 00000020: 00000000 00000000 00000000 00148086 00000000 000000c8 00000000 00000100
[   68.738347] iwlwifi 0000:01:00.0: 00000040: 00028010 10008ec0 00100c10 0045e812 10110000 00000000 00000000 00000000
[   68.748865] iwlwifi 0000:01:00.0: 00000060: 00000000 00080812 00000005 00000000 00010002 00000000 00000000 00000000
[   68.759384] iwlwifi 0000:01:00.0: 00000080: 000f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[   68.769899] iwlwifi 0000:01:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   68.780415] iwlwifi 0000:01:00.0: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[   68.790925] iwlwifi 0000:01:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   68.801438] iwlwifi 0000:01:00.0: 00000100: 14c10001 00004000 00000000 00462031 00000000 00002000 0000000e 00000000
[   68.811950] iwlwifi 0000:01:00.0: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   68.822465] iwlwifi 0000:01:00.0: 00000140: 14c00000 ff000000 000000ff 15410018 00000000 0001001e 00481e1f 00000000
[   68.832971] iwlwifi 0000:01:00.0: iwlwifi device memory mapped registers:
[   68.839898] iwlwifi 0000:01:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[   68.850417] iwlwifi 0000:01:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[   68.860932] iwlwifi 0000:01:00.0: iwlwifi device AER capability structure:
[   68.867976] iwlwifi 0000:01:00.0: 00000000: 14c10001 00004000 00000000 00462031 00002000 00002000 0000000e 00000000
[   68.878475] iwlwifi 0000:01:00.0: 00000020: 00000000 00000000 00000000
[   68.885088] iwlwifi 0000:01:00.0: iwlwifi parent port (0000:00:01.0) config registers:
[   68.893559] iwlwifi 0000:00:01.0: 00000000: 0fae10de 40100107 060400a1 00010000 00000000 00000000 00010100 200001f1
[   68.904079] iwlwifi 0000:00:01.0: 00000020: 13001300 0001fff1 00000000 00000000 00000000 00000040 00000000 00000153
[   68.914595] iwlwifi 0000:00:01.0: 00000040: 0000480d 000010de f8035001 00000000 00826005 00000000 00000000 00000000
[   68.925110] iwlwifi 0000:00:01.0: 00000060: a8008008 fee00000 00000000 00000000 00000000 00000000 00000000 00000000
[   68.935629] iwlwifi 0000:00:01.0: 00000080: 01420010 00008020 0002281f 00313c42 70110042 00000000 014801c0 00000008
[   68.946142] iwlwifi 0000:00:01.0: 000000a0: 00000000 00000813 00000400 00000000 00010002 00000000 00000000 00000000
[   68.956653] iwlwifi 0000:00:01.0: 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   68.967165] iwlwifi 0000:00:01.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   68.977680] iwlwifi 0000:00:01.0: 00000100: 14010001 00004000 00000000 00062011 00000000 00002000 000000ae 0a000001
[   68.988195] iwlwifi 0000:00:01.0: 00000120: 0000a010 00100d24 00000000 00000007 00000000 00100000 00000000 00000000
[   68.998709] iwlwifi 0000:00:01.0: 00000140: 0001001e 00391e1f 60031e0c 00000039 00000000 00000000 00000000 00000000
[   69.009221] iwlwifi 0000:00:01.0: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   69.019737] iwlwifi 0000:00:01.0: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   69.030251] iwlwifi 0000:00:01.0: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   69.040764] iwlwifi 0000:00:01.0: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   69.051274] iwlwifi 0000:00:01.0: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   69.061771] iwlwifi 0000:00:01.0: 00000200: 00000000 00000000 00000000
[   69.068387] iwlwifi 0000:01:00.0: iwlwifi root port (0000:00:01.0) AER cap structure:
[   69.076364] iwlwifi 0000:00:01.0: 00000000: 14010001 00004000 00000000 00062011 00000000 00002000 000000ae 0a000001
[   69.086873] iwlwifi 0000:00:01.0: 00000020: 0000a010 00100d24 00000000 00000007 00000000 00100000
[   69.096901] edid invalid
[   69.115324] edid invalid
[   69.117880] edid invalid
[   69.118839] iwlwifi 0000:01:00.0: SecBoot CPU1 Status: 0x5a5a5a5a, CPU2 Status: 0x5a5a5a5a
[   69.138326] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[   69.138339] edid invalid
[   69.139122] iwlwifi 0000:01:00.0: Not valid error log pointer 0x00000000 for Init uCode
[   69.152273] edid invalid
[   69.156435] edid invalid
[   69.157069] iwlwifi 0000:01:00.0: Failed to start INIT ucode: -110
[   69.172225] edid invalid
[   69.176404] edid invalid
[   69.192204] edid invalid
[   69.196375] edid invalid
[   69.203280] tegradc tegradc.0: hdmi: edid read failed
[   69.208375] tegradc tegradc.0: hdmi: using fallback edid
[   69.208496] tegradc tegradc.0: blank - powerdown
[   69.216498] tegradc tegradc.0: unblank
[   69.247275] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[   69.247369] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[   69.248377] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[   69.248384] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[   69.255117] extcon-disp-state extcon:disp-state: cable 47 state 1
[   69.255119] Extcon AUX1(HDMI) enable
[   69.255253] extcon-disp-state extcon:disp-state: cable 51 state 1
[   69.255256] Extcon HDMI: HPD enabled
[   69.255278] tegradc tegradc.0: hdmi: plugged
[   69.272997] tegradc tegradc.0: blank - powerdown
[   69.365468] extcon-disp-state extcon:disp-state: cable 47 state 0
[   69.365471] Extcon AUX1(HDMI) disable
[   69.424240] tegradc tegradc.0: blank - powerdown
[   69.424261] tegradc tegradc.0: unblank
[   69.434722] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[   69.434811] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[   69.435883] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[   69.435891] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[   69.442498] extcon-disp-state extcon:disp-state: cable 47 state 1
[   69.442500] Extcon AUX1(HDMI) enable
[   69.445375] tegradc tegradc.0: unblank
[   70.980721] iwlwifi 0000:01:00.0: Failed to run INIT ucode: -110
It shows iwlwifi stacktrace so the driver crashed it seems. It also prints hardware as “NVIDIA Jetson Nano Developer Kit (DT)” but I don’t have the devkit so that is weird.
The error lines is about a timeout. It is possible that I have a hardware problem?
Hello everyone,
Great news, I got the Intel 9260 WIFI and Bluetooth working on my Jetson Nano by doing the following:
  1. Get the latest version of Jetpack and fresh image on your nano
    2.Clone and build and install the iwlwifi backport:
cd ~
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git
cd backport-iwlwifi
make defconfig-iwlwifi-public
sed -i ‘s/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/’ .config
make -j4
sudo make install
Clone the linux-firmware git repo and copy relevant files to the system:
cd ~
git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
cd linux-firmware
sudo cp iwlwifi-9260* /lib/firmware
sudo reboot
3.Install BTUSB from https://github.com/yoffy/jetson-nano-kernel/blob/master/install-btusb.sh
Reboot and you should have both WIFI and Bluetooth working.
Enjoy!
Hi, I tried this in an attempt to get the Intel 8265 to work on the nano. I also have a 9260 but it’s not suitable for me as I need dual mode (AP+STA) communication, which the 9260 does not support. I did what you suggested (copied the iwlwifi-8265* files instead) but I still get errors from the driver (as I did before):
[ 70.811218] iwlwifi 0000:01:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2 [ 70.820903] iwlwifi 0000:01:00.0: Falling back to user helper
then later:
[  160.873301] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[  160.883595] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00000001/00002000
Registering mobile devices [][  160.892180] pcieport 0000:00:01.0:    [ 0] Receiver Error         (First)
[  160.901253] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[  160.913008] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[  160.921497] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[  160.928325] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[  160.940062] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[  160.948450] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
[  160.955275] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[  160.967014] pcieport 0000:00:01.0:   device [10de:0fae] error status/mask=00004000/00000000
[  160.975406] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
and then a bunch of exceptions:
[  168.176135] iwlwifi 0000:01:00.0: Error sending STATISTICS_CMD: time out after 2000ms.
[  168.184067] iwlwifi 0000:01:00.0: Current CMD queue read_ptr 199 write_ptr 200
[  168.211127] ------------[ cut here ]------------
[  168.216816] WARNING: CPU: 0 PID: 4280 at /home/ubuntu/Documents/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2126 iwl_trans_pcie_grab_nic_access+0x17c/0x248 [iwlwifi]
[  168.237058] ---[ end trace 477c7113dd8777e0 ]---
[  168.255677] iwlwifi 0000:01:00.0: iwlwifi transaction failed, dumping registers
[  168.263083] iwlwifi 0000:01:00.0: iwlwifi device config registers:
[  168.270012] iwlwifi 0000:01:00.0: 00000000: 24fd8086 00100000 02800078 00000000 00000004 00000000 00000000 00000000
[  168.280542] iwlwifi 0000:01:00.0: 00000020: 00000000 00000000 00000000 10108086 00000000 000000c8 00000000 00000100
[  168.291067] iwlwifi 0000:01:00.0: 00000040: 00020010 10008ec0 001b0c10 0045e811 10110000 00000000 00000000 00000000
I don’t care in particular which network card I use, I’ll settle for anything that runs on the nano and supports simultaneous AP/STA modes.
Any recommendations?
Do the following:
$ git clone https://github.com/yoffy/jetson-nano-kernel.git
Build and install to SD card:
$ cd jetson-nano-kernel
$ ./build-kernel.sh
$ ./install-kernel.sh
$ ./install-iwlwifi.sh
$ sudo reboot
and tell me what you get.
Thanks @nooblecybot - I get a compilation error on the backport-iwlwifi:
    CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/fils_aead.o
cc1: some warnings being treated as errors
scripts/Makefile.build:335: recipe for target '/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/mvm/fw.o' failed
make[9]: *** [/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/mvm/fw.o] Error 1
make[9]: *** Waiting for unfinished jobs....
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/cfg.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/ethtool.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/rx.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/wireless/of.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/spectmgmt.o
scripts/Makefile.build:649: recipe for target '/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/mvm' failed
make[8]: *** [/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi/mvm] Error 2
scripts/Makefile.build:649: recipe for target '/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi' failed
make[7]: *** [/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel/iwlwifi] Error 2
scripts/Makefile.build:649: recipe for target '/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel' failed
make[6]: *** [/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless/intel] Error 2
scripts/Makefile.build:649: recipe for target '/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless' failed
make[5]: *** [/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/drivers/net/wireless] Error 2
make[5]: *** Waiting for unfinished jobs....
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/tx.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/wireless/debugfs.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/wireless/shipped-certs.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/key.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/wireless/extra-certs.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/util.o
  LD [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/wireless/cfg80211.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/wme.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/chan.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/trace.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/mlme.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/tdls.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/ocb.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/led.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/debugfs.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/debugfs_sta.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/debugfs_netdev.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/debugfs_key.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/pm.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/rc80211_minstrel.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/rc80211_minstrel_ht.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/rc80211_minstrel_debugfs.o
  CC [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/rc80211_minstrel_ht_debugfs.o
  LD [M]  /home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi/net/mac80211/mac80211.o
Makefile:1629: recipe for target '_module_/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi' failed
make[4]: *** [_module_/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi] Error 2
Makefile.build:13: recipe for target 'modules' failed
make[3]: *** [modules] Error 2
Makefile.real:100: recipe for target 'modules' failed
make[2]: *** [modules] Error 2
Makefile:40: recipe for target 'modules' failed
make[1]: *** [modules] Error 2
Makefile:30: recipe for target 'default' failed
make: *** [default] Error 2
make: Leaving directory '/home/ubuntu/jetson-nano-kernel/workdir/backport-iwlwifi'
Did you start with a fresh install of Jetpack?
yes
Thanks @nooblecybot! Worked for me. I have both WiFi and BT working on my 9260 on JetPack 4.4. I’m still amazed that after all this time, they haven’t added support for the 9260 directly to L4T. Ah well.
I will just add that you might have wanted to break down step 3 a little bit further since it wasn’t clear you needed the entire repo:
cd ~
./install-btusb.sh
sudo reboot
Otherwise, I’m up and running and happy. Just in time for me to move on to my Xavier NX, which arrives on Wednesday. :p Thanks a bunch for sharing!
I’m facing this issue and followed the steps + patch the system but still facing the same issue for the last few days. And in the solution, it mentioned that it will be in the next release, but I can’t see it. What should I do?
Installed official SD card image, applied updates through apt, followed @nooblecybot’s instructions for backported iwlwifi, and everything seemed to compile just fine. I did notice this warning however:
WARNING: "hash_algo_name" [/home/dan/backport-iwlwifi/compat/compat.ko] undefined!
Rebooted system. No module loaded. Try to load the module via modprobe and get the following:
dan@JetsonNano:~$ sudo modprobe iwlwifi
modprobe: ERROR: could not insert 'iwlwifi': Unknown symbol in module, or unknown parameter (see dmesg)
dmesg shows the following:
[  475.574856] compat: Unknown symbol hash_algo_name (err 0)
Output from lspci -kkv:
01:00.0 Network controller: Intel Corporation Wireless-AC 9260 (rev 29)
         Subsystem: Intel Corporation Device 0014
         Flags: fast devsel, IRQ 84
         Memory at 13000000 (64-bit, non-prefetchable) [disabled] [size=16K]
         Capabilities: [c8] Power Management version 3
         Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
         Capabilities: [40] Express Endpoint, MSI 00
         Capabilities: [80] MSI-X: Enable- Count=16 Masked-
         Capabilities: [100] Advanced Error Reporting
         Capabilities: [14c] Latency Tolerance Reporting
         Capabilities: [154] L1 PM Substates
         Kernel modules: iwlwifi
Nothing shows up when running dmesg | grep iwl.
I feel like I’m missing something simple/straightforward… any help would be hugely appreciated!
Anyone tried using Intel 9560 WiFi with the Jetpack 4.4 for jetson nano?
Any issue with getting it to work?
