6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: RTX PRO 5000 Blackwell
- Driver Version: 580.142
Topic Description
Detailed Description
I am using a RTX lidar model with single emitter being shot at a wall at 4.0 m distance. The intensity keeps varying across the frames. The simulator should produce the physical link-budget output (range, defocus, incidence angle, material reflectance) repeatably - i.e., I want intensity that varies with the scene, not from a stochastic component re-rolled every frame.
Setup
omni:sensor:Core:rayType = “IDEALIZED”
omni:sensor:Core:azimuthErrorStd = 0.0
omni:sensor:Core:elevationErrorStd = 0.0
omni:sensor:Core:intensityProcessing = “RAW”
Target authored with the SimReady non-visual material schema:
omni:simready:nonvisual:base = “aluminum”
omni:simready:nonvisual:coating = “paint”
omni:simready:nonvisual:attributes = “none”
Resolves to materialId = 257 end-to-end (verified via outputMaterialId=True on IsaacCreateRTXLidarScanBuffer). USD-attribute resolver is enabled via /rtx/materialDb/nonVisualMaterialCSV/enabled = False.
Questions
Is there a supported way to disable the randomState / cuRand variance injection in the stock DefaultMaterial / CoreMaterial / CompositeMaterial / RetroReflectiveMaterial BSDFs? Is ConstantMaterial expected to be available at runtime in 5.1, or is it strictly a build-only debug BSDF? Here is the full USDA File:
Full USDA
#usda 1.0
defaultPrim = “SingleBeamFMCW”
upAxis = “Z”
metersPerUnit = 1.0
def OmniLidar “SingleBeamFMCW” (
prepend apiSchemas = [“OmniSensorGenericLidarCoreAPI”]
# Required xform ops so hydra can compute the lidar camera matrix.
double3 xformOp:translate = (0, 0, 0)
quatd xformOp:orient = (1, 0, 0, 0)
double3 xformOp:scale = (1, 1, 1)
uniform token
xformOpOrder = [“xformOp:translate”, “xformOp:orient”, “xformOp:scale”]
# ----- Scan topology --------------------------------------------------
token omni:sensor:Core:scanType = "SOLID_STATE"
uint omni:sensor:Core:numberOfEmitters = 4
uint omni:sensor:Core:numberOfChannels = 4
uint omni:sensor:Core:numLines = 1
uint[] omni:sensor:Core:numRaysPerLine = [4]
uint omni:sensor:Core:scanRateBaseHz = 60
uint omni:sensor:Core:reportRateBaseHz = 60
uint omni:sensor:Core:stateResolutionStep = 1
token omni:sensor:Core:rotationDirection = "CW"
# Physical Gaussian profile so spot size, defocus, and aperture truncation
# actually feed the link budget. Requires Msquared + divergence values below.
token omni:sensor:Core:rayType = "IDEALIZED"
float omni:sensor:Core:beamWaistHorM = 0.002
float omni:sensor:Core:beamWaistVerM = 0.002
# ----- Range ----------------------------------------------------------
float omni:sensor:Core:nearRangeM = 0.5
float omni:sensor:Core:farRangeM = 200.0
float omni:sensor:Core:rangeResolutionM = 0.0002
float omni:sensor:Core:rangeAccuracyM = 0.00
uint omni:sensor:Core:maxReturns = 1
uint omni:sensor:Core:rangeCount = 1
float[] omni:sensor:Core:rangesMinM = [0.5]
float[] omni:sensor:Core:rangesMaxM = [200.0]
# ----- FMCW optical ---------------------------------------------------
# 10 mW average per emitter is realistic for an eye-safe 1550 nm coherent
# FMCW channel (e.g. Aeva / SiLC class chips run 10-40 mW per lane).
float omni:sensor:Core:avgPowerW = 0.020
float omni:sensor:Core:waveLengthNm = 1550.0
# Effective measurement-window width. For coherent FMCW the receiver is
# not pulsed, but this controls the per-shot SNR / range-resolution floor.
uint omni:sensor:Core:pulseTimeNs = 5
# Beam quality. Single-mode fiber laser is essentially TEM00 -> M^2 ~= 1.1.
float omni:sensor:Core:Msquared = 1.1
# Full-angle 1/e^2 divergence. 0.06 deg ~= 1 mrad, which gives a ~5 cm
# footprint at 50 m -- typical for a small solid-state FMCW unit.
float omni:sensor:Core:divergenceHorDeg = 0.06
float omni:sensor:Core:divergenceVerDeg = 0.06
# 10% reflectance still detectable at 250 m is a competitive (but not
# heroic) coherent-detection sensitivity curve.
float omni:sensor:Core:minReflectance = 0.1
float omni:sensor:Core:minReflectionRangeM = 250.0
# 25 mm receive aperture -- ~3x more collected photons than 14.5 mm.
float omni:sensor:Core:effectiveApertureSizeM = 0.02
# Focus near the middle of the useful range, not 16 cm in front of the
# sensor. Old 0.16 m left the wall at 5 m heavily defocused.
float omni:sensor:Core:focusDistM = 50.0
# InGaAs APD / coherent receiver QE at 1550 nm is typically 0.3-0.5.
float omni:sensor:Core:quantumEfficiency = 1.0
# ----- Angular noise (deterministic) ----------------------------------
# Small solid-state pointing jitter: ~0.01 deg std (~175 urad), which is
# at the floor of what good MEMS / OPA scanners achieve.
float omni:sensor:Core:azimuthErrorMean = 0.0
float omni:sensor:Core:azimuthErrorStd = 0.0
float omni:sensor:Core:elevationErrorMean = 0.0
float omni:sensor:Core:elevationErrorStd = 0.0
# ----- Intensity processing ------------------------------------------
# Keep the raw radiometric value so range, defocus, incidence and material
# actually move the intensity column. NORMALIZATION would mask all of it.
token omni:sensor:Core:intensityProcessing = "RAW"
token omni:sensor:Core:intensityMappingType = "LINEAR"
# ----- Output enables ------------------------------------------------
token omni:sensor:Core:auxOutputType = "FULL"
token omni:sensor:Core:outputFrameOfReference = "SENSOR"
bool omni:sensor:Core:skipDroppingInvalidPoints = true
# ----- Emitter line (azimuth = -1..+1 deg, elevation = 0) -------------
# 4 emitters evenly spaced across +/-1 deg (step = 2/3 deg). Fire times
# are evenly spaced across the 1/30 s = 33,333,333 ns scan period.
float[] omni:sensor:Core:emitterState:s001:azimuthDeg = [0.0, 0.0, 0.0, 0.0]
float[] omni:sensor:Core:emitterState:s001:elevationDeg = [0.0, 0.0, 0.0, 0.0]
uint[] omni:sensor:Core:emitterState:s001:fireTimeNs = [0, 10000, 20000, 30000]
uint[] omni:sensor:Core:emitterState:s001:channelId = [1, 2, 3, 4]
uint[] omni:sensor:Core:emitterState:s001:rangeId = [0, 0, 0, 0]
# bank == line index per emitter; must be < numLines. All 4 emitters are
# on the single line 0, so bank is all zeros.
uint[] omni:sensor:Core:emitterState:s001:bank = [0, 0, 0, 0]
# float[] omni:sensor:Core:emitterState:s001:distanceCorrectionM = [0.205, 0.205, 0.205, 0.205]
