Interesting - Nvidia RTX Ada 4000 RmInitAdapter failed when installed in a pci switch
I’m developing a pre-Si PCie Switch in emulation environment (FPGA) with a dedicated board that serves as a PCIe bridge connected to the emulator with RTL of the switch.
the GPU is Nvidia RTX 4000 Ada. the emulator is connected to a Supermicro X11DAi-N.
Nvidia Driver version is 550.107.02 on Fedora 37 system.
When the host boots, dmesg shows several issues with the GPU initialization process like: RmInitAdapter: Cannot initialize GSP firmware RM.
when the GPU is connected directly to the host - it works fine!
I’ve attached the dmesg , lspci dump of the GPU and the Nvidia debug log.
I think that maybe because the GPU is slow because its connected an emulator so there are issues with timeout…
Please help me figure this out!
gpu_debug_log.txt (405.5 KB)
gpu_lspci.txt (4.7 KB)
nvidia-bug-report.log.gz (2.8 MB)
This is the Jetosn forum which is not able to support your RTX 4000 Ada issue.
Sorry for that.
