Please let me know what is wrong in the following simple code:
Code:
attributes(global) subroutine saxpy(x,y,a)
implicit none
real,device :: x(:), y(:)
real,value :: a
integer :: i, n
n = size(x)
i = blockDim%x * (blockIdx%x - 1) + threadIdx%x
if (i <= n) y(i) = y(i) + a*x(i)
end subroutine saxpy
https://redtube.onl/ https://beeg.onl/ What you need to know about sex videos – Spanktube.vip
program testSaxpy
use cudafor
implicit none
integer, parameter :: N = 40000
real :: x(N), y(N), result(N), a
real, device :: x_d(N), y_d(N)
type(dim3) :: grid, tBlock
integer :: i
tBlock = dim3(256,1,1)
grid = dim3(ceiling(real(N)/tBlock%x),1,1)
a = 2.0
do i = 1,N
x(i) = float(i)
y(i) = 3.0*float(i)
enddo
result = a*x + y
x_d = x
y_d = y
call saxpy<<<grid, tBlock>>>(x_d,y_d,a)
y = y_d
write(,) 'Max error: ', maxval(abs(y-result))
end program testSaxpy
The error message is as follows:
0: copyout Memcpy (host=0x0x62b880, dev=0x0xf03d47200, size=160000) FAILED: 77(an illegal memory access was encountered)
Hi michealgimies,
CUDA Fortran device kernels typically need to have an interface.
Otherwise F77 calling conversion are used which will cause problems when passing in arrays.
While you could add an explicit interface block, the easiest thing to do is put saxpy in a module where an implicit interface is created.
% cat test.cuf
module saxpy_mod
contains
implicit none
real,value :: a
integer :: i, n
n = size(x)
end module saxpy_mod
program testSaxpy
use cudafor
use saxpy_mod
implicit none
integer :: i
a = 2.0
do i = 1,N
x(i) = float(i)
y(i) = 3.0*float(i)
enddo
result = a*x + y
x_d = x
y_d = y
y = y_d
write(*,*) 'Max error: ', maxval(abs(y-result))
% pgfortran test.cuf; a.out
Max error: 0.000000
Hope this helps,
Mat
