You say it compile with Visual Fortran, which Visual Fortran? Is is PGI Visual Fortran?
I am sorry but I am not familiar with the code/syntax you posted here.
Can you post a code that you compile with PGI compiler and gives the error you mentioned? I copy your code and it does not even compile past the first line due to syntax error.
The code is a snippet of a larger code, if you want I can email you the code; I’d rather not post the entire code here…if that’s ok with you…
You should have access to my email address, just remove erdc from the id. I’ll send you the code once I get your email, or if you post your email address here.
I have received your source code. I only need a file that give you the error message you mentioned. They are not standard fortran code. I mean, I will need a preprocessed source.
