What is the voltage level for PIN85 (Camera FSYNC#1) of the camera connector on the AGX Orin development kit carrier board?
Table 3-1 in the documentation shows 1.8V, but the measured voltage is 3.3V. Can it be changed to 1.8V?
Thank you!
3.3V is the correct voltage, also noted in the pinmux spreadsheet as below. The voltage cannot be programmed to 1.8V. I will mark this for correction in the Carrier Board Spec.
