My TX2-NX can capture interlaced video from ADV7281-M now, but the field order sometimes may be wrong:
the wrong order:
the right order:
How can I get the current field ID(even or odd) ?
Should I modify the driver code of tegra_channel_capture_frame_single_thread() in drivers/media/platform/tegra/camera/vi/vi4_fops.c ?
In https://ez.analog.com/video/f/q-a/9630/what-video-format-is-the-mipi-csi-2-output-from-adv728x-parts says:
in interlaced mode odd frames have one extra line than even frames.
so how can I get the actual line count in driver code?
or how can I get the frame number in frame start/end packets when one frame is captured?
hello jiakai1000,
please refer to Topic 73584 , and Topic 109266 we don’t support interlaced streams.
hello,
interlaced capture is supported, I have fixed the bug, below is patch:
diff --git a/drivers/media/platform/tegra/camera/vi/vi4_fops.c b/drivers/media/platform/tegra/camera/vi/vi4_fops.c
index 7b19eb1d3..b2866b4f5 100644
--- a/drivers/media/platform/tegra/camera/vi/vi4_fops.c
+++ b/drivers/media/platform/tegra/camera/vi/vi4_fops.c
for (i = 0; i < chan->valid_ports; i++)
@@ -620,11 +647,19 @@ static int tegra_channel_capture_frame_single_thread(
if (chan->capture_state == CAPTURE_IDLE)
chan->capture_state = CAPTURE_GOOD;
spin_unlock_irqrestore(&chan->capture_state_lock, flags);
+ if (chan->is_interlaced && chan->interlace_type == Interleaved) {
+ if (j == 0 && vb->sequence != BOTTOM_FIELD) {
+ dev_info(chan->vi->dev, "%s: adjust interlaced field\n", __func__);
+ j--;
system
Closed
February 1, 2023, 1:29am
7
