Hello, I’m trying to use the option --source-in-ptx to generate annotated code with ptx. Using the nvcc that came with CUDA 6, there are no annotations in the generated ptx file:
nvcc --source-in-ptx -ptx -I/usr/local/cuda/include -arch=compute_30 -code=sm_30 -c kernel.cu
However, using the same command with nvcc from CUDA 5.5 produced the expected results.
I’m running Ubuntu 12.04 x64.
Has there been a change to this option in CUDA 6?
