We are having intermittent boot crashes/issues.
Most of the time the system boots just fine, however - every once in while (estimation: every ~20/30 boot attempt or so) the boot fails and the system reboots.
Yes, AGX Xavier Industrial is correct. Should have added that information in the initial post, sorry.
Jetpack version 32.7.X
Not that we have seen, have booted/shutdown for more than 3500 times when booting from internal eMMC in a test rig without seeing this issue.
However, that setup was a bit different - with not using LUKS/squashfs etc.
Compliance test for all PCIe lanes to the NVME disk have been performed with more than satisfactory results.
Do you mean that you use LUKS/squashfs for NVMe but not for internal eMMC?
Correct.
Have you tried with the same setup for NVMe as internal eMMC?
It could help us narrow down the issue.
No. Sadly I don’t see how we could pull that of.
Could you also share the steps how you setup for NVMe and check if the issue could be reproduced on the devkit?
Also no, as we do not know the specifics of how it is set up (encryption, volumes, partitions, squashfs, EXT4 etc).
So I guess all these answers where no good. But it is the best I could give you.
Just as a thought - we know that the current setup uses the hardware de-/encryption on the AGX a lot. Are there any known limitations/bugs regarding that one?
So, how do you get this encrypted NVMe? Is that done by your customer?
We’ve not tested or verified such the use case of squashfs so that I’m asking for any setup or reproduce steps. It seems not the official supported feature.
Could you also help to provide the dtb in use for further check?
