Intermittent green/black vertical lines at 1/4, 1/2, 3/4 width on NvSIPL ISP2 output (DriveOS, ~3848×2168 NV12)
We are seeing intermittent vertical line artifacts on camera images in a DriveOS + NvSIPL pipeline. Below is a detailed description of the environment and the symptom. Any similar known issues or guidance would be greatly appreciated.
1. Environment / pipeline
  • Platform: NVIDIA DriveOS on DRIVE AGX / Orin
  • Camera frontend: Sensor → Deserializer (e.g. MAX967x class) → NVCSI / VI → NvSIPL
  • ISP output used by the application: ISP2
  • ISP / pipeline native image format: YUV420 NV12 (semi-planar: Y plane + interleaved UV plane), not RGB at the ISP output
  • Configured image size in our application: 3848 × 2168
  • Multi-camera: on the order of ~4 ISP2 streams per process; two processes may run on the same SoC and share ISP / VI / NVCSI resources (roughly ~8 concurrent 4K-class ISP2 streams in the worst case)
  • By default we disable ISP0/ISP1 and only enable ISP2 output
Data path after ISP:
Sensor / SerDes / NVCSI / VI
    → NvSIPL ISP2  (YUV420 NV12, \~3848×2168)
    → S1 application (Producer): full-frame copy of SIPL NvSciBufObj
    → NvSciStream C2C over PCIe
    → S2 application (Consumer): receive YUV NV12
    → YUV(NV12) → BGR conversion
    → JPEG / PNG save (artifacts observed on these saved images)
Important format note:
  • The camera pipeline output we consume is YUV (NV12) from the beginning.
  • BGR / JPEG exist only for display and storage after color conversion on S2.
  • The defect is observed on the saved images after YUV→BGR; we are trying to determine whether it already exists in the ISP2 NV12 buffer before C2C / before color conversion.
2. Symptom overview
  • Artifact type: very thin vertical lines superimposed on the image
  • Color:
    • Most common: green vertical segments
    • Sometimes: a black vertical line in the same frame (or in other abnormal frames)
  • Frequency: roughly on the order of ~0.5% of frames (order-of-magnitude estimate from field observation); highly intermittent, no reliable forced reproduction steps so far
  • Not every abnormal frame has the same number of lines: a frame may show one or multiple green segments; black lines are less frequent than green
3. Geometric / visual characteristics
  • The lines are perfectly straight and vertical (aligned with the image column axis)
  • They do not follow the fisheye / wide-angle lens geometric distortion of real scene content
    → they behave like digital / pipeline artifacts, not physical objects (cables, poles, etc.) in the scene
  • Horizontal position:
    • Appears roughly stable / periodic
    • Visually clustered near ~1/4, 1/2, and 3/4 of the image width
    • For an effective width of 3840, that corresponds approximately to:
      • x ≈ 960
      • x ≈ 1920
      • x ≈ 2880
    • Adjacent abnormal column positions are separated by about ~960 pixels
  • Vertical extent:
    • Often a short vertical segment, not always spanning the full image height
    • Frequently appears in the middle / lower region of the frame
    • Start/end rows can vary between occurrences
  • Line thickness: very narrow (appears close to 1-pixel-class / very thin column)
4. Color behavior (especially the green line)
  • The green line does not look like a constant pure-green overlay (fixed RGB green painted on top)
  • Along the line, brightness tends to follow the local background:
    • over bright areas → the green segment looks brighter
    • over dark areas → the green segment looks darker
  • This appearance is more consistent with a local chroma (U/V) anomaly on NV12, while luma (Y) may still be largely plausible, rather than a hard-coded green RGB draw
The black line, when present:
  • Also appears as a thin, perfectly vertical digital column
  • Looks closer to a dead / zeroed column (missing or cleared samples) than a chroma-tint line
5. Relationship to our application processing
  • Our S1 producer performs a full-frame copy from the SIPL buffer into the NvSciStream packet
  • We do not intentionally slice / process the image into width/4 vertical strips in application code
  • Despite that, the defect locations still align with quarter-width positions (~960-pixel period)
  • Classic row-major CPU memcpy tearing usually produces horizontal bands; this defect is vertical and position-periodic, which makes a simple full-frame row-copy tear a weaker explanation for the quarter-width pattern by itself
6. Resolution / geometry detail that may be relevant
  • Application constants use WIDTH = 3848, HEIGHT = 2168
  • The recurring X positions match 3840 / 4 = 960 better than 3848 / 4 = 962
  • Note that 3848 ≈ 960×4 + 8, i.e. there are 8 extra pixels beyond 3840
  • We therefore suspect a possible mismatch among:
    • active / effective width (e.g. 3840)
    • configured / reported width (3848)
    • PlaneWidth / PlanePitch / ROI / crop / padding
      but this is still an observation from the symptom pattern, not a proven root cause
7. Runtime / system context when observed
  • Observed on field / station monitoring images (ceiling-mounted wide-angle / fisheye-style views of an industrial platform)
  • Can appear while people / equipment are present in the scene; the lines cut across people, floor markings, and mechanical structures without respecting scene perspective
  • The issue can occur during otherwise “normal” streaming (not only during obvious camera bring-up / teardown)
  • We have separately seen ISP / ACP style failures on this platform (e.g. SIPL NOTIF_ERROR_ACP_PROCESSING_FAILURE), but we do not currently have a proven one-to-one correlation that every vertical-line frame is accompanied by an ACP/ISP failure notification
  • In other words: this can look like a silent image-quality defect, not always a hard pipeline error event
8. What the problem is / is not (based on observation only)
Consistent with observations:
  • Intermittent digital vertical artifacts on YUV-originated images
  • Strong spatial preference for quarter-width columns
  • Green line behaves like chroma-related corruption; black line like a cleared/dead column
Less consistent with a simple explanation from the visual evidence alone:
  • A real physical line in the scene (geometry / fisheye mismatch)
  • A permanent sensor dead column (because it is intermittent and length varies)
  • A UI / debug overlay drawn by the application at fixed HUD positions
9. Ask to the community / NVIDIA
  1. Has anyone seen similar intermittent vertical lines at regular ~width/4 boundaries on NvSIPL ISP2 NV12 output under DriveOS?
  2. For NV12, is a thin green vertical segment with background-dependent brightness a typical signature of corrupted UV at a fixed chroma column?
  3. Are there known issues or constraints around width vs pitch (e.g. 3848 vs 3840) that could produce periodic vertical chroma artifacts?
  4. Which DriveOS / NvSIPL / kernel logs are most relevant when the defect is mostly silent (no obvious ISP/ACP notification on every occurrence)?
We can share cropped sample images and more exact pixel coordinates / version strings if needed.
Thanks in advance for any help.
This forum is exclusively for developers who are part of the NVIDIA DRIVE® AGX SDK Developer Program | NVIDIA Developer . To post in the forum, please use an account associated with your corporate or university email address. This helps us ensure that the forum remains a platform for verified members of the developer program.
Hi, I’ve changed my email address to a corporate one, is it available?
Dear @Jiayu_Chu ,
Could you share details DRIVE OS release , camera module, nvsipl_camera command output log, syslog and dmesg(for application run), output image.
@SivaRamaKrishnaNV Thank you for your reply
We run with DriveOS 6.0.7.0, and 4 AR0820 cameras, and we got image like this.
Sorry, the issue was reproduced a few days ago, so I may only have some application logs left, but they do not seem to contain much useful information. Could you please let me know specifically which logs or information you need?
Dear @Jiayu_Chu ,
Could you please test with DOS 6.0.10 if it can be reproduced. DOS 6.0.7 is very old release.
Sorry, that may not be feasible. Our product is already in production and is currently running DRIVE OS 6.0.7. We also share the device with other projects, so changing the os version may not be possible in the short term.
Are there any known or potential issues with DRIVE OS 6.0.7? We also encounter eNotifyType: 204 from time to time. Could this issue also be related to the DRIVE OS version?
Hi,sorry to bother you, but is there any further information?
Dear @Jiayu_Chu ,
DOS 6.0.7 is not a DevZone release. I believe you must have got it via another support channel. Could you reach out to your NVIDIA representative to seek guidance on right support channel.
