Intermittent HEVC NVENC “Invalid Level” initialization errors – suspected uninitialized memory usage
We suspect use of some uninitialized memory within the nvcuvid library resulting in an invalid level error being returned at initialization of the nvenc video encoder.
Test environment
OS Ubuntu 24.04.3 LTS
Linux version Linux 6.8.0-85-generic #85-Ubuntu SMP PREEMPT_DYNAMIC Thu Sep 18 15:26:59 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
GPU NVIDIA GeForce RTX 5050
Driver 580.126.09 (also 580.76.05)
Docker OS Ubuntu 22.04
We want to encode the following video stream:
Codec hevc
Frame size 3840x2160
Scan type Progressive
Pixel format yuv 422 10 bit
Profile Main 4:2:2 10 (Rext)
Level 5.1
Tier High
Bitrate 80 Mbps
B-frame count 2
We’re using ffmpeg build based on tag 8.0.1 with nvenc enabled:
ffmpeg version n8.0.1 Copyright (c) 2000-2025 the FFmpeg developers
  built with gcc 11 (Ubuntu 11.4.0-1ubuntu1~22.04.2)
  configuration: --enable-nvenc
  libavutil      60.  8.100 / 60.  8.100
  libavcodec     62. 11.100 / 62. 11.100
  libavformat    62.  3.100 / 62.  3.100
  libavdevice    62.  1.100 / 62.  1.100
  libavfilter    11.  4.100 / 11.  4.100
  libswscale      9.  1.100 /  9.  1.100
  libswresample   6.  1.100 /  6.  1.100
We use the following (simplified) ffmpeg command line:
./ffmpeg -f lavfi -i testsrc2=size=3840x2160:rate=50 \
  -vf format=p210le \
  -t 10 \
  -c:v hevc_nvenc \
  -profile:v rext \
  -level:v 5.1 \
  -tier:v high \
  -pix_fmt p210le \
  -b:v 80M \
  -g 50 \
  -bf 2 \
  -preset p5 \
  -r 50 \
  -f mpegts output.ts \
  -y
When use the above command we get varying results.
Most of the times the nvenc InitializeEnoder returns an error:
[hevc_nvenc @ 0x4e42340] InitializeEncoder failed: invalid param (8): Invalid Level.
According to us the level 5.1 should be valid for this combination of parameters and it looks like a false report.
Sometimes it encodes without any problems.
We have also run the ffmpeg command via valgrind and forcing the allocated memory to be filled with 0xFF. In that case we get 100% occurance of the error.
valgrind \
  --tool=memcheck \
  --leak-check=no \
  --track-origins=no \
  --show-reachable=no \
  --undef-value-errors=no \
  --num-callers=4 \
  --malloc-fill=0xFF \
  --free-fill=0xFF \
When we force the memory to be set to 0x00 it will run succesfully every time.
With the valgrind memory check it also looks whether it has conditional jumps on uninitialized memory (allocated and used by libnvcuvid.so):
==136501== Conditional jump or move depends on uninitialised value(s)
==136501==    at 0x31751D3E: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x3174D977: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x317B557E: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x316C5D96: ??? (in /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.580.126.09)
==136501==  Uninitialised value was created by a stack allocation
==136501==    at 0x317516AF: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==
==136501==    at 0x31751D45: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==
==136501==    at 0x31751D6E: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==
==136501==    at 0x31751D76: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==
==136501==    at 0x3180446F: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x3180BABB: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x317BA28F: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x316D283F: ??? (in /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.580.126.09)
==136501==  Uninitialised value was created by a heap allocation
==136501==    at 0x4848899: malloc (in /usr/libexec/valgrind/vgpreload_memcheck-amd64-linux.so)
==136501==    by 0x317C9089: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
==136501==    by 0x317BA2C4: ??? (in /usr/lib/x86_64-linux-gnu/libnvcuvid.so.580.126.09)
Additional findings:
  • When we disable b-frames (-bf 0) then we don’t get this error.
  • When we set the level to auto the encoded output sometimes has level 6.2 and sometimes 5.1.
(Cautious) Conclusion:
  • It looks like the libnvcuvid.so library makes use of uninitialized memory. The video level calculation done by the library is affected by this calculation
Please let us know whether additional information is required.
Some additional information to informatio shared earlier.
It can also be reproduced outside docker container.
On Ubuntu 24.04.3 LTS we’ve build ffmpeg (compiled with gcc-13).
We’re using version 13.0.19.0 of the nv-codec-headers repo: Release Version 13.0.19.0 · FFmpeg/nv-codec-headers · GitHub
built with gcc 13 (Ubuntu 13.3.0-6ubuntu2~24.04)
Then on host OS we can reproduce the same error.
Thanks for reporting this issue with detailed steps to follow.
We are able to reproduce this issue (internally tracked as 5830620) and will work on this to get fixed in the future driver release. Thanks.
Hi Mandar,
Just for your awareness, and to prevent duplicate issues, we also created a bug report.
Best regards,
Rudy
