I have an intermittent issue with what seems to be the MIPI timing. Half the time I have a perfect picture using the Nvidia ISP that I can stream and responds well to changes in light, etc.
However the other half of the time it is like something gets “off” when the TX1 starts talking to the sensor. Everything gets skewed. It’s almost as if the TX1 started reading too late, or too early.
I’ll attach some pictures of what I mean.
The camera daemon and dmesg report nothing out of the ordinary when an event occurs.
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
queryPixelFormats: type: 1, pixelformat 0x32314752 "RG12"
Sensor_LoadModeModeType: mode 0: Failed to load pixeltype
Sensor_LoadModePixelPhase: mode 0: Failed to load pixeltype
setActivePixelFormat: 0x32314752
Has anyone run into this before? It’s odd to me that it isn’t a random starting point, I have three distinct outputs. Either perfectly aligned, half way, or almost entirely off the screen. I should note that when taking video or streaming during an event the issue does not resolve itself. It jumps around quite a bit and the colors screw up. However on the 50% chance the image is aligned properly everything is perfect and there are zero issues.
Making those three controls into dummy controls and setting the default values myself did not have an effect. I still got one of the three results, either all the way off the screen, halfway off the screen, or perfect.
Attaching videos of the two screwy events so you can see how it looks. When it’s perfect, it’s perfect, it doesn’t have any of those errors. videos.tar (6.34 MB)
Getting data direct from gstreamer/v4lsrc or yavta never has the issue. Everything turns out great. Just seems to be a problem when I use the ISP.
Setting discontinuous_clk = “yes”; in the dtsi causes the camera daemon to crash when I try to stream.
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc
launchCC abort cc 104
SCF: Error Timeout: (propagating from src/api/Session.cpp, function capture(), line 731)
launchCC abort cc 105
launchCC abort cc 106
launchCC abort cc 107
launchCC abort cc 108
launchCC abort cc 109
launchCC abort cc 110
Error: waitCsiFrameStart timeout guid 1
Error: waitCsiFrameStart Something went wrong with waiting on frame start
launchCC abort cc 111
launchCC abort cc 112
./debug_daemon.sh: line 6: 2350 Segmentation fault sudo /usr/sbin/nvcamera-daemon
I don’t see anything in my sensor’s developer guide about supporting a discontinuous mode.
Daemon crash cause by not get the frame data. The key point is the sensor output to discontinuous mode.
And please check the sensor mode setting in the DT is correct eight.
