Hi
My Nano has become quite unstable lately. It fails with something like this
[ 2267.285731] mmc0: Data CRC error
[ 2267.288959] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 2267.294781] sdhci: Sys addr: 0x00000008 | Version: 0x00000303
[ 2267.300602] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000007
[ 2267.306426] sdhci: Argument: 0x0148dae0 | Trn mode: 0x0000003b
[ 2267.312250] sdhci: Present: 0x01fb0008 | Host ctl: 0x00000017
[ 2267.318072] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 2267.323895] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 2267.329722] sdhci: Timeout: 0x0000000e | Int stat: 0x00001000
[ 2267.335548] sdhci: Int enab: 0x02ff100b | Sig enab: 0x02fc100b
[ 2267.341374] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 2267.347203] sdhci: Caps: 0x376cd08c | Caps_1: 0x10006f73
[ 2267.353031] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000
[ 2267.358861] sdhci: Host ctl2: 0x0000308b
[ 2267.362791] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe410
[ 2267.369342] sdhci: ===========================================
[ 2280.034801] tegra-i2c 7000d000.i2c: pio timed out addr: 0x3c tlen:28 rlen:4
[ 2280.042173] tegra-i2c 7000d000.i2c: --- register dump for debugging ----
[ 2280.050262] tegra-i2c 7000d000.i2c: I2C_CNFG - 0x22c00
[ 2280.056157] tegra-i2c 7000d000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x1010001
[ 2280.063412] tegra-i2c 7000d000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 2280.069617] tegra-i2c 7000d000.i2c: I2C_FIFO_STATUS - 0x800081
[ 2280.075887] tegra-i2c 7000d000.i2c: I2C_INT_MASK - 0x7d
[ 2280.081332] tegra-i2c 7000d000.i2c: I2C_INT_STATUS - 0xc3
[ 2280.087066] tegra-i2c 7000d000.i2c: i2c transfer timed out addr: 0x3c
[ 2280.093992] max77620-thermal max77620-thermal: Failed to read STATLBT: -110
[ 2288.294669] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 2288.294722] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 2288.294797] 0-...: (1 GPs behind) idle=2e7/2/0 softirq=308297/308299 fqs=2533
[ 2288.294846] (detected by 3, t=5252 jiffies, g=42925, c=42924, q=5)
[ 2288.319607] 0-...: (1 GPs behind) idle=2e7/2/0 softirq=308298/308299 fqs=2119
[ 2288.326960] (detected by 1, t=5260 jiffies, g=126700, c=126699, q=283)
[ 2292.558520] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 0
[ 2292.565857] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.9.253-tegra #1
[ 2292.572440] Hardware name: NVIDIA Jetson Nano Developer Kit (DT)
[ 2292.578494] Call trace:
[ 2292.581039] [<ffffff800808ba40>] dump_backtrace+0x0/0x198
[ 2292.586512] [<ffffff800808c004>] show_stack+0x24/0x30
[ 2292.591636] [<ffffff8008f6121c>] dump_stack+0xa0/0xc4
[ 2292.596754] [<ffffff8008f5e2c0>] panic+0x12c/0x2a8
[ 2292.601627] [<ffffff8008181994>] watchdog_check_hardlockup_other_cpu+0x11c/0x120
[ 2292.609085] [<ffffff8008180b08>] watchdog_timer_fn+0x98/0x2c0
[ 2292.614892] [<ffffff8008138f10>] __hrtimer_run_queues+0xd8/0x360
[ 2292.620954] [<ffffff8008139860>] hrtimer_interrupt+0xa8/0x1e0
[ 2292.626758] [<ffffff8008bfa838>] tegra210_timer_isr+0x38/0x48
[ 2292.632563] [<ffffff8008121940>] __handle_irq_event_percpu+0x68/0x288
[ 2292.639059] [<ffffff8008121b88>] handle_irq_event_percpu+0x28/0x60
[ 2292.645294] [<ffffff8008121c10>] handle_irq_event+0x50/0x80
[ 2292.650930] [<ffffff8008125aa4>] handle_fasteoi_irq+0xd4/0x1c0
[ 2292.656817] [<ffffff80081208f4>] generic_handle_irq+0x34/0x50
[ 2292.662618] [<ffffff8008120fe0>] __handle_domain_irq+0x68/0xc0
[ 2292.668504] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 2292.673958] [<ffffff8008082c28>] el1_irq+0xe8/0x194
[ 2292.678906] [<ffffff8008ba09e0>] cpuidle_enter_state+0xb8/0x380
[ 2292.684892] [<ffffff8008ba0d1c>] cpuidle_enter+0x34/0x48
[ 2292.690261] [<ffffff800811139c>] call_cpuidle+0x44/0x70
[ 2292.695539] [<ffffff8008111718>] cpu_startup_entry+0x1b0/0x200
[ 2292.701436] [<ffffff8008091cf8>] secondary_start_kernel+0x190/0x1f8
[ 2292.707749] [<0000000084f6e1a8>] 0x84f6e1a8
[ 2292.711996] SMP: stopping secondary CPUs
[ 2292.716283] Kernel Offset: disabled
[ 2292.719837] Memory Limit: none
[ 2292.824501] Rebooting in 5 seconds..
When it works, I can dd all partitions without any error
root@jet:/home/user# for f in /dev/mmcblk0*; do dd bs=10M if=$f of=/dev/null; done
12211+1 records in
12211+1 records out
128043712512 bytes (128 GB, 119 GiB) copied, 1413,09 s, 90,6 MB/s
4000+0 records in
4000+0 records out
41943040000 bytes (42 GB, 39 GiB) copied, 463,201 s, 90,6 MB/s
0+1 records in
0+1 records out
458752 bytes (459 kB, 448 KiB) copied, 0,00852792 s, 53,8 MB/s
0+1 records in
0+1 records out
786432 bytes (786 kB, 768 KiB) copied, 0,0150839 s, 52,1 MB/s
0+1 records in
0+1 records out
65536 bytes (66 kB, 64 KiB) copied, 0,00211823 s, 30,9 MB/s
0+1 records in
0+1 records out
196608 bytes (197 kB, 192 KiB) copied, 0,00364618 s, 53,9 MB/s
0+1 records in
0+1 records out
131072 bytes (131 kB, 128 KiB) copied, 0,0024137 s, 54,3 MB/s
0+1 records in
0+1 records out
131072 bytes (131 kB, 128 KiB) copied, 0,00296715 s, 44,2 MB/s
0+1 records in
0+1 records out
458752 bytes (459 kB, 448 KiB) copied, 0,0069534 s, 66,0 MB/s
0+1 records in
0+1 records out
589824 bytes (590 kB, 576 KiB) copied, 0,00907845 s, 65,0 MB/s
0+1 records in
0+1 records out
65536 bytes (66 kB, 64 KiB) copied, 0,00181348 s, 36,1 MB/s
0+1 records in
0+1 records out
196608 bytes (197 kB, 192 KiB) copied, 0,00366681 s, 53,6 MB/s
0+1 records in
0+1 records out
393216 bytes (393 kB, 384 KiB) copied, 0,00600041 s, 65,5 MB/s
0+1 records in
0+1 records out
65536 bytes (66 kB, 64 KiB) copied, 0,00153623 s, 42,7 MB/s
0+1 records in
0+1 records out
458752 bytes (459 kB, 448 KiB) copied, 0,00681788 s, 67,3 MB/s
The card is a Samsung Endurance 128GB
The board is powered through the barrel, from a modified 2.5A Raspberry power supply (i have shortened the cable and replaced the USB connector with a jack); the supply voltage is usually above 5V
cat /sys/bus/i2c/drivers/ina3221x/6-0040/iio\:device0/in_voltage0_input
5216
I’ve tried two other cards (generic UHS 64GB) with similar results
Do you have any ideas?
