When compiled using IPA optimization (-fastsse -Mipa=fast,pure -O2), the following code:
if (iter2 /= 0) then
! Do some initializations [... Omitted ...]
main_iteration: do iter=iter1,iter2
! [... Omitted ...]
if (iter <= 1) then
else ! (iter > 1)
select case (imass)
case (2) ! Axially distributed
! Evaluate the rate of density change:
forall (i = 1:ncie, j = 1:neta) ! Line 427
rhodot(i,j) = dxm_dz_new(i)*dz_dvol(i)
end forall
end select
end if
! Body of main loop [... Omitted ...]
end do main_iteration
end if
causes an internal compiler error (edited here for length):
IPA: Recompiling intgrt.obj: new IPA information
PGF90-F-0000-Internal compiler error. rewrite_subroutine:
unknown stmt found 0 (intgrt.f90: 427)
PGF90/any Linux/x86-64 6.1-3: compilation aborted
If the forall construct in the above code fragment is replaced by the following:
do j = 1,neta
rhodot(1:ncie,j) = &
dxm_dz_new(1:ncie)*dz_dvol(1:ncie)
end do
then the program compiles with no errors.
There are many forall constructs in the program, scattered over a number of routines, but the one indicated above is the only one that caused any difficulty in the IPA optimization stage.
