I have created a dummy program and it already generates this error.
[bsc85539@p9login1 test]$ nvc++ main.cpp -gpu=cc70 -o main
NVC+±S-0000-Internal compiler error. BAD sptr in var_refsym 0 (main.cpp: 11)
NVC+±S-0039-Use of undeclared variable (main.cpp: 11)
NVC+±S-0094-Illegal type conversion required (main.cpp: 11)
NVC++/power Linux 22.9-0: compilation completed with severe errors
The code:
#include <stdio.h>
class myClass {
int i = 10;
public:
void compute() {
#pragma omp target parallel for \
firstprivate(i) \
default(none)
for (int x = 0; x < i; x++)
printf("hello\n");
printf("var value = %d\n", i);
int main(void) {
myClass x;
x.compute();
return 0;
I tried without -gpu=cc70 and got the same error. My SDK version is 22.9 but I tried older versions and it didn’t work either. What am I doing wrong?
If you need more information I will provide it to you.
Thank you.
Hi jreinal,
Looks to be a compiler issue when putting the loop bounds variable in a firstprivate clause. Appears to only occur when using the distribute model, but ok when using loop.
I’ve filed a problem report, TPR #33642, and sent it to engineering for review.
The work arounds are to either switch to using “loop”
#pragma omp target teams loop firstprivate(i) default(none)
or remove “firstprivate(i) default(none)”
#pragma omp target teams distribute parallel for
Thanks for the report!
Mat
Ok, but now another problem,
the code:
#include <stdio.h>
int main(void) {
int i = 1024;
for (int x = 0; x < i; x++) {
printf("var value = %d\n", x);
return 0;
and I get:
$ nvc++ main.cpp -mp=gpu -o main
nvc+±Warning-CUDA_HOME has been deprecated. Please, use NVHPC_CUDA_HOME instead.
/apps/NVIDIA-HPC-SDK/22.9/Linux_ppc64le/22.9/compilers/share/llvm/bin/llc: error: /apps/NVIDIA-HPC-SDK/22.9/Linux_ppc64le/22.9/compilers/share/llvm/bin/llc: /tmp/nvc++Ue_dkXu4X-pk.ll:104:22: error: use of undefined value ‘%i’
store i32 %6, i32* %i, align 4, !dbg !40
This is only an example, the real code is more complex, so I need firstprivate, private, and so on.
I can’t stop crying.
Thank you!
Related but a different problem that was fixed in our 23.3 release.
Putting a loop bound variable is a firstprivate clause isn’t necessary, so the work around is to remove it.
Ok, thanks.
So, the copy of values are doing by default to pragma section when I use loop?
The last version available in CTE-POWER cluster at BSC is 22.9. I don’t know if they can install the newer version of sdk. But if this the solution is ok.
Thanks again.
