The following code generates an ICE for 18.4 & 18.10 community edition. The code works fine with gfortran and IFORT.
PGF90-S-0000-Internal compiler error. copy_initconst_to_array: unexpected const type 15 (pgi_param_bug.f90: 31)
program test
integer, parameter :: x01 = 1
integer, parameter :: x02 = 2
integer, parameter :: x03 = 3
integer, parameter :: x04 = 4
integer, parameter :: x05 = 5
integer, parameter :: x06 = 6
integer, parameter :: x07 = 7
integer, parameter :: x08 = 8
integer, parameter :: x09 = 9
integer, parameter :: x10 = 10
integer, parameter :: x11 = 11
integer, parameter :: x12 = 12
integer, parameter :: x13 = 13
integer, parameter :: x14 = 14
integer, parameter :: max_dim = 10
integer, parameter :: list1(max_dim) = &
& reshape( (/ x01, x02, x03, x04 /), (/max_dim/),(/0/))
integer, parameter :: list2(max_dim) = &
& reshape( (/ x05, x02, x09, x10, x11,x12 /), (/max_dim/),(/0/))
integer, parameter :: list3(max_dim) = &
& reshape( (/ x03, x06, x07 /), (/max_dim/),(/0/))
integer, parameter :: icnt = 5
integer, parameter :: dual_list(icnt,max_dim) = &
& reshape ((/ list1,&
& list2,&
& list3 &
& /), (/icnt, max_dim/), (/0,0/), order=(/2,1/))
print *, 'hello world'
end program test
pgf90 18.4-0 64-bit target on x86-64 Linux -tp nehalem
pgf90 18.10-1 64-bit target on x86-64 Linux -tp nehalem
% uname -a
Linux centos7 3.10.0-514.el7.x86_64 #1 SMP Tue Nov 22 16:42:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
[/code]
