Something is really odd about the norm2 intrinsic function for Fortran 2008, the pgfortran compiler fails with ICE even for simple expressions.
Operating system is a Manjaro Linux
Compiler used
pgfortran -V
pgfortran 19.10-0 LLVM 64-bit target on x86-64 Linux -tp sandybridge
PGI Compilers and Tools
Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
A minimal working example is provided with
program mwe
integer, parameter :: wp = selected_real_kind(15)
real(wp), allocatable :: xyz(:, :)
real(wp) :: dist
integer :: i, j
xyz = reshape([&
& 2.02799738646442_wp, 0.09231312124713_wp, -0.14310895950963_wp, &
& 4.75011007621000_wp, 0.02373496014051_wp, -0.14324124033844_wp, &
& 6.33434307654413_wp, 2.07098865582721_wp, -0.14235306905930_wp, &
& 8.72860718071825_wp, 1.38002919517619_wp, -0.14265542523943_wp, &
& 8.65318821103610_wp, -1.19324866489847_wp, -0.14231527453678_wp, &
& 6.23857175648671_wp, -2.08353643730276_wp, -0.14218299370797_wp, &
& 5.63266886875962_wp, -4.69950321056008_wp, -0.13940509630299_wp, &
& 3.44931709749015_wp, -5.48092386085491_wp, -0.14318454855466_wp, &
& 7.77508917214346_wp, -6.24427872938674_wp, -0.13107140408805_wp, &
& 10.30229550927022_wp, -5.39739796609292_wp, -0.13672168520430_wp, &
& 12.07410272485492_wp, -6.91573621641911_wp, -0.13666499342053_wp, &
& 10.70038521493902_wp, -2.79078533715849_wp, -0.14148379504141_wp, &
& 13.24597858727017_wp, -1.76969072232377_wp, -0.14218299370797_wp, &
& 7.40891694074004_wp, -8.95905928176407_wp, -0.11636933482904_wp, &
& 1.38702118184179_wp, 2.05575746325296_wp, -0.14178615122154_wp, &
& 1.34622199478497_wp, -0.86356704498496_wp, 1.55590600570783_wp, &
& 1.34624089204623_wp, -0.86133716815647_wp, -1.84340893849267_wp, &
& 5.65596919189118_wp, 4.00172183859480_wp, -0.14131371969009_wp, &
& 14.67430918222276_wp, -3.26230980007732_wp, -0.14344911021228_wp, &
& 13.50897177220290_wp, -0.60815166181684_wp, 1.54898960808727_wp, &
& 13.50780014200488_wp, -0.60614855212345_wp, -1.83214617078268_wp, &
& 5.41408424778406_wp, -9.49239668625902_wp, -0.11022772492007_wp, &
& 8.31919801555568_wp, -9.74947502841788_wp, 1.56539243085954_wp, &
& 8.31511620712388_wp, -9.76854236502758_wp, -1.79108242206824_wp],&
& [3, 24])
do i = 1, size(xyz, 2)
do j = 1, i-1
dist = norm2(xyz(:, i)-xyz(:, j))
end do
end do
end program mwe
Invoking the PGI compiler results in
PGF90-S-0000-Internal compiler error. transform_call:Array Expression can't be here 168 (bug3.f90: 35)
Lowering Error: bad ast optype in expression [ast=163,asttype=12,datatype=0]
PGF90-F-0000-Internal compiler error. Errors in Lowering 1 (bug3.f90: 39)
PGF90/x86-64 Linux 19.10-0: compilation aborted
Expected result is either an error message for missing Fortran 2008 support or compiling the program.
A workaround is to have a temporary variable to store the vector in and than invoke norm2.
vec(:) = xyz(:, i)-xyz(:, j)
dist = norm2(vec)
