Here is a valid Fortran 95 program:
program test_pack
implicit none
integer, parameter:: iim = 16, jjm = 12, klon = klon = iim * (jjm - 1) + 2
integer, parameter:: n_plev = 15
real v1(jjm + 1, 0:n_plev)
real v2(klon, 0:n_plev)
integer k
logical, save:: dyn_phy(iim + 1, jjm + 1)
v1 = 3.
dyn_phy = .true.
dyn_phy(2:, 1) = .false.
dyn_phy(2:, jjm + 1) = .false.
dyn_phy(iim + 1, 2:jjm) = .false.
forall (k = 0:n_plev) v2(:, k) = pack(spread(v1(:, k), dim = 1, &
ncopies = iim + 1), dyn_phy)
end program test_pack
Here is the version of the Fortran compiler I use:
$ pgfortran -V
pgfortran 13.10-0 64-bit target on x86-64 Linux -tp istanbul
The Portland Group - PGI Compilers and Tools
Copyright (c) 2013, NVIDIA CORPORATION. All rights reserved.
Compilation produces an internal compiler error:
$ pgfortran -Mfree test_pack.f
PGF90-S-0000-Internal compiler error. shape_comm: array expression is not supported 141 (test_pack.f: 21)
PGF90-F-0000-Internal compiler error. convert_subscript: it must be array 0 (test_pack.f: 21)
PGF90/x86-64 Linux 13.10-0: compilation aborted
I think this is a bug of the compiler. Is it corrected in more recent versions of the compiler ?
NB : no problem with other compilers, nagfor, gfortran and ifort.
