This might be related to TPR#4256, as the program is similar. The following code:
program mult
implicit none
integer, parameter :: m = 6, n = 23
integer, dimension(m), parameter :: b = (/ 3, 4, 2, 2, 6, 6 /)
integer, dimension(n) :: a1 = (/1,4,7,2,6,9,8,5,2,5,1,6,3,6,4,7,8,4,0,4,3,2,7/)
integer, dimension(n) :: a2 = (/5,1,2,3,4,8,7,9,6,5,2,3,4,5,9,8,2,3,4,3,1,0,3/)
integer, dimension(m) :: d
integer :: j
do j = 1, m
d(j) = sum(a1(sum(b(:j-1))+1:sum(b(:j))) &
* a2(sum(b(:j-1))+1:sum(b(:j))))
end do
write (*, "(9i4)") d
end program mult
gives an internal compiler error. Specifically,
% pgf95 -o mult mult.f90
PGF90-S-0000-Internal compiler error. transform_call:Array Expression can't be here 55 (mult.f90: 10)
Lowering Error: bad ast optype in expression [ast=37,asttype=12,datatype=0]
Lowering Error: unknown intrinsic function [ast=40,asttype=14,datatype=6]
Lowering Error: bad ast optype in expression [ast=42,asttype=12,datatype=0]
Lowering Error: unknown intrinsic function [ast=45,asttype=14,datatype=6]
Lowering Error: bad ast optype in expression [ast=46,asttype=12,datatype=0]
Lowering Error: unknown intrinsic function [ast=49,asttype=14,datatype=6]
Lowering Error: unknown intrinsic function [ast=52,asttype=14,datatype=6]
Lowering Error: bad ast optype in expression [ast=53,asttype=12,datatype=0]
PGF90-F-0000-Internal compiler error. Errors in Lowering 8 (mult.f90: 14)
PGF90/any Linux/x86-64 6.2-3: compilation aborted
However, this program works fine:
program mult2
implicit none
integer :: j, lb, ub
do j = 1, m
lb = sum(b(:j-1)) + 1
ub = sum(b(:j))
d(j) = sum(a1(lb:ub) * a2(lb:ub))
end do
end program mult2
with output of:
23 158 57 27 168 48
The second program is probably better in terms of clarity, but it seems like the first program should work as well.
