Based on the error that you are getting, this appears to be an internal compiler error. I will download the PSBLAS source and try to reproduce the error that you reported.
Thank you for trying this. I have kind of similar problem with my own code too with different internal compiler error code. I am not sure if fixing the problem with PSBLAS will fix my problem too. However my code is not open source yet. I was actually trying to test pgfortran for the Cuda capability to finally buy the pgi compilers. Hummm, so I can’t do that now.
Anyway, I try to replicate the same problem with my code and send you the test case.
