I am compiling a large project and the f90 compiler incurred in the following error
PGF90-S-0000-Internal compiler error. string_expr_length: ast not string op 14 (dtpm_if.f90: 220)
2 inform, 23 warnings, 1 severes, 0 fatal for dtpm_if
PGF90/x86-64 Windows 12.10-0: compilation completed with severe errors
The faulty line seems to be
VUL_OP_FILEROOT = ‘________________’
VUL_OP_FILEROOT(2:MIN(15,LEN_TRIM(CHAR(J+48)//TRIM(EX_LETTER)//STUDY_ID))) &
= TRIM(CHAR(J+48)//TRIM(EX_LETTER)//STUDY_ID)
but this compiles just fine with Intel 2005 fortran compiler. What is going on here?
I am using PGI fortran compiler 12.10.
Thanks beforehand.
Hi Jon,
An Internal Compiler Error (ICE) is always a problem with the compiler, though without a reproducing example we can’t tell exactly what’s wrong.
I do see one similar ICE in a problem report (TPR#19443) which has been fixed in 13.7. Can you try installing 13.7 and see if your issue was the same problem? If not, can you please send a report to PGI Customer Service (trs@pgroup.com)?
Thanks,
Mat
Hi Mat,
Thanks for the prompt reply. I have downloaded a trial license for 13.7 and tried to recompile. I have got the same identical error to the same offending line that I reported in my preceding post. Unfortunately, I cannot send my code out for you to check but it seems that your compiler has some serious concerns in managing the TRIM function when called by other functions. As I said before, the old Intel 2005 fortran compiler has no problem to manage this but our aim is just to port the code to a different platform with a different compiler and yours has given to us satisfactory results for other applications (mostly for accelerating code). I hope this could be useful to you also if the information is forcefully limited.
Regards,
Jon
Hi Jon,
Instead of the full code, it it possible to send us a small example with reproduces the problem?
Thanks,
Mat
Dear Mat,
I have managed to get a few lines of code, extracted from the offending one, that reproduce the error. Here is:
SUBROUTINE TEST
IMPLICIT NONE
SAVE
INTEGER :: NULL
INTEGER :: ERROR, I, J
CHARACTER(80) :: EX_TITLE
CHARACTER(15) :: VUL_OP_FILEROOT
CHARACTER(80) :: STUDY_ID
CHARACTER(2) :: EX_LETTER
CHARACTER(3) :: NUMBER
DO J = 1,10
VUL_OP_FILEROOT = '________________'
DO I=1,20
NULL = 0
WRITE(NUMBER,'(I2)')I
NUMBER=ADJUSTL(NUMBER)
ENDDO
DO I=1,15
NULL = 0
ENDDO
NULL = 0
END DO
RETURN
END SUBROUTINE TEST
Hope this will help to improve your really fine product.
Jon
Hi John,
It looks like its the second “CHAR(J+48)” that the compiler is choking on. I’ll send in a report once our issue tracking system is back up. As a work around, can you try the following:
SUBROUTINE TEST
IMPLICIT NONE
SAVE
INTEGER :: NULL
CHARACTER :: J48
DO J = 1,10
J48=CHAR(J+48)
= TRIM(J48//TRIM(EX_LETTER)//STUDY_ID)
! VUL_OP_FILEROOT(2:MIN(15,LEN_TRIM(CHAR(J+48)//TRIM(EX_LETTER)//STUDY_ID))) &
! = TRIM(CHAR(J+48)//TRIM(EX_LETTER)//STUDY_ID)
DO I=1,20
NULL = 0
ENDDO
DO I=1,15
NULL = 0
ENDDO
NULL = 0
END DO
RETURN
END SUBROUTINE TEST
Thanks,
Mat
