Internal Compiler error
I tried to compile some code with a large openMP parallel block and get the following compiler error
PGC-S-0000-Internal compile error. zapdtypes: bad dtype 6028
PGC-S-0000-Internal compile error. zapdtypes: bad dtype 6032
The line number it lists for the file is the last line. I thought I might be missing a bracket, but don’t see one missing. Any other clues to look for? I see no openMP warnings and do see messages indicating the parallel region was activated.
Hi Chris,
This looks like a compiler problem. Can you send a report to our customer support team at trs@pgroup.com along with a sample of the source? We wouldn’t need the entire source, just enough to recreate the issue.
Thanks,
Mat
After including omp.h, that fixed the compiler problem. I still need to sift through the code and make sure it works, and once I’m sure my code is good, I’ll try to reproduce the problem, possibly with a much simpler example.
It would great if you could distill this down since we’ed like to get the error fixed. The error occurs when an internal compiler function doesn’t know how to handle a data type. While these are often the result of a syntax or other user error, the compiler should handle the error instead of giving an ICE.
Thanks,
Mat
