Good Afternoon,
I am getting some internal compiler errors. I would like to know what is the correct way to submit to somebody of the PGI group this issue and several other issues so that we can check if I am doing something wrong or if there are really some internal compiler errors. For this specific case, the same code compiles correctly using nvcc but not using pgi. The problem seems to be some openmp pragmas in a specific file. The whole thing is important because here at the T J Watson Research Center (IBM) we are trying to accelerate the baseline versions of some DoE codes to achieve the necessary Figure Of Merits on Coral systems.
Thanks,
Fausto
