Although far removed from the original code, this produces the internal compiler error, and if I change almost any line in it it compiles so I have been unable to reduce it further (but it started at 18 000+ lines):
function help_intrinsics_one(name) result (textblock)
character(len=*),intent(in) :: name
logical :: topic
character(len=256),allocatable :: textblock(:)
character(len=:),allocatable :: shortname
topic=.true.
select case(name)
case('abs')
textblock=[character(len=256) :: '']
shortname="abs"
call process()
case default
allocate (character(len=256) :: textblock(0))
end select
contains
subroutine process()
if(topic)then
textblock=[shortname]
else
textblock=[character(len=len(textblock)) :: ' ',textblock]
endif
end subroutine process
end function help_intrinsics_one
NVFORTRAN-S-0000-Internal compiler error. Scale_Of:bad dtype 0 (nv_bug.f90: 18)
NVFORTRAN-S-0000-Internal compiler error. Scale_Of: bad dtype 0 (nv_bug.f90: 18)
0 inform, 0 warnings, 4 severes, 0 fatal for process
