Internal Error (Assertion format.hasValue() failed.format not recognized or not supported
Description
Hi, I has written a plugin to to do elementwise operation of PROD with two inputs and one type is FLOAT an the other is KBOOL, but when the program start building the engine it throws the error
[TensorRT] ERROR: 2: [pluginV2Builder.cpp::deduceTensorFormat::495] Error Code 2: Internal Error (Assertion format.hasValue() failed.format not recognized or not supported)
How can I solve that problem? Or is there any way to do elementwise operation of PROD for Float ad BOOL
Environment
TensorRT Version: 8.0
GPU Type: AGX Xavier
Nvidia Driver Version:
CUDA Version: 10.2
CUDNN Version: 8.2
Operating System + Version: Linuc
Python Version (if applicable): 3.6
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
Looks like you’re performing an unsupported operation between those 2 data types.
Hope the following may help you. If you face any issues, we recommend you please share the issue repro script and complete error logs.
Thank you.
