I am using Windows
|Edition|Windows 10 Pro|
|Version|22H2|
|Installed on|4/30/2022|
|OS build|19045.4651|
|Experience|Windows Feature Experience Pack 1000.19060.1000.0|
I would just delete that “ServerLocal” and re-add it with your up to date credentials. It is good to refresh it once in a while. Make sure you are fully logged on to Omniverse Launcher, and Nucleus.
No you lose nothing. It is just a LINK to that server, not the server itself. The same way if you delete a shortcut on your desktop, it does not delete the actual file. The omniverse Nucleus server is stored on your main work server correct ? Not on your local machine ?
