The following code gives unexpedted results. It prints out “1,2” but I am expecting “2,2.” It seems that the internal procedure, ip_print, always
prints out the global scope value of ival=1, not the enclosing scope value of ival=2.
Is this a bug or part of the Fortran Standard?
module ip
integer :: ival=1 !global
contains
integer function ip_print()
ip_print=ival !always returns global ival
end function
subroutine ip_test()
integer :: ival=2 !local
print*,'%ip_test, ',ip_print(),ival
end subroutine
end module
program test
use ip
call ip_test()
end program
The function “ip_print” isn’t an internal procedure, but a module subprogram. Inside the function the accessible entity “ival” is the host module’s “ival”.
So, “ip_print” is correctly returning the value “1”.
To make the function an internal procedure:
module ip
contains
contains
ip_print=ival ! accesses the host ip_test's ival
end function
end subroutine
end module
The Fortran standard says that ival is defined using “host association” which is the enclosing scope. Why doesn’t ival take on the enclosing scope value, ival=2, when called from ip_test()?
Because, in your original version, the host of each of “ip_print” and “ip_test” is the module. In terms of the Fortran standard “host” isn’t related to the call stack, but where the functions are defined.
That is, while “ip_print” is called (referenced) by “ip_test” its host is still the module “ip”. Only if you make “ip_print” an internal procedure (using “contains”, as in my previous example) of “ip_test” does the host become “ip_test”.
Thanks. There are many ways to get the program to print out the answer that I am expecting.
My question is:
This code seems to be contradicting the Fortran Standard.
If not, where in the Fortran Standard does it state that internal procedures or module subprograms will not use “host association” to define variables, but rather use “global scope” to define variables?
Interestingly, there are two members of the Fortran Standards
Committee across the aisle from me , and they see no problems with the code and the Standard
But rather than argue the standard, create an example that gives
different answers on different compilers, and you will get peoples attention.
Looks like I found the statements in the Fortran Standard(2003) that address my issue.
Section 2.2:
A scoping unit that immediately surrounds another scoping unit is called the host scoping unit (often abbreviated to host).
Sections 2.2.3.2 and 2.2.3.3 define what the host scoping unit is for module and internal procedures and they are the enclosing module and program/subprogram, respectively.
So, indeed, the “surrounding scope” is not always the “host scope.”
