Hi NVidia Team
When we activate the pullup/pulldown for a GPIO within the pinmux sheet, what resistor value does this internally have? We could not find this information in all the documents.
Thank you.
Kind regards
Hi NVidia Team
Thank you.
Kind regards
Sorry for the late response, is this still an issue to support? Thanks
hello sevm89,
you may access the applications note of 40-pin GPIO Usage Considerations as see-also, thanks
Hi
Thank you for the first answer.
As it is not about the 40-pin GPIO connector of the DevKit, we would like to know the pull-up/down value when a GPIO is configured accordingly in the pinmux sheet. Which value is internally activated?
Hi, no such data is public. For the pads drive strength, it is +/-1mA or +/-2mA as you can see in the Design Guide.
