Internal Storage of Nvidia Drive AGX Thor too small
DRIVE OS Version: Provide DRIVE OS version. 7.0.3
Issue Description: We are facing the issue that the available storage on the Nvidia Drive AGX Thor is very small, so if we install the Nvidia Software like CudNN, Driveworks and Tensorrt it is almost full and we often get error messages “no space left on device”. How can this be the case on a high compute development device and how could we get access to more storage on the Thor?
Dear @adas.developer ,
Could you please share the df -h ? Do you see /home/ has enough space ?
Filesystem Size Used Avail Use% Mounted on
/dev/vblkdev0 26G 25G 0 100% /
tmpfs 30G 21M 30G 1% /dev/shm
tmpfs 12G 2.3M 12G 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/vblkdev33 39M 19M 17M 52% /mnt/nvlog_logs
tmpfs 5.9G 64K 5.9G 1% /run/user/1000
/dev/mapper/data_decrypted 114G 24K 108G 1% /data
Can you use /data partition ?
We mounted vblkdev2 as a /data partition which we use for our project stuff. Unfortunately when you install Nvidia Software or libraries on your device it will always use space in folders like /usr/local or /var /etc and so on which uses the disk space of vblkdev0. So I don’t know why there is not more storage available cause this is always our bottleneck.
How about cross compile the samples on docker and copy the binaries to target under /data partition. Does that work ?
Could you please provide any update for this topic?
We found a way to solve the problem, but still it is very unfortunate and we don’t understand why storage is so limited.
Could you share the used work around for your case.
