hello, I got this error when fitting a keras model with a bidirectional layer.
tf.keras.layers.Bidirectional(tf.keras.layers.LSTM(lstm_dim))
InternalError Traceback (most recent call last)
Input In [5], in <cell line: 3>()
1 NUM_EPOCHS = 10
----> 3 history = model.fit(train_dataset, epochs=NUM_EPOCHS, validation_data=test_dataset)
File ~.conda\envs\tf-gpu\lib\site-packages\keras\utils\traceback_utils.py:67, in filter_traceback..error_handler(*args, **kwargs)
65 except Exception as e: # pylint: disable=broad-except
66 filtered_tb = _process_traceback_frames(e.traceback)
—> 67 raise e.with_traceback(filtered_tb) from None
68 finally:
69 del filtered_tb
File ~.conda\envs\tf-gpu\lib\site-packages\tensorflow\python\eager\execute.py:54, in quick_execute(op_name, num_outputs, inputs, attrs, ctx, name)
52 try:
53 ctx.ensure_initialized()
—> 54 tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name,
55 inputs, attrs, num_outputs)
56 except core._NotOkStatusException as e:
57 if name is not None:
InternalError: Graph execution error:
Failed to call ThenRnnBackward with model config: [rnn_mode, rnn_input_mode, rnn_direction_mode]: 2, 0, 0 , [num_layers, input_size, num_units, dir_count, max_seq_length, batch_size, cell_num_units]: [1, 64, 64, 1, 2537, 256, 64]
[[{{node gradients/CudnnRNN_grad/CudnnRNNBackprop}}]]
[[Adam/gradients/PartitionedCall]] [Op:__inference_train_function_5896]
I have Windows 10, tensorflow version 2.8.0 , RTX 3060, Cuda 11.6.110 driver.
can you help me to fix it? not sure what my RTX 3060 is compatible with.
